Question about Tricity Bendix AW1000W Front Load Washer
How can i clean the rubber seal on the door - Tricity Bendix AW1000W Front Load Washer
  • Tricity Bendix Master
  • 3,463 Answers
Get some very coarse sand paper and rub hard on the seal, this should remove the worst of the residue
Posted on Nov 12, 2010
How do I clean the rubber door seal
This video will show you how to change a door seal on this bosch
Jun 26, 2012 | Bosch Washing Machines
Model wm0642hw front load. it leaks by door frame.rubber seal with clamp.only 2 years old. do i need to change the door frame outer part a151? thanks for your response in advance
Hi, If the door isnt loose or broken? Its more likely to be the rubber door seal if its leaking between the seal and the door glass. Check the edge of the seal where it touches against the glass for damage or ware if its ok clean any soap residue or bits from the glass.If it still leaks change the door seal.
Regards Elect App
Jul 13, 2011 | LG WM-2277HW Front Load Washer
I want to clean can i run thru with vinger,bleach and what else can i do?
With the machine off, open the door and spray Clorox Clean-Up inside of the front rubber door seal/gasket. You should be able to gently flex the rubber seal to get inside of its cavity. This is where mold, etc. tends to accumulate. After a minute or so, brush or wipe away any debris that has accumulated. Be careful not to wear good clothes! Once you have completed the gasket/seal cleaning, begin a hot water cycle with no detergent to thoroughly rinse the bleach from the door seal/gasket.
From then on, occassionally glance inside the gasket/seal to see whether there is a build-up of mold, etc. and repeat the aforementioned process.
Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have mold on the rubber door seal
This is a comon problem In areas where miosture is high and the tempiture is warm. Try using bleach to clen it off with or you can use super clean to remove it from the rubber. Not touchingthe seal with your hands and clothes will help some to.
Aug 31, 2009 | LG WM-2277HW Front Load Washer
Water leaking from door
This video will show you how to change a door seal on this Bosch front loader washing machine to stop leak
we have all bosch repairs in our channel
You can get seals on eBay
Aug 29, 2009 | Bosch Washing Machines
Is there a way to clean rubber seal around the opening?
Use a vinagar solution to clean the rubber seal. bleach will damage the rubber.
Apr 29, 2009 | Washing Machines
How do you clean the interior, I have a gross mildew looking build up on the rubber seal?
you cant really clean the door seal it will need replacing why you get the mildew on the door seal is that when you finish washing you close the door but this is a mistake never close the door as this lets the rubber seal dry and the moisture that evaporates goes into the atmosphere if you close the door the moisture never drys which causes the mildew
Jun 11, 2008 | LG Washing Machines
Tricity Bendix AW1000W Front Load Washer Logo
46 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
