Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
How do i get a fax confirmation to print out????
  • HP Master
  • 1,679 Answers
Follow the steps below to enable the Fax confirmation report.
Press SETUP button on front panel
Use Right or left arrow till you find Print Report - Press OK
User right of left arrow till you find Fax Confirmation - Press OK
You will find few options like
1. Fax Send Confirmation
2. Fax Recieve Confirmation
3. Fax Send and recieve
Choose the one you want and press OK
* Please rate this solution and write comments
Posted on Nov 12, 2010
  • ibfluffy Jul 05, 2011
    I'm frustrated. I really want a confirmation page (rather than checking my fax log) to make sure a fax was actually sent. Even though I've gone through the set up above and set it for both Fax Send Confirmation and Fax Send and receit confirmation, I don't get the confirmation page. When I set it on Fax Send and receive, I DID get a confirmtion page on received faxes but I really want them for when I send a fax. Any suggestions on why this isn't working for me? Thanx.
4 Suggested Answers
agnelkj
  • 210 Answers
SOURCE: How to print fax confirmation
hi,
from the main menu on the printer scroll down to "fax setup" or "advanced fax setup"
you have the option inside it.
thanks and regards
agnel
Posted on Mar 18, 2008
POCBM
  • 121 Answers
SOURCE: Printed confirmation on faxes sent form HP Laser Jet Fax M1522nf
To get confirmation page do this:
1. On the control panel, press Setup ( ).
2. Use the arrow buttons to select Reports, and then press OK.
3. Use the arrow buttons to select Fax Reports, and then press OK.
4. Use the arrow buttons to select Fax Confirmation, and then press OK.
5. Use the arrow buttons to select the option for when you want the fax error reports to be printed.
6. Press OK to save the selection.
To iclude first page with report:
4. Use the arrow buttons to select Include 1st page, and then press OK.
5. Use the arrow buttons to select On, and then press OK to confirm the selection.
Posted on Mar 25, 2009
  • 26 Answers
SOURCE: How do I print a confirmation page for this fax
1. First You need to press the additional functions button on the front.
2. Select Report Settings button
3. Select Printer button under the Print List menu
4. Press either PCL button or PS button to print the appropriate config page.
5. Press Configuration Page button
6. Select Yes button to confirm printing of config page.
Posted on Feb 19, 2010
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
How do I print a fax confirmation AFTER I've sent a fax on the HP L7590?
The product can print confirmation reports automatically for each fax that is sent and received.
Printing fax confirmation reports
  • The default fax confirmation setting is Off . Use these instructions to enable printed fax confirmations.
  • Press Setup on the product control panel.
  • Press the right arrow button until Print Report appears on the control panel display, and then press OK .
  • Press the right arrow button until Fax Confirmation appears on the control panel display, and then press OK .
  • Press the right arrow button to select the appropriate option (listed in the following table), and then press OK .
Sep 25, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
1. Press Setup.
Send &
Receive
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Confirmation
By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
251 people viewed this question
Seeker5211
Seeker5211
