Question about Arnold Corporation Garden
Arnold snow thrower light#490-241-0009 What is the voltage, wattage and base type for a replacemant bulb, since the company does not state what the replacement is?
boscia
  • 163 Answers
SOURCE: snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Posted on Dec 13, 2008
  • 10865 Answers
SOURCE: snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Posted on Jan 23, 2009
  • 2976 Answers
SOURCE: Snow Thrower does not self-propel
Did you check under the handle area, near the blower itself for a transmission lever? This will engage & disengage the transmission.
Posted on Jan 31, 2009
asnowman
  • 788 Answers
SOURCE: the light bulb burned out. I do not know what type
According to GE this uses a 40 Watt appliance bulb. You should be able to get one from any department or home improvement store.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
I try to give the best FixYa experience.
Posted on May 03, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Need to replace the surface light in GE JVM1490BD 003
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Or you can find helpful exploded view diagrams and order parts by entering your full model number here.
You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Posted on Jun 28, 2009
Fuel filter on snow blower
Howdie what do you need to Know About it ?
Feb 13, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Craftsman Snow Thrower engine spews balck smoke
the choke is stuck so remove the cover and look for the choke to see why it,s not movin
30 in craftsman snow thrower,model no.247.883960,pulls right contionusly while operating in any gear
Howdie ther is a Pin in the shaft of the wheels look to see if it is Broken and away ya go it is easy to see
Feb 07, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Snow thrower backfires and stalls
sounds like carb needs cleaning or plug changed
id do both
Jan 30, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Snow thrower
you need to thin out your mixture on the carb. should solve this.
Setting valves on craftsman snow blower model 536.8818000
Howdie what year is it ?they should set them selfes but only do you have to set them if it is nut adjust then goto the dealer for the spec,s
Jan 11, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
I just bought a Sears snow thrower, I put in oil and gas went to start it but the pull cord will not pull up. I then tried the electric starter but it just made a grinding sound. Why won t it start?
Check the crankcase and make sure it has oil. It sounds like the engine is frozen. If its brand new, take it back to Sears and have them start it for you.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Snow thrower not starting
Two ways to find out:
1.
2.elctric
start with elctric, take the plug cable out and see if have
https://www.youtube.com/watch?v=mUOmsGiirTU
if you have spark go to fuel :
change the old fuel to a fresh one.
https://www.youtube.com/watch?v=RfzzTilqwo0
Dec 13, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Craftsman 32" 10 hp
3600+/- 20rpm. That's the top end, I'd say idle should be between 1200 and 1500, but I don't know what model motor it is. I'm assuming its a Tecumseh snow king engine
Nov 22, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Craftsman 32" 10 hp snow thrower
Around the back of the engine, just below the cylinder cooling fins. The shut off should face you if standing in front of the recoil starter, for the fuel tank. The fuel line should wrap around I the side of the carb and be protected by the metal cover surrounding it.
Nov 20, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Garden Logo
267 people viewed this question
Top Arnold Corporation Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Arnold Corporation Garden Expert? Answer questions, earn points and help others
