Question about Canon PIXMA MP150 All-In-One InkJet Printer
Dear Adviser The Canon cartridges for my Pixma MP140 printer have run out of ink as indicated both on the printer by the E4 signal and on the computer by a pop up window when trying to print a document. I decided to refill both cartridges using a refill kit supplied specifically for Canon cartridges. The refilled cartridges were reinserted into the printer and after switching on the printer the E4 signal reappeared. Hence the printer was not recognising that the cartridges had been refilled. I was advised to Google ?Chip reset for Canon cartridges?, the objective of which is to reset the chip on the cartridge which reads the ink level in the cartridge. I came across the Maynard method which I applied but only got as far as step 4, at which point the fault light starting flashing and I could not get beyond that step. I got the impression from the description of the Maynard method that one starts with nearly empty cartridges to reset the chip(s). After the resetting process the cartridges are removed then refilled (Step 10) and after reinsertion, the printer should recognise that the cartridges are full. However I am BEGINNING with refilled cartridges. Does anyone know a procedure for resetting the chips where we are beginning with a refilled cartridge?
  • Canon Expert
  • 231 Answers
Hello, the printer Canon Pixma MP140 has cartridges with no chips. The printer reads the serial from the cartridge and tells you an estimated ink level. My recomandation is to press the resume/cancel buton for at least 10 seconds, that being the method to cancel the ink counter. After you press the resume/cancel buton you will be able to print, scan and copyas you did before.
The only disadvantage is that your printer will never show the ink level for this set of refilled cartridges, but it will work as well as brand new cartridges.
Posted on Nov 12, 2010
Testimonial: "Thank you for your suggested solution. It was simple and above all it has solved the problem that I had with my Canon Pixma MP140. Thank you again."
  • 1 more comment
  • ahviste Feb 08, 2011
    It seems,with my Printer is a little bigger problem. Absolutely nothing cant solve this E5...
  • Marius Chiriac Feb 09, 2011
    If E5 is the error you will have to replace the color cartridge.
  • ahviste Feb 09, 2011
    Changed many times. This Printer is a ****.Something has happend with Canon.All products i have, ended Contract ca. after Year.
    My MP 140 can recognise 1 Cartridge.No matter,Color or Black.If I insert both ,appears E5.
    It seems like some Electronic problem inside.
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP140 - c light flashing
This means you are getting low on color ink. You can continue printing for a while, but eventually you will get an error message (E,4) indicating that the ink has run out. Purchase, or have ready, a new color ink cartridge.
Feb 20, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
It's a Coanon A.I.1 printer model mp140 i've
E4 is a ink empty error.There is a memory in the cartridges and printer still recognize it like empty.You need to turn off the function on printer to show the ink level.Push and keep the "resume"button for 5 seconds.
Oct 05, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Error 4
The error code E4 indicates that ur printer is low on black ink if ur getting this error error code then u need to replace the blak ink cartridge. Hope this solution will solve ur prob
Jul 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My canon mp140 keep on flashing E and then 2 whats the problem
e2 is no paper, E3 is paper jam, E4 is no ink, E5, wrong ink, E8 waste ink absorber full
Jun 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My canon mp140 shows E4
From CANON FAQs for your printer:
Issue: ERROR LED: E, 4
Solution: Press and hold Stop/Reset button for at least five seconds.
Clearing the Ink Error If you want to continue printing in this condition, press and hold the <Stop/Reset> button on the printer for at least five seconds, and then release it. Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Apr 01, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
594 people viewed this question
old marine
old marine
