Question about GPX PDL805 Portable DVD Player
When is the battery charged?
There isn't anything in the instructions that explains this. Is it when the red light on the battery turns green? Does it turn green? Will the red light go out? Thanks!
  • Anonymous Jul 14, 2008
    I have the same problem. Can anyone help. The manuel shows nothing about charging.
    Sergeant:
  • 284 Answers
These small dvd player are built with less options
normally with cheap batteries, so usually it will turn green when fully charge or even turn off. hard to say. but since it cheap batteries, it probably wont do anything at all.
i would charge it for 10-14 hours then unplug the device.
the battery will get hot, and then the device will no longer work after over charging the player.
so charge for 10-14 hour only UNPLUG the player
play til it dies then start process all over again.
if you find that the battery is dying faster and faster then you have a cheap battery
theres no easy fix for this, some battery cannot be interchanged
when buying something make sure you can exchange the battery like a laptop. this way if the battery is overly charge it doesnt leak into the player.
or into the device
Posted on Aug 16, 2008
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
Lost Dynamic Falcon Mini Copter Manual/Instruction. What Does Flashing means while charging and why the green light isn't on?
The flashing red light means the batteries are low. The green light goes off when it's finished charging, or when there's not enough battery left to charge it.
Dec 21, 2010 | Atlus Video Game Consoles & Games
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
When I plug my Motorola H710 bluetooth in to charge the light only blinks red and when I use it it never seems to turn on?!
Here's the instructions for charging.
Plug the Motorola charger into the end of
the headset.
The indicator light turns red when the battery is charging. It may take up to 1 minute for the indicator light to turn on. When the headset's battery is fully charged (about 2hours), the indicator light turns green.
From your information, it may very well be that the battery should be replaced if the red light doesn't go off as it should.
Here's a link to the full instructions. I hope this helps.
(Click here)
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H710%20QSG%20EN%20Generic.pdf
Feb 06, 2010 | Motorola Mobility H710 Bluetooth Headset
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Lights on Rechargable Lantern.. Swissgear SG66301
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Nov 03, 2009 | Kitchen Appliances - Others
BATTERY CHARGER RADIO SHACK DELUXE 10 CELL
I would go to Radio Shack and have them explain the proper charging procedure as well as inquire about the red and green lights as not all chargers go green when fully charged-Normally red indicates a charging action and if a charger has no fully charged light, then a required charge time period is noted in the instructions. Batteries can be ruined by over charging!
Jan 03, 2008 | Energizer Rechargable Battery with Charger
GPX PDL805 Portable DVD Player Logo
179 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
