Question about Brother Office Equipment & Supplies
I have a mfc 465-cn and I have another computer and tried to install my printer. once I get to the part of installation where I insert the usb cord into the port and turn on the machine it doesn't recognize the port. I went and bought a new cord and it did work either. I don't have my manual for this printer anymore is there a way to possibly reset this?
    Genius:
  • 1,325 Answers
Hello
have you tested all USB ports and with other applications (ie: digital camera, cell phone, USB drive stick, etc..) ?
if one USB does work, buy a USB hub and salvage this working USB port (if that is the case here, that only one USB port on your computer functions) . This will allow you to use other USB ports on the hub . But beware you will have limited useage as to what you can or cannot plug in. USB hubs generate 500mA typically for a 4 port hub, so any peripheral requiring more than 100mA-120mA current downstream may not work on this hub.
if you need the manual to your Brother printer, go to this link and download or save onto your computer
http://welcome.solutions.brother.com/bsc/public/us/ca/en/doc/manual_index.html?reg=us&c=ca&lang=en&prod=mfc465cn_all&dlid=&flang=English&type2=-1
i hope this helps
Posted on Nov 12, 2010
I have a acer laptop. i also have the printer usb cord sonnected to the computer and i inserted the disk to install the option to use the printer. but it doesn't want to install. how can i get the printer...
First disconnect the printer from the laptop. install the drivers from the CD that came with the printer. Reboot. Now connect the printer. Allow Windows to detect the printer and load its drivers and give you a message in the right bottom corner saying "The new HW is installed and ready for use". Now run the word processor and go to File->Print. Here specify this printer as your default printer. And print away.
Dec 04, 2009 | Brother MFC 210C All-In-One InkJet Printer
Problem with installation
First Disconnect your printer
Reboot the computer
Start the installation from CD
Connect the printer when you see the screen to connect the printer
Once you connect the printer correctly to the USB it will proceed with the installation
Oct 07, 2009 | Brother Multi-Function Center MFC-240C...
How do I connect Brother MFC5440 CN to my computer
I would suggest USB - there is a little square connection usually on the oppisote side of the power.
Jun 19, 2009 | Brother Multi-Function Center MFC-240C...
Scanner - MFC 7420
Get the manual, and you may need the install disk too. Look carefully at the usb port on the copier so you get the correct usb cord.
Mar 31, 2009 | Brother MFC 7420 All-In-One Laser Printer
SCANNING WITH A BROTHER DCP 7020
I cant find the machine DCP-7020 but I think this machine is the same with model MFC-7420 if you have the installer CD follow these steps:
For USB Interface Cable Users
For Mac OS® 9.1 to 9.2
& Software
1 Turn off and unplug the MFC from the AC outlet and disconnect it from your Macintosh, if you already connected an interface cable.
2 Turn on your Macintosh.
3 Insert the supplied CD-ROM for Macintosh into your CD-ROM drive.
4 Double-click the Start Here OS 9.1-9.2 icon to install the printer and scanner drivers. If
the language screen appears, select your language.
5 Click MFL-Pro Suite to install.
6 Follow the on-screen instructions, and restart your Macintosh.
7 Connect the USB interface cable to your Macintosh, and then connect it to the MFC.
DO NOT connect the MFC to a USB
port on a keyboard or a nonpowered
USB hub.
8 Plug in the power cord and turn on the MFC.
9 From the Apple menu, open the Chooser.
10 Click the Brother Laser icon.
On the right side of the Chooser, select the
MFC to which you want to print.
Close the Chooser.
The MFL-Pro Suite, Printer driver and Scanner driver have been installed.
To install Presto! PageManager, click the
11 Presto! PageManager icon and follow the on-screen instructions.
Presto! PageManager has been installed and the installation is now complete.
You can easily scan, share and organize photos and documents using Presto!PageManager.
Dec 11, 2008 | Brother DCP 7010 Multifunction Laser...
My Brother MFC 465-CN keeps saying "No paper fed"
try cleaning the paper feed roller with isopropal alcahol
Nov 26, 2008 | Brother MFC-465CN InkJet Printer
USB Cable
The longer one will work, no problem.
Now if the cable was 25 or 50 foot long, that would be a completely different story.
6' is what they consider as the "ideal" length.
Oct 18, 2008 | Office Equipment & Supplies
PC won't detect MFC-210C Printer
TRY THIS, remove or uninstall the printer from your computer and turn it off.
Now, before you switch back ON the computer, remove the USB connection of your printer.
When the computer is done loading. Install the Printer using the CD that comes with the printer.
When the installer ask you to insert the USB connection of the printer,
that's the only time you should insert it to the USB port... switch ON the printer... Installation should proceed smoothly until completed.
That should solve your problem
Jan 21, 2008 | Brother MFC 210C All-In-One InkJet Printer
Installation brother mfc 420 cn
You can try searching the web for the driver for that machine or call Brother directly at 1-800-284-4357 and order another cd
John
Dec 09, 2007 | Brother MFC 420CN All-In-One InkJet...
51 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
