Question about GE Refrigerators
My refrigerator is from 1981: it is a TFF 24 model. Has always worked well and then all of a sudden the water and ice dispenser stopped working: one presses the button hears a sound but no water nor ice comes out; what shall I do?
  • GE Master
  • 3,287 Answers
Since you can hear the solenoid clicking on and off, it is not likely an electrical problem with the switch or associated wiring and solenoid valve - that's good.
Many fridges have a water filter that requires regular replacement. If yours has been installed for a while, it may be overdue. Remove and replace the filter and try again.
If you have recently pulled the fridge out from its "normal" position in your kitchen, it is very possible that the flexible water supply tube has been crushed or kinked when it was pushed back into its normal position. You'll have to pull it out again to inspect and replace the tube if found to be damaged for it to work normally again.
Fridges that have water and / or ice service receive water from a small diameter (1/4") flexible copper or plastic tube. Many times, the tube is connected to a valve that is designed to wrap around an exposed cold water pipe that is normally found under the kitchen sink. It may also be connected to a normal sized shut of valve by a plumber in anticipation of a fridge like yours, too. If you have the wrap around style valve assembly, the knob on the valve is used to both puncture the pipe during installation and later to turn the water supply on and off to the fridge. The hole made in the pipe is fairly small, and depending on how "hard" your water is, may have become clogged. You'll want to shut off the water that supplies the valve so that you can inspect it, clean or replace it completely without getting soaked.
These are the most common problems - but there are others. Hopefully, one of these will be the issue and it will work again. Good luck!
Posted on Nov 12, 2010
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Refrigerator dispenses ice, but does not dispense water?
Unfortunately, the housing that the water filter fits into is also the housing for the solenoid controlled water valve, and that is the most likely failure item.
Mar 29, 2010 | Whirlpool GS6SHAXMQ Side by Side...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice maker stopped working
if the water dispenses from the water dispenser I would say its the. Ice maker control module...try here
www.techray1.com and the link is on the guru guy on the left
Jun 15, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker working, water stopped dispensing
This could indicate the water valve on back that sends water to ice maker is not working. The coil can be checked with an ohm meter. I also can help you diagnose the problem. Send the model number of your refrigerator so I can help you better, Thanks, Sea breeze seabreezehvac@yahoo.com
Below you can visit my site and enter model and part numbers in search feature, we offer free help and assistance.
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
WATER IN DOOR
bad solenoid assembly maybe
Jul 05, 2007 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
