Question about SanDisk Audio Players & Recorders
Communication port pins are bent - SanDisk Audio Players & Recorders
  • 8,596 Answers
Must be replaced - taking player apart will cause damage, so usb port cannot be repaired/replaced (plus specific components are not orderable).
Posted on Jun 18, 2008
Lenovo USB port bent pins
The USB port/socket needs to be replaced it cannot be repaired.
It is not an easy DIY job, you need to take it to an IBM laptop repair center or a laptop repair shop.
Aug 25, 2012 | IBM Lenovo ThinkPad T400 (2767P6U) PC...
One of my pins was bent I straightened it out and it worked. Now someone bent it again and I can't get it to work at all. I see the light blink, but the pc don't recongnize it or even say that it sees it.
Hi as you mentioned that the pin bent again,so make the pin straight and if you've done that and it's still not working, double check your communication cable to make sure it's properly connected on both ends, otherwise you may need to try a different USB cable (I'm guessing that's what it uses to connect to the computer) to see if that may be the problem.
Best of luck.
Dec 19, 2010 | Computers & Internet
Usb to i pod or hitachi camera
i,d suggest that the ports are incorrectly wired on the motherboard headers, Or possible Bent Pin on the USB shorting out, when device is connected. 5V+ and 5V- will cause the computer to Arc, and restart.
Mike @ compurepair.
Nov 04, 2009 | Asrock K7S41 Motherboard
Communication Error when uploading photos
You may have switched USB mode to Pictbridge by mistake.
Press Menu/OK, select Setup, choose USB mode (on 3rd page) switch from Pictbridge to DSC, press OK.
Oct 05, 2009 | Fuji FinePix S1000FD Digital Camera
Replaced batteries, mouse lights up but it does not work the curser. Any ideas
Get a new mouse. On my opinion I perfer a ball mouse then a laser type mouse because they just break fast.
Sep 30, 2009 | GE Wireless Optical Mouse
HDMI port on xbox 360 has bent pins
Bent pins are a tough problem. In a lot of cases when you try to straighten them they break off. The best system to try is with very small needle nose pliers. Gently grasp each bent pin and bend. They don’t have to be perfect but close. Work on one at a time and work slowly. Still it is just a chance it will not break. Good Luck.
Jul 21, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
I need a pin out for a Vertex 5500 Mobile Radio Accessory Jack.
I found this info at: https://www.manualslib.com/manual/737199/Vertex-Standard-Vx-5500l.html?page=12#manual
It's easier to read it there.
DSUB 25-P
Pin 13: TXDI
[Digital Input for DATA Communications]
TX Hi-speed Data Input Type (jumper JP2005).
Input level 800 mV/600 Ohms, Max.input 1.2V
Tx Low-speed Data input Type ( Jumper
JP2006). Input level 40 mV/600-Ohms
If the Jumper setting is "Low-speed Data" (JP2006
jumpered), this port is usable in the AUDIO
(300~3000 Hz) range.
If the jumper setting is "HI-speed Data" (JP2005
jumpered), this port is usable for 9600 bps DATA
communications, because the filter and limiter are
not engaged in the Audio line.
Pin 14: DC OUT
[13.4 V/5 V DC Output]
Switched 13.8V output for supplying power to
an accessory (jumper JP2008).
Switched and regulated DC 5.0V output for
supplying power to an accessory (jumper
JP2007).
Maximum output current is 200 mA
Pin 15: IGN
[Ignition Sense feature]
The VX-5500 may automatically be switched to
the STAND-BY mode when the vehicle's igni-tion
key is turned on.
Maximum current is 20 mA.
This feature is only enabled on transceivers con-
figured for Dual Deck operation.
Ignition 13.8V
Pin 16: NC
[NO connection]
A
IN
CCESSORY
DSUB 25-Pin
Operating Manual Reprint
C
ONNECTOR
Pin 17: RX DO
[Digital Output for DATA Communications]
RX Hi-speed Data Output Type (jumper
JP2003). output level 600 mV/10k Ohms
RX Low-speed Data Output Type (jumper
JP2004). output level 200 mV/600 Ohms
If the Jumper setting is "Low-speed Data" (JP2004
If the jumper setting is "HI-speed Data" (JP2003
Pin 18: E
[GND]
Ground for all logic levels and power supply re-
turn.
Pins 19, 20, 21, & 22: DSUB 19, DSUB 20, DSUB 21
and DSUB 22
LOGIC level (+5V / 0V) output.
The logic output appears at these pins when the
front panel's PF key is turned on.
The possible programming features (use CE49)
are illustrated below.
If the HA feature is assigned to these ports, a cur-
rent amplifier must be connected between the
Horn circuit and the port.
None/A PORT/B PORT/C PORT/D PORT/E
PORT/HA PORT
Pin 23: EXT SQL
[Squelch Signal Output]
Open collector output. Max. sink current 10 mA.
A Signal is present (Squelch is open): Level High
No Signal is present (Squelch is closed): Open
When you connect the solder jumper on JP2002,
this port changes to PULL UP (5 V) output.
This status can be changed by CE49 programmer.
Pin 24: SP MUTE
[Speaker Mute Output]
External Speaker mute on: Level High
External Speaker mute off: Open
Pin 25: E
[GND]
Chassis ground.
Dec 11, 2017 | Vertex Radio Communications
Controller port usb pins are bent
is it in the warrinty / do they cover it
Oct 20, 2007 | Microsoft Xbox 360 Console
4 port belkin kvm
The things that usually go wrong with KVMs are bent connector pins (usually mouse or keyboard) or the switch itself. Inspect the mouse connector for bent or corroded pins. They are easy to bend and straighten, however, they will eventually break off if you do it often enough. If you find one that is bent the safest way to straighten it is by using a .7 diameter mechanical pencil. Remove the lead, and work the pin carefully into the pencil barrel. Once you have the pin inside the pencil gently straighten it by moving the pencil vertical. If it?s not a bent or corroded pin there isn't a whole lot else you can do other than try to get a warranty replacement or if its expensive enough, repaired.
Mar 20, 2007 | Belkin F1DK102P 2-port KVM Switch
63 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
