Question about GE RCA 4-Line Speakerphone
How do you make the phone to a call forwarding, model 25423/24
How can I forward my calls from cordless phone (Panasonic Model No# KX-TGCA21S) to my cellphone
go google and down load the user manual for your cordless phone
type in --user manual for Panasonic cordless phone model kx-tgca21s -- download any pdf version and follow the instruction in the manual
call Panasonic direct on their help line number and have a technician talk you through how to connect as you want
Feb 10, 2016 | Lands Phones
Model CS6429-3 How do I call forward to my cell phone
Hi Ecenthia. For the "Call forwarding" to work, you need to get in touch with your telephone service provider & subscribe to the call forwarding service.
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Vtech CS5121 Cordless Phone
How to cancel dnd cancel
The Panasonic 77xx series phones was first delivered with the TA series systems, but the phone is both forward and backward compatible with 7 different prefix phone systems and about 18 different models.
In a TA series, from the intercom, press FWD and dial 0#. It will turn BOTH Forward and Do Not Disturb off, so if you are forwarding calls to VM, you'll have to reset it.
Carl
Jul 04, 2011 | Panasonic KX-T7730 Corded Phone
When setting up phone book how can i space forward or back
Since you didn't specify the model of your phone, I can't give you a definite answer. On some of them the # moves forward and the * moves back.
Select the model of your phone from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl
to get the manual.
Jun 20, 2011 | Uniden Cordless Phone
How to forward a text message I have recieved to other numbers in my contacts?
Welcome to FixYa!
Forwarding a text message varies in different models of Motorola Cellular phones.
I'm going to give you a generic answer since you have not stated the model# of your Motorola phone.
Open the text message that you want to forward. Go to Edit mode. Click edit then,
For some models, it will work this way: Go to the field where you input the recipients phone number. Input the recipients phone number or search from your phone book. Then press send.
For other models, it will work this way: Click send while in the edit mode. It will ask for the recipients phone number. Input the phone number or search from your phone phone book.
I hope this helps. Thank you for using FixYa. Have a great day. Jas247
May 19, 2011 | Motorola Cell Phones
My Phone model is Panasonic KX-7250X How do you forward incoming calls to another extension
Forwarding is 710x plus the extension, where x is 2 for all 3 for busy 4 is no answer and 5 is no answer/busy.
These are the TD system forwarding commands.
Carl
Feb 22, 2011 | Panasonic Lands Phones
Can I divert calls from this phone to another phone? Thanks MArk David
  • Figure out if your particular cell phone model has the option to forward incoming calls. You can do this by visiting your cell phone manufacturer's website or reading the manufacturer's manual that came along with the purchase.
  • Access the "Settings" menu on your cell phone and select "Phone Settings" menu.
  • Select the "Call Forwarding" option in the "Phone Settings menu. This option is usually found at the bottom of the "Phone Settings" menu. Selecting the "Call Forwarding" option gives you access to call-forwarding controls.
  • Switch on the "Call Forwarding" slider. The default position is off.
  • Insert the phone number you wish to forward your calls to in the "Forward To" field. This field most commonly lies below the "Call Forwarding" slider.
  • Exit the setup menu by pressing the home button. You may be asked to confirm/save the changed settings depending on your cell phone model.
  • Make a test phone call to the cell phone number on which you just enabled the call rerouting option. If the call is forwarded and received on the number you entered, it means that the "Call Forwarding" option has been activated.
  • Oct 08, 2010 | Panasonic Cell Phones
    How to configure call forwarding on RCA RCA Phone model 25425RE1-
    CALL FORWARDING HAS TO BE DONE THRU THE PHONE COMPANY IF YOU HAVE CALL FORWARDING - AND I DO THIS IS WHAT I DO - I HAVE AT&T IN MEMPHIS TN PICK UP HAND SET AND HIT *72- YOU WILL GET A BEEP- DIAL THE PHONE # YOU WANT TO FORWARD THE PHONE TO - SOMEONE MUST BE AT THAT PHONE NUMBER TO ANSWER IT! ONCE THE LINE IS ANSWERED- THEY HANG UP AND THEN YOU HANG UP AND PHONE SHOULD BE TRANSFERED- I ALWAYS TEST IT TO UN- TRANSFER IT PICK UP PHONE AND HIT 73# AND IT WILL BEEP 2 TIMES- NOW PHONE IS NOT TRANSFERED ANY MORE
    Jan 16, 2009 | RCA 25425RE1 Phone
    GE RCA 4-Line Speakerphone Logo
    226 people viewed this question
    Top GE Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Dudeman321
    Are you a GE Lands Phone Expert? Answer questions, earn points and help others
