Question about Astoria Argenta SAE-2 Espresso Machine
Our espresso machine is making a strange noise. I guess to best describe it, it sounds like its steaming water when we aren't using it. The sound is continuous.
  • 22 Answers
It could be a leaking valve. If it's on top of the boiler it's most likely the antieddie pressure valve and they run arond $18.
www.kaldi.com
Posted on Jan 23, 2011
Miele Coffee maker CVA 615 makes clicking noise when first turned on. Grinds the coffee but the coffee will not come out. Makes the clicking noise again. It dispenses the used ground coffee correctly to...
If the Hot water and the steam function work fine - then I would say the water system and heaters are good. Are the grounds being dumped in the waste dry? I would guess so. The brew unit drive sounds to be the issue - it has a valve on it that dumps the water to waste if the pressure is to great - the waste valve sometimes gets stuck, but in your scenario it sounds as if the brew unit is not being driven to full compression (the clicking sound) and if that is the case the operation is cancelled. One thing you may try - set the grind to coarse and try a small cup - this is easier on the drive and may work - showing the Valve is good and the brew unit drive is starting to weaken.
Hope that helps
Jan 01, 2018 | Miele CVA615 Espresso Machine
When I turn on the steam valve, nor hot water nor steam comes out (not one drop), it doesn't make it to the nozzle and instead it goes directly to the drip tray. Coffees dispense works...
Hi, sounds like either you have a blocked or fauly solenoid, or micro switch or the water inlet side of the boiler is bocked. This is easy to fix. You need to be able to get to the inlet on the boiler, undo the water line and drill it out using a 3mm drill bit. Dazza
Sep 15, 2011 | Gaggia Titanium Espresso Machine
The machine is making strange noises when grinding
when first started up turn the steam valve open to get out air ... job done i hope or you need it repaired ... bsc appliances 07779933829 we repair via postal service anywere .
Jul 20, 2010 | DeLonghi EAM3400 Espresso Machine
Why does the coffee maker make a loud noise right before it brews the coffee?
Usually this is the expansion of steam as the heating element quickly rises to the preset temperature. This process heats the water to the correct temperature and causes the water to flow upward from the water reservoir. Then out the brewing spout over the coffee grounds.
It will usually make strange noises at the end of this cycle too.
The water is used up and remaining steam is vented.
Sounds more like a burping and last minute gurgle really. :)
Hope this helps!
Nov 17, 2009 | Keurig B100 Coffee Maker
Water coming out of steam nozzle not coffee output when making coffee
Sounds to me there might be a blockage on the brew unit, and since the pressure is so high it is going through the bypass. Clean the screen and tubes on the brew unit.
May 12, 2009 | Gaggia Syncrony Compact Coffee...
Extremely loud squealing noise during steaming milk
This could be blocked. The best way to clear this is to switch off the machine and see if you can dismantle the frother arm. Sometimes the arm will come off by unscrewing. If it does, wash it in hot water and washing liquid. If it doesn't come off try putting the frother wand into a mug of cold water and allow it just to steam the water.
Frother wands don't just steam liquids - they **** up liquid which can block the vents and the actual steam hole which this machines' problem sounds like it does have.
Apr 05, 2009 | Breville ESP8XL Espresso Machine
Thumping noise
There will be a different sound when you steam milk.
Aug 05, 2008 | Breville ESP8XL Espresso Machine
Heating element issue?
Hi sounds like a thermastat problem control needs professional tech to look at it cheers john
Jan 18, 2008 | Saeco Magic De Luxe Espresso Machine
Sealing in the cofee machine
You have to replace the steam valve, make sure you get one in metal.
Sometimes there will be a strange sound from the brewunit, make sure the filter in brew unit fits tight, if not you get a noisy sound from it.
Check also the hole in chassis behind the brew unit and make sure that is clean.
Sep 27, 2007 | Saeco Incanto Rondo Fully Automatic Coffee...
Astoria Argenta SAE-2 Espresso Machine Logo
162 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
obsteiner
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
