Question about HP L1950 LCD Monitor
Can't get base to pivot so monitor faces front
I just purchased an HP L1950 LCD monitor. The monitor ships with the screen facing up (parrallel to the base). I've tried to pivot it forward, but it moves about 2 inches and then feels like more pressure would break it. How do I get it to face front?
  • kasperg2 Jan 20, 2009
    I have the same problem! Is there a lock somewhere? Could it it have anything to do with the pin you have to remove to make it swivel?
    Is it a hardware failure?
  • Pt Time computr Tech skiR
    TILT IT MORE FIRMLY ! I too feared I would break my recent-purchase, so I did not take it past a firm resistance. But went to my tech dept at work, and they demoed for me, just tilt it more firmly past the point of strong resistance and it tilted fine (then I tried it on theirs). It was good to try it elsewhere first, but trust me on this; AS LONG AS that LOCKING PIN has been REMOVED at the second (upper) hinge small opening [if there's a oval hole with nothing in it, you're good-to-go), this will work
  • HP Master
  • 3,368 Answers
Take it back!
Posted on Mar 07, 2015
3 Suggested Answers
  • 1684 Answers
SOURCE: hi I have HP L1950
The problem you have is usually caused by a bad power supply in the monitor. If you can solder you can usually fix the problem by replacing a few bad parts. The bad parts are called capacitors. If you go to our web site at:
www.ccl-la.com/badcaps.htm We have some pictures posted of what to look for when you take the back off of the monitor. You can order replacement capacitors from several web sites or we can provide them for you. The values will be marked on the sides of the ones in your monitor. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. Contact me if you have more questions or need the repair done by our techs.
I hope this helps.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 06, 2009
mcdevito75
  • 1970 Answers
SOURCE: monitor facing ceiling want it to face me sitting
mcdevito75 here, You should be able to hold the monitor at the 9 and 3 O"clock position and simply use your hands to tilt the monitor to it"s desired position, look for any Locking type knobs on the back of the monitor Not the monitor itself but the base, the part the monitor is attached to, if so Loosen knob--s just enough to move monitor then re-tighten when done.
Posted on Jun 26, 2010
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
HP L1950 DISPLAY MESSAGE NO DVI INPUT
in this situation, there are two options. 1.The device connected to your TV via DVI cable is off. 2. DVI cable connected to the HP L1950 is burned.
if you try to connect a device to the HP L1950, it has two ways to connect:
Input Signal - Two connectors: one 15-pin mini D-sub analog VGA and one DVI-D. Try VGA them.
When i power up gateway screen is black
Most likely, its a power supply issue. Have fixed a couple of these by replacing bad capacitors on the power supply board. A bad capacitor will have the top bulging, not flat on top as it should be. The way to get the monitor apart is a little tricky. You will need to remove the screws around the top, sides, and bottom, Do Not remove screws on back in the middle. These screws hold the metallic pan that houses the power supply it's self. I used an orange pealer from Tupperware to pray the front face plate away from the back. You can use a screwdriver, if you don't mind a little marring on the face plate plastic. It's not easy removing the front face piece, lots of interconnecting plastic locks all.around the front face plate. Using your pry tool and pulling (you'll need to use a little muscle) to get the front off. Once face plate is loose, you'll notice the screen is connected to the power supply, one in the middle usually can be pulled and disconnected using your hand. I suggest taking pictures before removing the other wires holding the screen to the power supply. At this point, the front plate is removed, and the screws holding the the screen have been removed, wires disconnected, and power supply in view. Best of luck
Nov 10, 2013 | Gateway FPD1960 19" Flat Panel LCD Monitor
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
Monitor facing ceiling want it to face me sitting upright
Jun 25, 2010 | HP L1950 LCD Monitor
Hi I have HP L1950 i am facing issue with that LCD...it always showing white screen
I hope this helps.
Buddy
Corporate Computer
www.ccl-la.com
Aug 06, 2009 | HP L1950 LCD Monitor
Hp pavilion f1930 shows pic for 2 secs. then blank
Rather than guessing, or blaming the computer, I fix the F1903 backlight problem. Power the monitor and using a bright flashlight check the screen to ensure there's an image, or the menu when you press the menu button. Nearly every one of the F1703 and F1903 monitors I've repaired have all been backlight issues. If you have an image proceed with these instructions. This is a repair for those people competent in component level electronics repair with good soldering skills. Items needed, Crosstip screwdrivers, fine tipped soldering pencil, fresh rosin core solder, (4) "2SC5706" or "C5706" Transistors. Remove the 4 screws holding the base, set the base aside. Lay the monitor face down on a surface that won't damage the screen or Bezel. Remove the 4 screws holding the back on.Carefully pry the back away from the bezel. Be careful in doing this because the display controls are attached to the bezelremove the 4 screws holding the control board on. Turn Monitor face up, remove bezel. With the Monitor Face up remove the Machine screws around the edge of the case. Carefully place the monitor face down again without having the LCD fall out of the Monitor frame. Peel the foil Tape back on one end of the frame and using small pliers, unplug the 4 CCFL plugs (these go to the 4 lamps, I believe you have to remove the VGA and DVI connector Hex socket screws and screws around the power input. Carefully lift the back up and unplug the LCD, you'll have to remove the adhesive backed ribbon cable retainer. Set the LCD somewhere safe.The board with the 4 CCFL plug sockets is the Inverter board, unplug it fomr the Logic board, Remove the screws holfding it in as well as the 2 plastic clips (Squeeze these one at a tim with needle nosed pliers while gently lifting the board up.set the Monitor fram aside as you're going to focus on the inverter board. Using a LIGHTED magnifier, look for cold solderjoints, dull gray and pitted looking. One by one remove the solder with a desoldering braid (I mark the board with a sharpie pen to remember where all of the questionable joints are.) Using a fine tipped soldering pencil REMOVE the solder and replace with fresh rosin core solder. Be VERY careful not to disturb any of the surface mount components on the board. There are 2 large gray boxy looking capacitors with 2 transistors around each one. Check the solder connections there carefully on the capacitors. Look for signs of arcing, blackened spots or overheated circuit board. The 4 transistors in this area are (2S)C5706, replace them all, they're about a dollar apiece on EBAY, I would NOT recommend using a "SK or EGC Equivilent". Once the transistors are replaced, reassemble the monitor, up to the point of where you put the plastic case back on. with the monitor face up, plug in power and a signal cable form the computer and carefull press the power button on the Control board, the monitor should work. This is the most common fault with this monitor, if it doesn't work, go back and check all of the solder joints and resolder any you may have missed. Once the monitor works again, reassemble the plastics onto the frame, attach the base. I hope this helps, I can't promise this will resolve the issue every time, but it has in virtually every one of this model I've repaired. This repair helps the "no backlight or comes on then goes dark" problems. Randy L. Bray
Mar 29, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Hp l1950
If pressing the power button has no effect, the Power Button Lockout feature may be enabled. To disable this feature, press and hold the monitor power button for 10 seconds.
Jan 14, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Cracked face panel on monitor
Yes, the LCD screen "face panel" can be replaced. However, note that this part is the most expensive part of the monitor. If your monitor is more than a year or two old, it may be difficult to find a replacement and it may be more cost effective to simply replace the whole monitor.
Oct 11, 2008 | HP vs19 (Silver) 19" LCD Monitor
HP L1950 LCD Monitor Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
