Question about Watches
SOURCE: seiko watch stuck crown
The crown maybe a screwdown type. Try unscrewing (like jar lid)them pulling out the crown.
Posted on May 04, 2007
SOURCE: Setting time and date on my Cartier Pasha watch.
Do not be so afraid. Unscrew that big crown fully, pull off and then you will see the real setting crown(quite small one), called an underlayed crown.
That little chain is hard enough to withstand your pulls, unless you are drunk. :)))
When you get that small crown handy- you can set the time and all the features.
If the small crown is not moving, your watch is rusty and you will need a proper watchmakers help.
Don't forget to rate, please.
Posted on Jan 11, 2009
SOURCE: discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Posted on Jan 25, 2009
SOURCE: Where can I buy a new White Resin Nautica watch band.
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Posted on Jan 26, 2010
Testimonial: "THANK YOU"
SOURCE: replacement band for my nautica watch N17524G
Follow this link and contact Nautica: http://www.nautica.com/helpdesk/index.jsp?display=store&subdisplay=contact Rate me plz.
Posted on Mar 04, 2010
Testimonial: "excellent work ! thanks a lot !"
Jan 16, 2013 | Watches
the battery may need replacing
HOW TO START YOUR WATCH
To start your watch remove the plastic guard from
under the crown, then press the crown in against
the case. The second hand will begin advancing in
one-second intervals.
Some deep-depth water-resistant watches require
the setting crown to be screwed in to secure
water-resistance. If your watch case has a protrusion
with screw threads, the crown must be screwed in
after setting the watch.
To screw in, push the crown firmly against the
threaded protrusion and hold in while turning the
crown clockwise. Continue to screw in the crown
until it is tight. You will need to unscrew the crown
(counter-clockwise) before pulling it out the next time
you want to set your watch
Oct 17, 2012 | Timex T2N652 Womens Weekender Watch...
Jul 22, 2011 | Watches
Apr 07, 2011 | Movado Juro 0605023 Wrist Watch
Feb 10, 2011 | Nautica A31504 Watch
Jun 26, 2010 | Invicta Subaqua Noma Iii S
Mar 26, 2010 | Tag Heuer WK1120.BB0314 Wristwatch
Jan 10, 2010 | Nautica Compass Chrono Date Leather Set...
Oct 19, 2009 | Nautica Blue Dail Yacht Chronograph Watch...
May 02, 2007 | Seiko SNA553 Alarm Chronograph
Apr 19, 2018 | Columbia Watches
157 people viewed this question
