Question about Seagate ST1.2 ST68022CF 8 GB ATA-33 Hard Drive
The computer is not detecting my seagate 8 gb st1.2 drive. sometimes it identifies as a f: removable drive but when i click it takes a long time to read and flash the message that" please insert the disk". I can hear the sounds like "clunk clunk" but nothing . How can i retrive data out of this drive. thanks.
  • 1 more comment
  • mnawaz Nov 12, 2010
    The problem is i can't access the drive. I can hear the sounds of probably its spinning ,but it dosn't show up, and when it does it shows nothing. What is the best possible way of retriving the data out of it.
    i have that drive connected to my windows 7 machine. You are asking me to reboot it thru a bootable CD? why?. I can bring up the machine fine with normal boot. The drive is not my primary its a external drive.
    Its an external USB Segate 8gb st1.2 drive. That's the problem its not a main hard drive of my computer and i cannot access it connecting it to the windows. Occationally it shows as mapped to F: Removable Disk. But when i click it it shows nothing and gives the message as "Please insert the Disk".
  • 12,061 Answers
That "Clunk Clunk" sound" you hear is the death rattle of a drive, sorry, I have experienced this many many times.
Generally they cannot be easily fixed. One can try to get an exactly the same drive and remove the Motherboard off a Brand New drive, and replace the MB, on the "Faulty" drive, if the board is your problem, You must be prepared to "Blow up" that new board too. If sucessful, then usually it will, "just work" as it was before. If it is the drives "internals" There isn't much more one can do.
If one cannot "Mount" or "See" the drive, then there is no way to retrieve data, if it can be mounted, then there are a number of programs on the 'net, freeware, to do this for you, simply Google, HDD data recovery, and take your pick.
If however the data is imperitive, there are places, that for a price, will recover the data 100% guaranteed.
But with these tiny HDD they are very easily damaged because the tolerances are so small,and when they are again because of the size they are difficult to work with.
Posted on Nov 13, 2010
  • 4,281 Answers
Your harddrive has bad sectors you need to fix it first. Connect your harddrive to computer where windows was loaded. then if you are able to access harddrive in windows then take bakup first. After take bakup you can format it then it will work again. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Nov 12, 2010
  • Yes for that you need to connect it to computer where windows loaded.
    If you unalbe to access that on another computer.
    then you need to boot computer with bootable disk then run disk manager tools of seagate then fix the bad sectors then you can use it again.
  • Is it SATA drive or external usb drive?
Seagate backup plus is beeping and will not pull up on computer??
Troubleshooter: Seagate Manager does not see my Seagate FreeAgent drive Troubleshooting in case the Seagate Manager cannot detect the FreeAgent drive.
Sometimes, Seagate Manager (the software bundled with newer FreeAgent drives) does not see the drive.
This article focuses on drives that can be seen in Windows, but are not seen in the software.
If you are using Windows 8, please note that Seagate Manager is not supported in Windows 8, so you will need to use a different backup solution.
If the drive is not detected in Windows 7/Vista/XP, then use the external drive troubleshooters to try to resolve the non-detection issue.
After connecting the FreeAgent drive, please give it up to 1 minute to display in the middle of the main screen in Seagate Manager.
If the drive does not display, open My Computer (Computer for Vista) and confirm the drive is listed there. The drive should be listed as "FreeAgent Drive". If you have formatted or renamed the drive, then it will show up with the name you provided.
If the drive does not display in My Computer (Computer for Vista), use the External Drive Troubleshooter to help resolve that issue before continuing.
If the drive is detected in Windows, check if the Seagate service is running.
  1. Right-click on the My Computer (Computer for Vista) icon.
  2. Choose Manage.
  3. In the Computer Management window, click Services and Applications.
  4. Open the Services area.
  5. Scroll down the Seagate Service (they are listed alphabetically).
  6. The Seagate service should display Started in the Status column.
    If it does not, right-click on the service and choose START.
  7. If the service reports as Disabled, enable it to start automatically.
    To do this, right-click on the service. A Status Type drop-down menu will appear. Click on the General tab. Select Automatic and click OK.
