Question about Powerware 9330 40 (A40401110031112) UPS System
Replacement batteries were installed but were not Powerware brand. The brand put in is DataSafe P/N of Powerware is PWHR12120W3FR and I need the cross reference to the DataSafe type.
  • 45 Answers
I don't know the exact cross reference number for you but Eaton tech support should be able to help you. Eaton bought Powerware 6 years ago but retained their service support personnel.
Toll Free: 1 800 843 9433
International: +1 919 871 1800
E-mail: LargeUPSTS@Eaton.com
Posted on Nov 15, 2010
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
We had a power outage for about 45 minutes a few days ago. Ever since then the Powerware 3110 has been beeping. I turned it off and left it plugged in overnight and when I turned it back on the beeping...
This could be several things, fortunately the device should actually be helping you to diagnose the issue. There are different beeps for different issues. They are as follows:
1 Beep Every 5 Seconds = Power Outage\Loose Plug Connection\Tripped Circuit Breaker\Power Cord Damage or Failure
2 Beeps Every 5 Seconds = Low Battery Alarm
3 Beeps Every 5 Seconds = Battery Needs Charging\Service\Replacement
3 Beeps Every 5 Minutes = The Battery is discharged and battery power is unavailable (If this continues battery replacement may be necessary)
1 Beep Ever 1/2 Second = Power Requirements exceed the UPS Capacity (remove some equipment to lighten the load on the unit)
Continuous Beep = Short Circuit / Input Voltage out of Range / UPS Fault (Likely replacement of entire unit)
That should help diagnose the actual issue. If it turns out the battery needs to be replaced they can be found online for around $20. A simple google search for Powerware 3110 Battery should return what you're after. Good luck!
May 05, 2011 | Powerware 3110 UPS System
Good afternoon The system has a red light flashing constantly and is emitting 3 beeps every thirty seconds. Thanks for your help.
The battery in your UPS needs to be replaced. You can contact the manufacturer for a replacement battery -- depending on your warranty, they may replace it for free.
http://powerware.eaton.com/Products-services/Backup-Power-UPS/3105.aspx?cx=3
Mar 17, 2011 | Powerware 3105 500i (0790341043681) UPS...
Need to locate someone to install batteries into our UPS Powerware 2000. Location, Tempe, AZ (Phoenix, AZ)
Try contacting Eaton. They bought Powerware about 6 years ago and the personnel are trained on older Powerware systems. If you have the part number and serial number from the rating label on the UPS, that would be helpful.
Toll Free: 1 800 356 5737
E-mail: SinglePhaseTS@eaton.com
Nov 24, 2010 | Exide /Powerware PowerWare 2000 UPS...
Sound skippes when ever playing a dvd or an aduio file
if you have dell datasafe installed in pc, kindly update to latest version of dell datasafe.
if no dell datasafe installed, upgrade firmware for your optical drive from suppot.dell.com
download and run piotodma.exe from support.dell.com
Jan 29, 2010 | Dell OptiPlex 760 MT Desktop Computer
Replacement fans for powerware 9120
A good electronics supplier should have. Get the correct voltage and size, and get one with the largest CFM available.
Oct 01, 2009 | Powerware 9120 UPS System
Bad zener Powerware 5125-1500
There may be a reason. Too much current draw.
I would recommend to get a better brand UPS.
Sep 09, 2009 | Powerware Computers & Internet
Powerware 9120
Greetings!
How many years is your ups working? UPS is usually run by a battery, some of them are disposable and needs replacement. If it does not charge anymore it needs replacement of battery.
Thanks.
Nov 06, 2008 | Computers & Internet
Powerware 9120. 1500i UPS
You can download the manual and other literature at
http://www.powerware.com/EMEA/UPS/9120_info.asp
The contacts for support in India are found at
http://www.powerware.com/India/Service_Support/IN_Office_Contact.asp
They offer a battery monitoring software package, at
http://www.powerware.com/India/Service_Support/IN_Battery_Services.asp
You can email support at http://www.powerware.com/pp/Check.asp?key=code1
Good luck
Feb 20, 2008 | Powerware 9120 UPS System
Powerware 9330 40 (A40401110031112) UPS System Logo
194 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
