Question about Ricoh FW870 Black and White Copier
Need a fw770 wide format drum - Ricoh FW870 Black and White Copier
  • quennie732 Nov 15, 2010
    BIG job why are you replacing the drum? -Carl
Switching on the machine XEROX MODEL 6030 WIDE FORMAT an error appears '003-302 please reboot' after rebooting the machine the error still remains SOLUTION Required
Hi Shahab,
Have you looked inside the printer to see if you have any media or sensors blocked or torn media stuck inside.
Don't leave the lid open too long or your drum might get light shocked.
You need further investigation on this problem.
As the problem occurred several days ago I assume you might have it fixed by now.
Good Luck.
Apr 22, 2015 | Xerox Office Equipment & Supplies
Line appears on copies from top to bottom of the sheet, Approx 7 7/8 in. It happen both off the glass and when ripping a job to machine
With lines showing up with both coping & printing, you are most likely need a general cleaning and if that will not work, odds are you are going to need a new OPC drum & drum cleaning blade and a new developer change..... Good Luck
Nov 09, 2012 | Xerox 8830 AccXES N5T Wide Format Digital...
Gestener 6123 Copier Printer Paper is sticking onto the drum, how do l solve it
I will need more details from you.There is a drum unit in there and a fuser unit that might look like a drum. ans normaly the paper sticks to the hot roller in the fuser, if the lead edge is solid black
Jun 14, 2011 | Gestetner - AO40 Wide Format Copier Copier
We have a ricoh FW770 that keeps leaving toner on the print, we have to keep cleaning the drum in order to get a good copy
probably you need to change the drum cleaning blade. Its a long silicon rubber stripe that cleans the excessive toner from the drum surface.Also replace the developer units seals to prevent the developer and toner leak.
Hope that helps.
Mar 22, 2011 | Ricoh FW870 Black and White Copier
I HAVE A RICOH FW770 PRINTER THAT HAS BACKGROUND IMAGES, STREAKS AND SOME SPOTTING FROM THE DEVELOPER. THIS STARTED SLOWLY AND HAS GOT WORSE DAILY. I THOUGHT THE CARTRIDGE WAS BAD AND REPLACED IT. NO...
First of all the machine requires regular service.
The approx life of certain parts are as follows
Drum : 50000 copies(A1 size )
Developer : 20000 copies(A1 size )
So please check how many copies your machine has done , so that you know what you need to replace beforehand.
About the cartridge, before using it ,shake it well and make sure the gear at the end is turning properly.
Life of the toner is approx 1800 copies(A1 size ).
Jan 27, 2010 | Ricoh FW870 Black and White Copier
I have just purchased a 2nd hand Ricoh copier model 2022 and there was no manual. Would you happen to know of a web site I can download the manual. Many Thanks Warren
please download manual from below link :-
http://www.devicemanuals.com/guide/Copier/Ricoh/Ricoh-Copier-Wide-Format-FW770-User%27s-Guide-TXpBNU5EUT.html
or
http://safemanuals.com/user-guide-instructions-owner-manual/RICOH/AFICIO%202022-_E
Thanks
veeru
May 09, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
We have a Ricoh FW770 large format copier which leaves toner speckles on the sheet. What is the problem? We have replaced the toner cartridge as well as the recovery blade but still these spots of toner...
There could be some corona wires in there that are built up with toner that need to be cleaned. Im not sure how the transfer system works on the large format printers but if it's anything like an Oce one, that should do the trick.
Mar 30, 2009 | Ricoh FW870 Black and White Copier
Can't get picture in wide format on the menu. 16:9 and 4:3 only.
I had the same problem with a 50". The only way I could fix it was to set my Bose system to 4:3 format and the tv to 16:9. Now you can use the zoom to get the right size
good luck
eltjo
Nov 21, 2008 | Samsung LN-T4053H 40 in. LCD Television
Kyocera mita copier (printhead repearing ((led))
change toner... if that doesn't fix it then change the drum...
Jul 24, 2008 | Gestetner A045 Wide Format Copier
Ricoh FW870 Black and White Copier Logo
27 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
