Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
What are the 2 screw adjustments on the john deere 140 carburator ,top and side screws, how many turns out from seated position?
  • Kelly
    Kelly Nov 12, 2010
    Hi and welcome to FixYa, I am Kelly. The John Deere 140 has been around since the 1970's There are so many different engines. They started with 12 HP Briggs and Stratton then on to a 14 HP Kohler and today the LA140 has 17.5 to 23 HP Vanguard Twin Cylinder engines. What is your engine number please so I can pass you the correct information? Just as a general rul of thumb the inital setting is 1.5 turns from the just closed position. That will NOT be the final adjustment.
    Top is usually for Idle speed and the side screw is usually for the fuel air mixture. Make your adjustments on the side screw only unless your having idle problems.
    I will just say that most carb problems are caused by debris in the float bowl and throat jet in the bottom of the carb / bowl nut threaded area. This includes a dirty float bowl nut. Additionally a dirty fuel filter will cause an engine to run lean or stall under an extended load.
    Engine make and model number please.
    Kelly .
    Once you pass your engine model number by responding here I can probably locate a manual for your engine so you can do what everis nesessary on your carb.
  • 718 Answers
Start out with three turns and go from there!
Posted on Nov 13, 2010
Opel kaddet 1995 model. How do I adjust the
There are only two adjustments on a carburetor, the air mixture setting and the butterfly valve position setting. The air mixture screw is on the side close to the mounting flange, and has a spring behind the screw head to keep it in position.
To adjust it, look for the throttle valve screw which is also on the side, it ix the one that attaches close to where the throttle cable attaches to the carb. Turn the set screw down to let the car idle as slowly as possible. Now go to the air mixture screw. Turn it slowly first in one direction until the revs drop, then turn it out to the point where the revs are maximum. You might have to turn the screw back and forth until you find the best position. Now turn the throttle adjustment back to idle speed.
Aug 28, 2014 | Opel Kadett Cars & Trucks
Carburator Hi / Lo Adjustments
First things first. where are your screws set when you start it is very important to know where you are at when you start adjusting a carburetor so you can put it back in the same position when you move on to the next attempt at a solution if it should turn out that the adjustment was not the cause of your issue. Turn both H and L screws, individually, clockwise until they bottom out GENTLY. DO NOT TIGHTEN these screws down this will damage the needle and the seating surface of your jet as well as the jet itself in some cases. merely turn them until you gently come in contact with the seat, translation until it doesn't turn anymore using VERY LITTLE FORCE. Now back each of the screws out Turning Counter Clockwise 1-1/2 turns each. POINTER: Take a sharpie and put a dot on the side of your screwdriver so that you can see it well. White out works to if the sharpie is hard to see. Turn the screw one half turn at a time counting out loud to yourself 1/2...1...1-1/2. All the while watching the position of your mark on your screw driver. Your dot should end up on the opposite side that it started on. Now adjust your throttle using it's set screw turning it also clockwise. Turn it enough to sufficiently raise the idle Don't Go Crazy about 1/4 throttle should do. Start your saw after you have taken a look around for safety. Start with the l screw or low idle circuit. using your ear to tune it. Adjust the screw in or out till the machine sounds the best then turn it Clockwise about an 1/8 of a turn. Then move on to the H screw or High Idle Circuit. With the trigger fully depressed adjust back and forth until you find the sweet spot. Release the trigger. Adjust your idle screw back down . Now Squeeze the trigger again squeeze it completely and quickly. Does it bog a little between circuits Adjust the L screw and then the H screw a little at a time until you have a smooth transition between them both.O7OUT
Feb 04, 2014 | John Deere 2E Leaf Blower Operators Manual
Hi/Lo Adjustment Procedure on 2E
Feb 04, 2014 | John Deere Garden
What is the initial carburettor adjustment for a mac 120 MCCulloch chainsaw?
Hi williamsc32...
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Sep 28, 2012 | McCulloch Mac 110, 120, 130, 140, 160, Eb...
How do you adjust the seat on a john deere gator hpx 12v
you have to flip the gator on its side then you will see four red knobs underneath loosen those and then move the seat to the desired position then tighten the knobs
Aug 12, 2012 | Peg Perego John Deere Gator HPX Ride on...
How to adjust seat on a john deere gator hpx
How do I adjust the mixture screws on the top of the Ryobi 700r carburator
Hi trr6...
Sep 22, 2011 | Ryobi Garden
How to adjust carburator on weed trimmer
Hi bobbiewil512..
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly bottom the adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the bottom seated position to open when you go to replace them, if you remove them for cleaning or replacement.
Normally you adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed.
The high speed jet is normally adjusted when the engine is warm to 1 1/2- 1 3/4 open from the bottom seated positon.
Then re-adjusted by turning the High Speed adjustment screw in or out till the motor runs smoothly at high speed.
Free Answer...Please take time to rate me
Jun 06, 2011 | Garden
I have a john deere 70 1974 with a 7 horse power tecumseh how many times to i turn the either jets on the carb
The bottom screw on the carburetor is the main fuel mixture screw, turn this "in" slowly until is "seats" and then back it out two turns. The idle mixture screw is located on the side (do not confuse with the idle speed screw), turn this in slowly until it seats and then back it out one turn. This will get you in the ballpark but it will have to be fine tuned from their. The proper adjustment is between a "lean" running condition (engine will try to cut off) and a "rich" running condition (engine will load up). The main fuel mixture is adjusted at full throttle position and the idle mixture screw is adjusted at idle speed. Once this is done, you can adjust the idle speed screw in the low throttle position. Hope this helps.
Feb 23, 2011 | John Deere Garden
How do I adjust the seat on my grandson's john deere lawn tractor?
Apr 24, 2010 | Peg Perego John Deere Gator HPX Ride on...
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
569 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