  8. Reboot the computer.
  9. If the service fails to start after you reboot with these settings, then check the logs of your Antivirus or Antispyware software to confirm they are not restricting the startup of this service, as some aggressive protection programs can prevent services from starting until you approve them. So, you may need to approve this program specifically in the Antivirus/Antispyware software. Please contact your anti-virus software support for help.
  10. If the service will not start or is working already, uninstall the software (for steps on uninstalling the software, see this article).
  11. Once the software is uninstalled, reboot the computer.
  12. Then reinstall the software by opening the InstallSeagateManager.EXE file on the FreeAgent drive. If you have removed the software from the drive, it can be downloaded from the download center.
  13. If the drive is still not seen by the computer, connect the drive to other USB ports on the computer.
    Some eSATA cards block the drive's identity and prevent it from working. Updates have been made to Seagate Manager and to some vendors' eSATA drivers to help this issue. See our eSATA tips article for details.
  14. If the drive still does not display after these steps, please contact Technical Support.
Check Required Windows Component Installations
1. Check to make sure you have the MSXML Parser 6.0 installed:
  • Open Control Panel
  • Open Add/Remove Programs / Programs & Features (Vista)
  • Check box for "Show All Updates"
  • Look for "MSXML Parser 6.0"
If this is not found, visit Microsoft's website to install this component: http://www.microsoft.com/downloads/details.aspx?FamilyId=993c0bcf-3bcf-4009-be21-27e85e1857b1&displaylang=en
2. Make sure Microsoft .Net Framework 3.5 installation
  • Look for "Microsoft .NET Framework 3.5".
If this is not found, visit Microsoft's website to install this component. 3. Try the steps listed here.
4. Remove the Seagate folder from C:\Documents and Settings\All Users\Application Data (XP) or C:\Program Data folders (Vista) and reboot.
5. Download and install the newest Windows Installer.
6. Download newest Seagate Manager from our Website and re-install a clean copy. Note: Do not do the update when the message pops up saying one is available.
Jul 24, 2014 | Seagate Backup Plus 500GB 2.5" Blue...
No detection or read in Windows XP
Sounds like a hardware failure on the drive, Dont know what to tell you there, you WILL spend money to retrieve any data.
Jul 08, 2007 | Seagate ST1.2 ST68022CF 8 GB ATA-33 Hard...
Seagate Expansion 1TB external Desktop Hard Drive (9sf2A4-500) not detected.
Claire,
Have you tried connecting the drive to another computer using Windows 7 or later. You could try chkdisk /f at a command prompt or get the testdisk app to identify deeper issues with the drive.
Chappo07
Oct 24, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My hard drive can't be detected by device manager. All it does is blink and make a weird sound each time it blinks. What should I do?
good day.....seems this tips can help you...trace the sata cable if properly connected...but i'm sure the ticking sound is an indication of defective hard drive...inside the hard has a mechanical arm that goes up and down...this arm read the data..... it's better if you buy a new one....
Feb 13, 2011 | Seagate (ST9100801U2-RK) (9W3638556) 100...
My portable HD detect pc, but no driver found and cpould'nt open
If it shows up in my computer then just double click on it as you would the C drive or dvd or cd it should put the driver in already if it is showing remove safely sometimes it will require a reboot after it is installed
Jul 07, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate 500 GB freeware pro window xp will not reconize the drive,rapid blinking ,signal on the outer...
TRY THIS
RIGHT CLICK ON MY COMPUTER
SELECT MANAGE
CLICK ON DISK MANAGEMENT
IDENTIFY YOUR DRIVE
RIGHT CLICK AND FORMAT
QUICK FORMAT.
PLUG OUT
PLUG IN
NOW IT SHOULD READ]
Jul 06, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hard disk not detected
The problem is that u have done partitions for 160 GB harddisk, so do all the partitions of 40 GB or less than that.
Sep 24, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
You could try to download and install FTK - Forensic Tool kit to grab the info. But sadly if the memory won't detect, your looking at having to use expensive software/hardware to grab the info.
Seagate ST1.2 ST68022CF 8 GB ATA-33 Hard Drive Logo
113 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
