Question about Troy Garden
I have a TB525EC trimmer with the "new" string
I agree it was not an easy feed process. The single line did not feed into the individual upper and lower chambers, due to cheap plastic part design, causing the line to jam on auto feed.
REMOVAL OF HEAD: I put on a Gator type Universal trimmer head.
Attempted to hold the shaft/rod, but it twisted and I thought it might break. I used a needle nose vise-pliers to clamp onto and hold head, at top of factory head. [At bottom of outer shaft was a black plastic cup/cover; just below is a gap that allows gripping of the bolt for the head, above the red trimmer head turn knob.] After you vise the bolt, hold the pliers and spin the head counter-clock wise, unscrewing the head & nut. [It was not very easy breaking the nut loose, by I have light arthritis and was able to accomplish without other help or tools.
N Ramos
Posted on Aug 18, 2012
    President:
  • Troy Master
  • 1,545 Answers
Great question! You can always go to the Home Depot and purchase a "universal-type" retro head and if it doesn't fit correctly, just return it for a refund or go on a site like Ebay and buy a genuine Troy Bilt retro type string head. I bet they will fit.
Posted on Nov 12, 2010
  • Tom Smith Apr 22, 2012
    You obviously have no idea what you're talking about. With these pieces of junk that trimmer head doesn't just unbolt. I can't even get TroyBilt to answer how to remove the thing
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Gas dripping out of air intake on troy bilt trimmer TB525EC
The diaghrams in the carb could be starting to stiffen up holding the needle open. Does it start with no choke when cold? Rebuild the carb to replace stiff diaghrams
Oct 24, 2012 | Troy-Bilt 4 Cycle Straight Shaft String...
Echo SRM 200 series trimmer is great. I noticed though this summer once I reel in the new string, a short time of trimming later, only 1 side of the string appears. When I open up the reel, the string is...
For your machine, make sure you are using the Manufacturer's recommended trimmer line. For your model, they recommend using Echo brand .080" Cross Fire diameter line. You also need to insure that when you load the spool with the line, that it is loaded (in the right direction) so it can feed properly.
Jul 02, 2011 | Echo Rapid Loader, Trimmer Head
Replace duel string trimmer line
Change the line on Troy Bilt 4cycle TB525EC weed eater
Oct 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I don't know how to load line into the Troy Bilt Speedlock head
cut to pieces of string about 8 ft long. run your line through the holes on the side of the head. you will see 2 smaller holes on the inside. put the string in those 2 holes and begin turning your head to install the string.
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
String will not feed when bumped
I've never had any luck with those stupid bump heads. Every time I would refill them, the string would get caught up. They bind up. I finally replaced the bump head with a string head that you place short pieces of string in. They're not perfect either. You have to pre-cut the string to about 9-12 inches in length, and just replace the piece when it's time.
Jun 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
I have a Ryobi Reel Easy bumb feed stringhead on my Cs30 Ryobi weed eater with an expand it curved attachment. Loading the replacement string is no problem, but getting it to come out is another problem. I...
what model is trimmer? cs30? if you found the line on it clockwise, that's your problem. on the cs30 it rotates counterclockwise if youre looking at the head while trimmer is upside down. the line has to be wound opposite direction or your going to have a MESS of string in the head.
May 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
504 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
