Question about ATI RADEON 9000 Pro 128MB AGP DDR with DVI&S-Video (Retail Box) Graphic Card
I have no DirectDraw, or Direct3D or AGP Texture acceleration
    Genius:
  • 1,672 Answers
Download the driver for that video card in the ati.com and it sure will work! Taah!
Posted on Nov 12, 2010
I install direct x 9.0 on dell latitude before now i can not install now why
My solution was when I wanted to play terraria I googled and found I needed a driver for xp pro I'm running 7 tho and install in compatibility mode. Worked for me
Aug 24, 2012 | Dell Latitude D610 Notebook
My direct3d , directdraw , agp texture accelerator are showing not available in my dxdiag.
Actually you have not installed drivers for ATI Radeon 7500. Just download and install updated drivers for this hardware. If you can't locate the specific drivers then use a driver scanner tool to locate specific drivers for this hardware. Also use a system utility tool like PCFresher to fix windows and registry errors. It will also fix missing dll files.
Apr 25, 2012 | Computers & Internet
I had download project igi and it is showing that no d3d driver with acceleration
try
open start menu, then open run, then type dxdiag, on directx files tab
look for d3d8.dll or higher, if you can't see it then you need to install some drivers but before that
you need to go to display tab, then look for directx features see if the directdraw, direct3d, and agp accelecation is enabled, if not, minimize the directx diagnostic window, goto desktop , right-click select properties goto settings, adjust the resolution to 800x600 or higher, then change the color quality to highest 32bit, or higher, just don't do 256color bad quality it will disable the d3d,
then back to directx diagnostic windoow check again then test the directdraw and direct3d,
if it don't work you will need to update your video card driver, or buy a new vga card, with d3d capabilities, the higher the better,
note: some card may not be compatible with your board so try to google first for compatible parts
by korotchan
hope it help
Jul 08, 2010 | Eidos Interactive Project IGI: I'm Going...
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
May 14, 2010 | Yahoo Messenger
Dell Precision 450 new Graphics Card problem
drivers vga.dll version 5.01.2600.000(english)date 2/28/06 04;00:00 whql logo'd:yes mini vdd:vga sys vdd:n/a ddl version:unknown directx feture directdraw acceleration:not available direct 3d acceleration: not available agp texture acceleration :not available teste draw test direct3d the system is using the generic video driver please install video driver probided by the wardware manufacture. directdraw test result:all test result: all tests were successfull: direct 3d funtionality not available.you should veryfi that the driver is final ;from the harware manu facture. ram 512 mb storage capacity 160gb raid no graphics card:intel graphic media accelerator 900 gm primary optical driver dual-layer dvd+/-rw
Dec 03, 2009 | 3Dlabs AGP Video Cards: Wildcat VP560 64MB...
Direct 3D Driver Installation Or Reinstallation?
The HAL error is because you haven't installed your grafikcard so windows is using a defaultdriver. You need to download the drivers for your videocard.
I can't say what card you have, for that you have to read the productpaper that came with the computer or open the pc and check the card.
Most graficcards have either nVidia or ATI chips. Intel is the brand on your CPU (and some other stuff) but they dont do their own graficcards.
My advice:
¤ Check the manual/documentary of the computer and look for the type of card you have for your grafics.
¤ If you can't find it in any documentation. Open the computercase and check the cards for any card with a logo from either nVidia or ATI.
¤ When you find the correct card. Check for the name of the card. (could be ATI HD5670, or anything like that)
When you have all info on what card you have. Go to either nVIdia or ATI driverpage and select your card and download/install the driver.
Restart computer hand it should be fine.
Btw. at http://free.grisoft.com you can download a free version of AVG Antivirus. So you don't need to worry about staying connected.
Cheers and hope this will help.
Sep 15, 2009 | Compaq Evo D510 Minitower (Open Box)...
DirectDraw and Direct3d Acceleration Problem
This problem happened to me when I was installing halo pc. Its not fixable so what I recomend is that you take all of your files, pics, ect. and put them on a hard drive or flash drive and start over on your computer. I had to do that because the direct x 9 got corupted and I was not able to fix it. Now that I completely formated my computer, I am able to play halo and halo 2.
Jan 16, 2009 | Microsoft Windows Xp Home Edition Sp2...
Directdraw Acceleration no available (Disabled)
The same problem happened to me and following procedure solved it;
Goto Diplay Properties->Settings->Advanced->troubleShoot. On that window I saw that the hardware acceleration was set to None. I made it Full. And now dxdiag should show all options enabled..
Mar 31, 2008 | Microsoft Windows Xp Home Edition Sp2...
Monitor
you wont have any of these if you have onboard graphics, to get graphics with rendering and 3D texture you will need to fit an AGP graphics card and dissable on board graphics.
Sep 02, 2007 | Asrock P4VM8 Motherboard
Computers & Internet Logo
150 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Tony
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
