Question about Panasonic PT AE200 Multimedia Projector
Just picked up a old PT-AE200E as a freebie and while the lamp works (~3000hours on the clock), the picture is basically yellow and black but in an oddly negative look (ie. what should be white is displaying black and most of the rest is in shades of intense yellow). I'm hoping its just a case of a fresh lamp but don't want to fork over the cash without a better idea of the problem, Cheers in advance :)
  • 579 Answers
SOURCE: Panasonic PT-53wx42 has a greenish/yellow tint to it.
Trty re-soldering the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it.
Posted on Jan 02, 2008
SOURCE: panasonic PT-L759U
This also works for a Panasonic PT-LC50E LCD Projector.
Posted on May 26, 2008
  • 4234 Answers
SOURCE: How do I rest the lamp times on my DLP TV Panasonic PT-56DLX75/PT
The reset procedure is usually documented in the owner's manual. But if you can not locate that, please update this with the model number of hte set and we'll get that info for you. Please note that the procedure is relatively simple, but dependent upon the model number.
Thanks,
Dan
Posted on Feb 05, 2009
  • 34 Answers
SOURCE: PT-53TW53 53 in. Rear Projection has sound but no picture
It is. And I hope you some cash set aside for this extremely costly repair.
I once had a rear projection TV and was told by the repairman that each of the 3 flourescent lamps run about $200.00 to replace.
Needless to say I did not get it fixed
Posted on Oct 12, 2009
  • 3 Answers
SOURCE: Side BY Side Picture On TV Black And White
My mother-in-law sent me her unit with the same problem. The problem i had was you couldn't really read anything on the screen in the setup menu. I finally got lucky and got in the right menu and set everything to default settings and it went right back. Here are the steps to reset it without reading it.
1. remove all tapes and discs
2 if your unit scans for channels when you turn it on press return once
3.if it doesnt go to channel scanning you should have a blank screen
4.press the functions button once
5.press down twice
6.press the enter button
7.press the enter button again
8.press down once
9.press right once
10.press down 4 times
11.press enter once
12.press up once
13.press enter once and the double image should be gone
14. press the functions button twice to exit
hope this works for you
Posted on Feb 06, 2010
How to know if HC5000 lamp is out
Lamp timer mean nothing in the end its just a light bulb and can go at any time.
Dec 05, 2011 | Mitsubishi HC5000 LCD Projector
I need a user manual for panasonic pt-ae200e
I can email you this manual. It is 34 pages. Please send email to LBrown18062@hotmail.com Please put PANASONIC PT-AE 200E in the subject line. I will send it to you right away.
Oct 16, 2011 | Panasonic PT AE200 Multimedia Projector
I have a panasonic pt-60dl54, the sound works but green picture
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.You will need to replace the DMD board. Have a blessed one!
Apr 13, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Oct 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Replaced lamp; still have no video yet have audio
Did you replace the lamp because the picture went out (black)?
May 21, 2009 | Panasonic Televison & Video
I cannot reset my lamp clock
http://answers.yahoo.com/question/index?qid=20080221185527AAvGCui
I just now replaced my lamp and tried the solution on the above bookmarked site (hold down VOL- on the TV itself while holding down the SPLIT button on the TV remote simultaneously for several seconds... I didn't need all 20 seconds that this site recommends), and that worked for me. About 5-10 seconds in, I saw a blue box on my screen that basically said "Lamp timer has been reset to 0" with an "Exit" box below that. It took me a while to find the "Exit" button on my remote control to clear that box off the screen, but that's how I cleared it.
My TV is just short of 3 years old; I bought my Panasonic PT-52LCX65 on "Black Friday" (day after Thanksgiving) in 2005. My lamp died last Saturday night.
Hope this helps! -- ChuckE
Jun 06, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT 50LC14 problem
You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
Feb 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-53WX42 - When I turn the TV on, the red light comes on but, no sound or picture.
Does the light blink? If it is blinking a 3 code, the IC's need to be replaced. Those three lamps as you called them are not lamps, they are the three picture tubes.
Jan 08, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic Rear Projection TV -dark picture
Javabean,
First off I think you meant Panasonic PT-51G44A which is an AP815 chassis. That unit has an all to common failure of the capacitor at C581 on the D board which is a 33uf/160v cap. Replace it and I think that will solve the problem..
Bill
Dec 11, 2007 | Televison & Video
Panasonic PT AE200 Multimedia Projector Logo
51 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
