I am looking for a Coleman Manuel on Coleman Presidental iii 7900 Series Furnace
    Genius:
  • 1,015 Answers
You can go to google and enter name and model number and request manual. The last time I did that they charged me 15.00. Sorry i'm not more help but I have not been able to find a free download. Thank you
Posted on Nov 12, 2010
Coleman 7900 Series Furnace. Fan comes on first then blower comes on. This is backwards.
combustion fan comes on first the blower comes on when it gets to temp so it can blow hot air ?
Dec 07, 2016 | Heating & Cooling
Do I need a outside cooling unit for a Coleman 7900 Presidential lll gas heat and cooling unit
Yeah, youd have to look at the model on the Indoor coil box, furnace will be setting on top of it. Youll need the model off that coil box to get the correct tonnage of the outdoor condensing unit, you can go 1/2 ton smaller on outdoor for greater efficiency.
Feb 12, 2015 | Coleman Heating & Cooling
How to light the pilot on a 7600-800 series presidental 11 furnace
WHY DID THE PILOT GO OUT TO BEGIN WITH? WHAT TYPE OF FUEL? IS IT SEALED COMBUSTION? IS THE GAS ON?
Dec 27, 2012 | Heating & Cooling
Makes a noise, but the fan does not turn, it spins
I was told to change the capacitor on the blower motor and that solved my problem.
Jul 21, 2010 | Tools & Hardware - Others
It wont lite, how do you lite the pilot, where is it located, do you have a manual i have a coleman presidental 3 furnace
There is a window directly above the gas control valve. Either a spring held latch or a screw off cover need to be removed to access the pilot. To light the pilot, turn the knob to pilot and hold down while lighting pilot. The pilot in straight back inside the hole about 10 inches. Use a long fireplace match or rig a wire to hold the match. Once the pilot lights, hold the control knob down for about 30 secs., if it stays lit after release, turn to "On" and operate normally.
Dec 13, 2009 | Tools & Hardware - Others
Furnace not cycling properly.
you might want to check the filter, if the filter is restricting the airflow the furnace will over heat and it will shut down. if you turn it off and on it will reset it and it will try again. Pull the filter out half way and try that, if it runs fine then clean the filter or get a less restrictive one.
Feb 06, 2009 | Coleman Propane Forced Air Heater...
Pilot light is out of our coleman 7900 mobile home furnace and we can't get it re-ignited
The thermo couple or the gas valve itself is most likely bad. Cheap enough to start with the thermo couple.
Sep 04, 2008 | Coleman Heating & Cooling
Mobile home furnace
you probably have a bad thermostat if it wont shut down id replace the thermostat first and then have the thermocoupler checked...replace the thermostat
Aug 20, 2008 | Heating & Cooling
Coleman 7900 gas furnace/central ac, was working fine, now blower wont come on, it tries but turns real slow then stops, i took it out and bench tested the motor andit works fine, put it back in the...
Motor run capacitor. If problem is intermittent, try wiggling wires from motor to capacitor to check for broken wires. Motor might seem to work ok with no load on bench but it has no real power. The power to really spin the motor under load comes from the capacitor
Jun 29, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
