Philips Desktop 710-T Desktop Cassette Transcriber / Recorder Logo
Posted on Nov 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What size tapes does this recorder take? - Philips Desktop 710-T Desktop Cassette Transcriber / Recorder
Javier Gonzalez
Level 2:
  • Expert 207 Answers
  • Posted on Nov 25, 2010
Javier Gonzalez
Expert
Level 2:
Answers
207
Questions
0
Helped
56982
Points
306
Hello this unit takes minicassette tapes you can fined a different options at http://www.tvps.com/Departments/Dictation-Accessories/Cassette-Tapes/Mini.aspx any of this models work for you
Ihave 1/2"tape I wannt to use as my source. How do I do that?
I assume you have reel to reel 1/2 inch audio tape.
You will have to find a tape machine that uses the same size, format and speed as the 1/2 inch tape was recorded at in order to play it back (Presumably, you will record it into a DAW or computer digital audio format for future use?).
This tape could be a multi-track in a format specific to the original machine it was recorded on, it could be digital audio on reel to reel tape, it could be many different formats.
What do you know about the tape, how, when, and on what equipment it was recorded?
How many belts does a Realistic 14-972 909B tape recorder need?
You can try this site that I am listing but if it is not in stock, then you can use the dimensions listed to see if you can find one. SMC ELECTRONICS
2helpful
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Akai 1710 Manual - Stereo Tape Recorder - HiFi Engine
www.hifiengine.com/manual_library/akai/1710.shtml
Jun 10, 2014 - Reel size: up to 7 inch reel ... instruction/owners manual English ...Akai Open Reel Tape Decks. Akai 1700 1700 · Akai 1710L · 1710L.
Akai Reel-to-Reel Tape Recorder ' eBay
www.ebay.com > ... > Vintage Electronics > Vintage Audio & Video
eBayShop from the world's largest selection and best deals for Akai Reel-to-Reel ... AKAI Reel-to-Reel Tape Recorder Model # GX255 + 2 Microphones + 30 Tapes.
AKAI Reel to Reel Tape Decks Guide ' eBay
www.ebay.com > ... > Reel-to-Reel Tape Recorders
They are famous for their high quality reel to reel decks throughout the 1960s, 1970s, and the ... top of or inside the AKAI Head Cover: X-100D, X-150D, X-165D, 1700, 1710, 1720W, 1800L, ... These models are: 1800L, X-1800SD, X-1810/D, GX-1820/D, and 1800D-SS. ..... User Agreement, Privacy, Cookies and AdChoice.
CR8003 TAPE RECORDER
Hello may be you try to say what type of tapes used your unit, if yes it is a micro cassette size see link for some available for your unit. http://www.tvps.com/Departments/Dictation-Accessories/Cassette-Tapes/Micro.aspx
I have a samsung scd103 digital cam and when i record something it looks good on the screen while im recording it but when i play it back there are grey lines and distorted sound
Have you tried cleaning the recording heads? Use a dry type cassette cleaner only. It's just like a vcr head cleaner tape, only in the small mini-dv tape size.
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
2answers
Toshiba D-VR650 can't tape says canot record protected image
THERE IS A TAB ON THE VCR TAPES IT CAN BE BROKEN OUT TO KEEP PEOPLE FROM TAPING OVER YOUR PERSONAL TAPES.LOOK AND SEE IF THIS IS NOT BROKEN OUT. IF IT IS PUT SOME TAPE OVER IT AND IT WILL RECORD ON THAT TAPE AGAIN.
CONNECTING TAPE RECORDER
I assume you want to record from a tape recorder/player. If not, leave a message, but it will be a similar cable and connection.
If your tape recorder has a headphone jack, you can connect it to your sound card with a special cable. The headphone connectors are sometimes different sizes. It could be either a 1/8 inch, 2.5 mm or 3.5 mm plug. Your local electronics supply store (Radio Shack?) should have the cable you need. (I'd take your tape recorder with you, if possible.)
1helpful
DVC recorder
The physical tapes are the same size, but the encoding on the tapes are different. Unless the panasonic recorder can play DVcam, you're out of luck.
Dan
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
