Question about Royal RL170MX Shredder
My RL170MX will only run in reverse mode. Forward and auto modes do not work. What controls the motor rotation ?
    Genius:
  • 1,218 Answers
Motor forwards rotation is begun by inserting paper in betwen the 2 "eyes" in the paper throat of the shredder. They can become dusty/dirty and not function, if they are clean and yet the motor still will not turn in the forward direction it is possible the pcb inside the unit is faulty...contact Royal at 1-800-524-0799 for parts assistance.
Posted on Nov 12, 2010
Auto reverse
You do not list brand and model but it is typical that the belt replacement is missing the mark in that the reel rotation sensor is not detecting rotation of the reel table and therefore trying to go the other way. The reels have to be turning in play mode. If they do not auto stop or the reverse function thinks the tape is at end.
Apr 15, 2014 | Audio Players & Recorders
Front defrost not working
as always, check fuses first.
then scan this car, it will show, mode motor errors. huh?
those are damper. in the heater box.
there are 2 fail points (besides wires)
the control is bad,
or the damper is failing.
The FSM covers this 100%
or at alldata.com
what tech does is makes sure the control sends the signal
the damper (there are 3 types used on all cars)
if its damper motor , the FSM shows the damper tests.
which are unique to Toyota. and a spec, year, 2006.
the mode damper is failing.
the only question is why,
the answer is simple tests. detailed in all FSM of all cars made.
here ill look your up to see which of the 3 type class it is.
your car has a ACC brain, a/c controller, this controller runs the show.
it gets your inputs from the defrost switch and then sends signals
to the mode motor.
FSM quote
Air Vent Mode Control Servo Motor ControlWhen the mode select SW is pushed, the ECU in the A/C control assembly activates the air vent mode control servo motor.
The servo motor rotates to the position (FACE, BI-LEVEL, FOOT, FOOT/DEF, DEF) selected by using the mode select SW,
and moves the damper.
In auto mode, A/C control assembly controls the damper to move to the best position for the conditions without operating the
mode select SW.
I SAY SCAN iT
using any scan tool that suports full Toyota. full scans including
extended factory codes..
i say buy one.
here is one.
http://www.amazon.com/gp/product/B001QIUGVI/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
owning complex cars, and DIY, you need a real scan tool
or just guess.
Feb 18, 2014 | Toyota Prius Cars & Trucks
Cobart Automatic Meat Slicer is not working on Automatic mode
To operate the slicer in Automatic mode . . . Rotate the Speed Selector Knob to the desired speed; make sure the Carriage is in HOME position (all the way forward); make sure the Lever is on the Manual position (pointing down); turn the slicer on; start the carriage drive unit by rotating the Lever to the Automatic position (up and to the right). Either of the two speed selections can be used to begin Automatic mode. The speed can be adjusted at any time by rotating the Speed Selector Knob. To stop the drive unit, rotate the Lever down and to the left - to the Manual position. ------------ If you slicer is set on proper automatic mode and still not running on automatic mode then the problem relates to internal motor or the selector knob. But try reset before this. Push the reset button underneath the slicer near the right-front foot if the carriage motor overloads. The reset helps in some problems.But if its not helping then internal connections of selector knob has to be checked.Of the same with motor,the connections of motor to the selector for automatic mode has to be checked.---------------- This will help.Thanks.Helpmech.'
Dec 15, 2010 | Microwave Ovens
I had a lift motor go out on my 9500hr treadmill, I changed the lift motor. Now when i try to get the treadmill to inclin it only does it in the manual mode. when i try to get it to incline through the...
1) Try to measure the if there are 110Vca in the terminal in forward or reverse.
2) Try to measure the ESR from Capacitor and replace it.
3) If you system as LIMIT Switch , test for continuity with DMM for faulty and replace, or some wires loose or disconnect.
4) If you system are Relais see if the relais for UP and down, and working most of them has LED that will be LIT indicating working or NOT
5) If NOT voltage Vca are NOT, coming from The Controller Board Motor, REPLACE IT,
Control board motor has 3 power supply: 1) Console board 2)Elevation Motor 3) Main Motor.
Some IGTBs are Defective.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
LED Blink Patterns on the Control Board Treadmill
Nov 25, 2017 | Life Fitness 9500HR Next Generation...
I just installed a new hampton bay ultura 68" ceiling fan and the unit is only controlled by a remote control. The reverse function does not work and the fan only runs in one direction which happens to be...
After researching the complaints on this product I found that the reverse mode can be intermittent, the high speed can be slow at best and the returns of this product back to the store are staggering. Get a new but different model.
Jun 21, 2010 | Heating & Cooling
I own a Royal RL170MX shredder. I turn on the
If the blades rotate then the paper should go in...just be sure the blades are turning in the forward direction and not in reverse.Also make sure you lubricate the blades with shredder oil.
Sep 01, 2009 | Royal Office Equipment & Supplies
The shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Jun 12, 2009 | OfficeMax 0M96431 Shredder
Blades rotate twice but stop-motor continues to run, both forward & reverse mode its the same. Have tried to oil, unblock, run forward & back but to no avail. Can anyone help
Is the motor just humming after the 2 rotations? If you are over oiling the unit, tha shreds will soak up the oil and start sticking to the blades and begin growing a paper tumot in side the cutter shroud, whish in turn will start to slow down and jam the cutter asm and motor. Best to take apart and thoroughly clean.
Jun 01, 2009 | Office Equipment & Supplies
Royal RL170MX Shredder Logo
308 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
