Question about kawasaki Garden
My trimmer starts but then it quits running. I checked the plug and it is dry. Sounds to me there must be a blockage in the fuel line. Am I right?
  • 718 Answers
Could be but most likely the blockage is in he carb.
Posted on Nov 13, 2010
What can be making my edger turn off right when it sounds as though its going to start?
A faulty on off switch can cause this.spark plug foulage.fuel blockage.loose spark lead.broken power feed to spark.hope this helps
Aug 14, 2014 | McLane 3.5 HP Gas Edger & Trimmer...
My Ryobi 4 cyl 30cc leaf blower just quit starting. Has always started perfectly, but now it just wont start.
replace spark plug.if spark plug okay problem could be carburetor or air leak at fuel lines or check primer bulb for crack which cause air leak.any breaks in fuel line or primer bulb cause air leaks fuel system cause carb not get fuel run engine.
Sep 20, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I fixed one featherlite trimmer by replacing the feul lines but the other one starts running after being primed by the bulb and will run for 3 seconds or so and quit. Any suggestions for what to try next?
  • Alow the engine to run for longer on the start setting before you switch to run (choke turned off)
  • Ensure air filter is clean. Foam elements can be washed with hot water and detergent, squeezed dry in a cloth, and then rub about half a teaspoon of oil evenly through the foam. Paper elements can be cleaned with compressed air blown from the inside of the filter but ideally should be replaced.
  • Check fuel lines aren't kinked or blocked restricting fuel flow.
  • Ensure fuel filter isn't dirty. This is probably located at the end of the fuel line in the tank.
  • The fuel lines may have become airlocked.This can happen if the tank is run dry. If the trimmer has a primer bulb, alternatively press it several times and then try to pull start the engine with choke on. Repeat this several times. The primer bulb should feel spongy and fill with fuel.Once the engine kicks, switch to run
Ensure the choke is turning off ok when you rev the machine (automatic turn off choke)
Have a look at these tips also :
http://www.fixya.com/support/r9230929-weed_eater_strimmer_will_not_start
Jun 13, 2011 | Garden
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Mightylite 26cs Gas Trimmer
sounds to me like dirt in gas tank dirty or plugged filter screen on fuel line inside gas tank or plugged pinched or obstucted fuel line . also check for the following pin hole in primer bulb bad spark plug dirty or rusty coil or flywheel magnet.or simply dirty or missadjusted carb if i can be of further assistance let me know i would start with the fuel hoses and make sure they are in good shape first ...do the easiest and cheapest things first good luck hope this gets you up and running good mrdmburns@cableone,net
May 01, 2009 | Homelite Mighty Lite Lawn Trimmer
I have a 125l trimmer and it runs for about 10 minutes and then it dies. it will restart, but will not run at trimming speed.
I had the same problem. Check the fuel line right above the grommet on the tank. Mine dry rotted and had a small hole in it sucking air. The trimmer would start ok but wouldn't run long or at all wide open. Replace the fuel line and grommet (all one piece).This fixed my problem.
Mar 31, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
My ryobi lawn trimmer fuel cuts off while running and hard to start
A number of possibilities:
1. Air filter needs cleaning. Remove two screws at the side of the filter housing (has the choke control through it) and remove filter from inside. Clean in water with detergent. Allow to dry before saturating with 30SAE oil - squeeze to evenly distribute. Then replace.
2. Fuel tank is insufficiently full allowing air to get in when machine is rotated awkwardly.
3. Fuel line or carburettor jet blockage. Try a little compressedair down the line.
Nov 27, 2008 | Garden
Garden Logo
195 people viewed this question
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
dannydoesita
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
