Question about Dell UltraSharp 2407WFP 24" LCD Monitor
Whole screen flickers on and off continuously for a few minutes. Is good for a while then goes bad again
  • 11,361 Answers
You may have dying power supply, backlight inverter board, backlight assemblies. You will have to do some in-depth troubleshooting and take some voltage measures before and after the problems.
Please read my guide and look at the pictures before DIY repair.
It is similar to 2408; http://s807.photobucket.com/albums/yy352/budm/Dell%202408WFP%20Rev%20A02/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Nov 12, 2010
PANDIGITAL Digital Photo Frame works perfectly except the SCREEN Flickers Black after a few moments
Annemarie, I had a similar problem with an off-brand photo frame from Wal-Mart last year, although in my case the frame would shut down entirely after it had flickered a few times. In my case, I was able to remove the back of the frame's case by removing 4 screws (two were hidden underneath model number stickers) and inspecting the device's innards... what I found was that, as you surmised, there was a loose connection from the female end of the DC-in power supply. The ground connection to the device's circuit board had been poorly soldered, leaving the connection itself loose and a small piece of solder on top of the board and very near the positive connection.
While not being the best solderer in the world, with the aid of a magnifying glass, a solder removal tool, and a ColdHeat soldering wand, I was able to heat the offending piece of solder and remove it from the circuit board and then, as I was personally uncertain of my ability to re-solder the connection without melting the board, I simply held the connection in place and applied a dab of hot glue to keep it there. After the glue cooled, I reassembled the case and the frame worked for almost another year before something else finally burned out and it was left cold and dark.
Hope this helps, good luck!
Dec 03, 2013 | PANDIGITAL 7-Inch Digital Photo Frame with...
Samsung television flickers to bright white fuzzy picture
In such cases, we have to ensure that it is not the input device that is causing this problem. So, please switch your input device to something you are sure, works. If you notice same problem, look for loose contacts in inter connecting cables and jacks. If problem persists, please refer it to a qualified service technician.
Jul 28, 2012 | Televison & Video
I have a HP dv4t-1100SE. Recently I changed my LCD panel as per HP advise. The notebook worked fine for 3 months. Again I have multiple problems. 1. As soon as I start my notebook screen starts...
1; Try running with no main battery first. (batteries are short lived)
2: try a new power pack.? (wall to PC)
3: ;make sure the power pack jack at PC edge when wiggled does not cause screen to drop out. (bad connection there)
4: bad LCD inverter. (if separate from main screen)
5: stuck key on keyboard.
6: As you turn it back on tap the F10 key. This will load BIOS setup utility.
Press F9 to load defaults.
Press F10 to save and exit.
7:overheating, it can do that fast if the CPU heat sing falls off.
or goes loose with no thermal compound working there,
or full of dust bunnies. the fan must blow and most cool the pc
and not have its vents blocked, clean it. is cure.
HOw does BIOS work, ? good? all sceens look ok, /?
esc key or F10 to reach bios, which every yours is.
Apr 21, 2017 | HP Computers & Internet
I have a Dell D610 Notebook that displays very faintly (almost black) but works perfectly with External Monitor. When I try dual display it shows continuously on Ext Monitor and only flickers on the...
It sounds like you have a bad inverter board or bad lamp, but chances are it is the inverter board located at the bottom of the LCD screen inside the housing. I suggest taking it to a computer shop for a estimate before you decide to have it repaired.
Dec 20, 2010 | Dell Latitude D610 Notebook
32" 32lc7d after a few minutes, flickers, then goes dark.
There are no fans in this model but it looks like either the backlights in the screen are breaking down after they have warmed up or a problem in the inverter board, again part of the driver circuit breaking down after a period of time. They inverter boards can sometimes be replaced seperatly but usually come with a new screen which if the backlights are at fault then the screen would need to be replaced.
Feb 04, 2010 | LG 32LC7D Television
I can hear the tv but after flickering for a few minutes the whole screen goes black. If I turn it off at the mains for a while it comes on again but only for a few minutes then goes black again. The...
There are many things that can cause this. Depending upon the type of projection set you have, the particular solution will be different. Can you please update this posting with the make and model please?
Thanks,
Dan
Oct 29, 2008 | Televison & Video
Lcd Flickering
Sounds like the driver board for the backlight is going bad...is there a spot on the screen part of the case ( usually at the bottom) that feels much warmer than the rest?
Mar 16, 2008 | Gateway 450ROG Notebook
Acer AL1716 monitor flickers
i Have the same problem, this screen is used on the spare computer we have in a loft conversion and the room does get rather cold, Warming the screen up with a fan heater for a couple of minutes gets rid of the problem. When the fault occurs the buttons on the front to adjust the picture quality don't work they just turn off the monitor.
Dec 08, 2007 | Acer AL1716 17" LCD Monitor
Dell UltraSharp 2407WFP 24" LCD Monitor Logo
191 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
