Question about Gateway MT3705 Notebook
MT3705 will not show harddrive or cdrom
My harddrive stopped working for the second time, so I replaced it. I was in the middle of install my o/s and it rebooted. After that it would not show that a harddrive or a cdrom was connected. Do u think it is the motherboard?
  • 67 Answers
At first I would think that a harddisk format would fix it.
but it sounds more like that your ide controllers on the motherboard is broken.
you'll need to get the motherboard replaced.
CS
Posted on Jun 18, 2008
Every time I try to use Yahool e-mail a revolving colored circle appears and stops the computer from working.How do I resolve this?
The Famous SPINNING BEACHBALL. It should stop after a few seconds, if not BackUp and then Reformat your HD and start over.
Sep 20, 2013 | Apple MacBook Laptop Computer Mac...
Every time i put the hard drive in the xbox screen shows up where it's just a white screen with the xbox symbol in the middle. Is it a virus? What can I do to fix it?
Does it load up without the harddrive in the system? If it's freezing when you put the harddrive in, you may have a bad harddrive and need to replace it.
Feb 23, 2011 | Microsoft Xbox 360 Console
How do i remove the hard drive from a hp pavilion a1320n
1) Computer unplugged from power, observe Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the hardware components inside a computer.
Computer unplugged from power, computer on a table, computer case open.
TOUCH the metal fame of the open computer case to relieve your body of Static.
Also before you take new hardware components out of their anti-static bags, or boxes.
If you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
HP Support > Pavilion Media Center a1320n > Opening the computer case
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00593575&cc=us&lc=en&dlc=en&product=1818050&tmp_track_link=ot_search
Replacing the Harddrive, (Hard Disk drive),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00639788&cc=us&lc=en&dlc=en&product=1818050&tmp_track_link=ot_search
The Harddrive is a SATA harddrive. Uses a SATA 7-pin data cable, and a 15-pin SATA power cable.
http://en.wikipedia.org/wiki/SATA
Top right photo shows the SATA data cable connector, and cable.
Top right photo below it shows a typical SATA data header (Connector) on a motherboard.
Typical SATA power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
NOTE*
IF, your SATA harddrive has a connection for a standard 4-pin Peripheral power cable, (Misnomered as Molex), AND a connection for a SATA power cable, ONLY use the SATA power cable.
It will Burn Up the Harddrive if you use both.
If you are putting a new Harddrive in, you will need to have backed up, (Copied) the info you wish to save off of your old Harddrive, first. This is if the harddrive is not bad, of course.
You will also need the Restoration Disk/s to install a new Harddrive, if you are going to just replace the harddrive with a new one. (Larger, or replacing a bad harddrive)
If you do not have the Restoration Disk/s you can obtain them from HP Support.
In the US call 1-800-474-6836
24hrs a day, 7 days a week.
Disk/s are free. Shipping and handling is not.
$17 for a 5 to 7 day ship, $24 for a 2 to 3 day ship.
Have the Serial Number from the back of your computer tower handy to give to the representative.
(White Service Tag. S/N is Serial Number)
If you are not in the US, here is the Worldwide Support contact page,
http://welcome.hp.com/country/us/en/wwcontact_us.html
If you are going to install a new operating system, per se Windows, (Windows 7?), you may have to go into BIOS Setup, and in Boot Order set the first boot device to CDROM, if the disk does not automatically load.
Oct 24, 2010 | HP Pavilion Media Center a1320n PC...
MY GATEWAY MT3705 STOPPED WORKING
Remove the battery...hold start button for 20 seconds with battery out. Re-install baterry and plug in. Try that...:)
Sep 07, 2009 | Gateway MT3705 Notebook
Replaced harddrive and dvdroom wont recognize in bios
Goto bios menu. And change the setting on hard drive and cdrom. It could be it still set in the old configuration. Try to set it in auto detect. Then save the setting. Then goto bios once again to check if the settings doesn't change. Restart again and wait if something you didn't expect still happens.
Leave a comment if this solve cd rom detection.
May 12, 2009 | Gateway M-6750 Notebook
Can't boot with Cd-Rom unable to install windows XP
Well, maybe I can try, thus in your bios setting you can boot using usb cdrom? Or maybe its time to change your cdrom drive already. If you can borrow a good spare cdrom. Take this in for the meantime in exchange for your installed cdrom. Maybe your cdrom drive is faulty. Then if this is ok, it is now easy for you to get on.
Second option, you can take out your harddrive prime it, then have a partition (say d:\) with a copy of full copy of xp installer, and other important installer just have it foldered. Then I assume you can boot using a floppy drive with win98 rescue disk. After booting goto harddrive partition with xp installer. then click setup and set it up in c:\ . Then your go other software, installed it manually.
I do this coz it much faster to installed using harddrive and also it is only in xp.
Hope this helps. comments if I miss something.
May 05, 2009 | Microsoft Windows XP Home Edition
Alienware Aurora CDROM and Hard Drive Issues
Some SATA/RAID controllers require you to install the drivers during the setup of Windows. Otherwise, you'll get the message you received. Download the drivers and put them onto a floppy disk for use during setup and at the start of the Windows setup, you will be prompted to press F6 to install these drivers. If you don't have a floppy drive, don't worry. You can slipstream the drivers into a setup disc that you can create. To do so, follow the methods here:
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Feb 05, 2009 | Alienware PC Systems Alienware Aurora High...
GATEWAY MT3705
maybe i would try to replace the harddrive first with a old one you have laying around or buy one from a computer-recycleing place first then if that does not work i would replace the motherboard
Jul 14, 2008 | Gateway MT3705 Notebook
Problems with windows.
  1. Are you using a SATA drive or an IDE(PATA)?
  2. If using SATA, is SATA set up in bios as first boot or second after CDROM?
  3. If using PATA hard drive is the IDE channel working properly? Switch the CDROM and Hard drive ribbon cables on the motherboard.
May 10, 2008 | Foxconn 661FX7MF-S Motherboard
Errors
no this is not the problem with any motherboard r with hard disks this is the problem with the cdrom drive ... the capability of the reading cds is less of the cd rom u r using in this first system ... once you just have a check by removing the cdrom drive of the second computer & inserting into the first comp... it will surely read that cd....
this means it s the timt to change the cdrom of the first computer .. so just buy new 1..........
Feb 11, 2008 | Foxconn NF4UK8AA-8EKRS Motherboard
Gateway MT3705 Notebook Logo
56 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
