Question about Kenmore Dryers
How do you get loose change out from the drum
Unscrew the parts the coins are stuck in from inside the bottom panel
Posted on Nov 12, 2010
Inside drum of front loader loose bearing in back is ok but drum must have bushing gone how can i change this bushing the drum looks like its sealed
If the inner drum moves or is loose the the inner drum needs to be replaced .At the same time you should replace the rear of the outer drum as this contains the seal and bearings.
Nov 04, 2010 | Kenmore 43142 Front Load Washer
I have thumps in back brakes when applied fully got new drums and brakes ,car is 1997 blazer i have replaced drums 3 times no change pulling my hair out
Make sure its not some other thing such as: loose axle mounts/u-bolts, worn differential internals, bad u-joints, something loose in back like the jack or spare tire, loose gas tank straps. Good luck
Aug 10, 2010 | 1989 Chevrolet S-10 Blazer
I've changed the drive belt, but it seems that the...
If the drum being pushed forward makes the problem better, I would say your felt pads under the drum which the drum rides on are either worn down the metal or loose.You need to remove the front casing of your dryer and inspect these felt pads. If they are loose tighten them up and if they are worn they need to be replaced. When you have your dryer apart you may also want to try to move the rear of the drum to the left and to the right and see if the back of the drum is loose as this means your bearings are loose and may need replacement. To fix this problem however the top of your dryer will have to be removed to take the drum out (many times the top will tilt back on hinges) because the bearings are on the back of the drum.
May 12, 2010 | Dryers
As dryer rotates, with clothes drying, it sounds like loose pocket change is loose in between the two tubs.........help!
the change gets caught in the three baffles that are attached to the drum.unplug the dryer,open the door and remove the two screws that hold the in place,remove the door,then remove the other two screws opposite the door screws and pull the front panel off.rotate the drum so one of the baffles are down in the right hand corner so you can get at the screws that hold the baffles onto the drum.try loosening the screws but you might have to remove the baffles to get to the change.let me know how you make out
Apr 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Makes a noise like there is loose change in the dryer. Grey marks are coming off onto the clothes. checked. there is nothing inside the dryer or in the pockets of the clothes. Still happens- even with...
This sounds like a faulty drum bearing. The grey marks you are seeing are grease from the bearing. The loose change sound is from the remnants of the bearing rotating as the drum turns.
Mar 09, 2010 | Dryers
Paddle in drum is loose at back of drum screw is loose how do i access to tighten ?
You need to get at the outside of the drum to reach those screws. You don't give a brand, but if it's a Whirlpool-made dryer (many are, like the Sears models), this page can help. It shows how to change a belt, and the first few steps explain how to open the machine to get at the drum.
Good luck with the repair, and thanks for using Fixya!
Mar 02, 2010 | Dryers
Cannot dis-mount the drum to change break pad
Drums Probably Have Deep Groove Cut In Them--BACK OFF AJUSTERS--This Will Allow Removal.
Dec 19, 2009 | 1996 Dodge Caravan
START SWITCH HUMS BUT THE DRUM DOES NOT ROTATE
Try turning the drum while holding down the start button the belt could be twisted
May 10, 2009 | General Electric DHDSR46EGWW Dryer
GE dry is making a noise like loose change is rolling around
There may be change rolling around in it.
Remove the top. Take the screws out of the drum baffles and remove the coins from inside the dryer drum baffles.
When replacing them, tighten them well to help prevent coins from getting in there.
Mar 23, 2009 | GE Dryers
Change in drum/tub
Scamp, the only solution is to empty the pockets...there is no funtional or non functional part to catch the coins, buttons, toothpicks, bra wires etc...Catriver...
Oct 25, 2006 | Maytag MAH8700A Front Load Washer
Dryers Logo
63 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
