Question about Refrigerators
Runs constantly even on lowest settin. Freezes contents.
    President:
  • 1,515 Answers
Hi, sounds as though you are having a thermostat control problem. Try turning the stat slowly in each direction as far as you can to determine which direction is coldest or warmer, or it may say. You want to see if it will shut the compressor off. If it were low on freon it would also run all the time trying to keep up on a call for cooling, but you would not have everything freezing. Its a stat problem if it will not shut off when you turn the dial all the way in either direction, and will need to be replaced. If this is something you want to take on, you will need to get the model, serial, and name and size off unit and get a new control stat at a appliance parts house. They can be tricky to replace as the capillary tube on the stat runs up into the evaporator coil of the freezer, which makes it hard to change. Your only other choice would be to get estimates on having it changed for you. Depending on the age of this unit, and what you paid for it, I would take all of this into count before you have a tech come out, as they can be costly. Try turning the control to see if you can get it to cycle off, and if it does, set it about 2 settings higher then that to see if this will solve your problem. Please keep me posted on the out come.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Posted on Nov 12, 2010
Fridge Freezes Everything
there is a motor with a flapper that opens and closes to keep your temp correct in the refrigerator side most likely the motor is bad and stuck open so your air from the freezer has constant flow to the refr side. the flapper is in the back of the refr behind a cover where the air flows in.
Apr 16, 2014 | Emerson Cr180 1. Cu. Ft Compact...
MCWC30MCG freezes reguardless of thermostat
Mine was doing the same thing. Needed a new thermostat. Part number is 1206856 or WDF18A-L or WDF22A-L depending on where you get it. $23-$25 easy repair you can do.
Jul 24, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
The indicator light is constantly on
tats the flash i think... u can off it by offin the flash settins in ur camera settins
Apr 11, 2010 | Sony Ericsson Walkman W980i Cellular Phone
Milk, lettuce freezes after temperature is reduced
turn both control to the same number the lowest number and then wait 24 hrs if you want it needs to be cooler move both controls 1 number then wait 24 hrs and see if you are happy
Apr 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer over freezes,whats the correct setting?
The thermostat maybe defective. It will not over freeze even at the lowest setting.
May 27, 2009 | Refrigerators
Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Food gets frozen
If your refrigerator freezes its contents, even when the cold control is set to its lowest setting, its cold control is probably defective. Call an appliance repairperson. As a rule, refrigerators are designed to maintain 37 to 40 degrees F in the refrigerator box and 0 to 5 degrees F in the freezer box. Setting either compartment to lower temperatures generally costs you extra in energy dollars. If the icemaker keeps making ice, even when full: 1) Lift the bail wire to shut it off. 2) Empty the bin, remove the icemaker, clean it, and reinstall it. 3) If the problem persists, consider having an appliance repairperson remove and replace the entire icemaker and valve, a relatively affordable repair. With this type of problem, it's often better to replace the unit rather than to pay for
Jan 18, 2006 | Hoover HCA331FFK
Refrigerators Logo
181 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
