Question about Whirlpool Washing Machines
The washer will run fine but about 15 minutes into the cycle water starts leaking from the bottom of the machine. I don't know exactly where it is leaking from, but it doesn't seem to be coming from the drain tube. Do you have any idea of what the problem could be?
  • 1,606 Answers
If it consistently leaks during the spin cycle, the first place to check is the pump and the drain hose connection to it.
However, most of the time the leak is in the tub bearing. Look for signs that soapy water has been running off the top of the transmission. Letting this continue will eventually damage the clutch or transmission, so set aside a day for tearing the machine apart. If you purchase a bearing replacement kit, don't forget to check whether you also need to buy sealant. This is not ordinary caulking compound; so follow the manufacturer's specifications.
Another possibility is a leak from the water level sensing port or tubing. This is unlikely because then you would also have problems with overfilling.
Posted on Nov 12, 2010
My Miele W1119 washer won't run. It was fine earlier today and I just completed a load of wash. When I started the next load on the Normal cycle, the timer lights to 58 minutes as always and the...
sounds like bushes mine done the same changed them now all good check it is not leaking water on to the bottom of machine this will activate the sensor to stop washing and drain water
Jun 04, 2017 | Miele Touchtronic W1119 Large Capacity...
2002 Maytag mah5500 leaking water onto motor. Have checked all hoses and bellow where they attach and they are dry. A small mirror appears to show water leaking down from clearance between tub and motor
Find out where the leak is coming from. Does it leak constantly or during one The other two options are when the washer is agitating or pumping the back or front will come off so you can observe where the leak is coming from. WARNING. You are working with a moving, electrically hot machine that could flood. You must take your time and not put your hand or hair in somewhere that can catch you. You should not have to get into the upper control center, thus reducing the shock hazard.
Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose. Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.# There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc. Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits. Most likely, you won't find standing water, but some clues of where you should look when the machine is running. Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem. Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak. WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on. Stay clear, and watch your hair and hands. Once the machine is full and starts its cycle, look for leaks. Let the machine do its cycle and as it goes into each part of the cycle, look for the leak. Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely. Remember, water runs down; where it drips is not necessarily the place of origin.
Find the leak and make the needed adjustment (which will be all that is necessary most of the time). If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
Regards.
Jul 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
I recently found that my washer is causing a leak, only on the first drain cycle. The second drain cycle is fine. I thought I had a plumbing problem with the drain, however after snaking it and using ...
The most common leak point for this machine is at the center tub seal. Remove the front panel by removing the screws from the bottom of the front panel. Look at the bottom of the tub, directly in the center. See if there are any water marks around this seal or around the inside of the cabinet. If there is, this is a pretty intense repair requiring specialty tools, so you will likely need to call in a servicer. This typically runs about $300 or more to repair.
Jan 13, 2011 | Maytag LSE7806A Top Load Stacked...
My duet washer leaks from the bottom....i do not know what cycle it starts....but by the end of the wash...water accumulates at bottom
It is probably too new to be a cracked hose (but that is possible). More likely, it is a loose fastener on one of the hoses (connected to the water pump). You could remove some of the cover - just enough to see the pump in the bottom cavity of the machine. With a flashlight, you should be able to spot the exact cause of the leak - then let up know what that cause is and we can provide guidance on repairing it.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water from the bottom
take the back cover of ,first check if all the water hoses are tighten,if all tighen then its leaken around the motor area might need a new motor or gasket ,check it when its running so u knw where exactly the leak is,for more info let me know,if my info was of any help to you please leave a comment,thank you.
Sep 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
About 1 minute into the cycle water starts running out from underneath of the washer. Checked all the hoses that are connected to the back and none are leaking
this is either the front seal that goes from the outer tub to the front of the washer or a hole in the outer tub itself or one of the hoses underneath the seal and the hoses are easiest to check you can take a cup of water and slowly pour it into the front seal. take care not to overfill it to where it spills into the tub and see if you are getting water on your floor from that. the hoses tip the washer up onto its back and look at them from the bottom for any cracking etc. the tub itself can only rust out on some of the neptune models or on others is plastic and can get punctured. just have to look for damage with a light and a mirror.
May 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Ultima WF840 won't go from wash to rinse cycle
the pump is blocked, so the sensor detects that the machine has not emptied in the allocated time, so this will reset the time.... the pause is because it knows there is a probblem getting rid of water.
location: bottom right near the motor. ensure you tip the washer as far forward as you can so you can get a bucket under in order to prevent flooding.
hope this helps
Aug 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Leaking water
Possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine. Also use only detergent for 'front loading machines'.
Oct 07, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal De
