Question about American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen...
Since buying the house, we have always had slightly lower flow out of this faucet, but most recently flow is down to a weak stream. There seems to be no problem with the faucet head. All other faucets in the house have good flow. Any suggestions? Thanks.
  • 718 Answers
Sounds like there is a blockage in the head try to disassemble it carefully and clean it out. Watch how you take things apart, if your recall is less than perfect take pics. with your phone or dig. camera. Good Luck
Posted on Nov 13, 2010
The water pressure to the H/C is very weak while the w/p to the handheld is fine
Most new faucets have to adhere to a standard of output so they are regulated.
Jul 22, 2014 | Fontaine Plumbing
KWC faucet leaking around the main stream of water
Yes, go to HD or Lowe's and buy a new one.
Be sure to take the old one for comparison.
Nov 20, 2017 | Delta Model 470: Signature Kitchen...
Hot Water pressure is nearly non-existent. Cold is fine. This is not a problem of turning on the water below the sink. Water faucets coming from the house are both fully open,, both hot and cold. Nor...
It sounds like you may have an obstruction in the supply valve under the sink. Turn off water to house. Remove supply tube from valve. Unscrew the packing nut. This is the nut where the stem of the valve enters the body of the valve. Remove it and flush the line by having someone turn on the main while you hold a cup or small bucket over the valve to prevent water from going everywhere. Also check to make sure the washer has not come loose. If the washer shot out when you flushed the line, replace it. Be sure to check flow before reinstalling supply line.
Jul 08, 2017 | Grohe Ladylux Cafe Faucet with PullOut...
Low stream
these faucets have a single handel, and have a cartage that can be taken out and cleaned. Low water pressure is caused by minerals in the water to build up in the cartage and slow down water flow.
Mar 28, 2010 | Kohler K-10416-BN Fort½ Single Control...
Handle is loose water flow weak
to tighten handle, you hold lever(top of handle) while unscrewing round piece below, entire assembly should come off.look down and should be screw down there, tighten it up. flow problem could be the areator, unscrew and clean if need'd. check supply tube's,shut off valve's, (if you have them)make sure they are wide open.
Mar 22, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Need help Have new house with 2 handle delta faucets, everything worked fine yesterday till I shut water off to install hot water heater now 2 different sinks have no flow hot or cold. Checked lines down...
Try opening all of your faucets in the house including the two that don't work. then go around the house and shut off one faucet at a time. Sometimes the air that gets trapped in a system will do weird things. I had a similar experience and finally the faucet started sputtering and then full water flow... still can't figure it out.
Mar 07, 2010 | Delta 3555RB-216RB Victorian Double-Handle...
Blanco harvest kitchen faucet with pullout spray low flow rate
Check fine filter at tip, probably blocked, got caught with same thing myself recently!!!
Jan 26, 2010 | Blanco Harvest Single Handle Faucet with...
American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen... Logo
82 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
