Question about Roper RES7646KQ Electric Dryer
ACCESSTO THE SWITCH IN THE DOOR THAT SHUTS OFF DRYER WHEN DOOR IS OPENED
  • les2310 Nov 15, 2010
    JUST WHAT I NEEDED TO KNOW----THANK YOU
  • Roper Master
  • 8,220 Answers
ACCESSTO THE SWITCH IN THE - themobilian_118.jpgThis is an older type. themobilian_119.jpgthemobilian_120.jpg
More repair photos and a service manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 12, 2010
How do you shut dryer off in the middle of the cycle, opening door does not work
Is this a digital control dryer or does it have a timer, and I would check the door switch if it does not shut off when you open the door,
Oct 18, 2014 | Roper REX4634KQ Electric Dryer
Dyer light out and door switch wont shut dryer off hen opened door
the switch has a push button on it it may have gotten stuck in a closed position best to replace it. Also check the mechanism that attaches to the switch it may have gotten bent you might try straightening it or just replace it. the switch should have three wires to it and is located by door
Sep 15, 2014 | Dryers
Door is ajar message when shut light comes on but doesnt run
That's because the door switch isn't getting pushed when you're closing the dryer door for some reason or another. Its located at the top of the door. Try pushing the switch by hand and seeing if the light shuts off when you manually push it.
Nov 27, 2013 | Samsung DV337 Electric Dryer
Door will not stay shut
There has to be some sort of spring on the door latch assembly that keeps the door closed. If broken or no tension the door will not latch and spring open. And when the door springs open, a safety switch shuts the machine off.
Nov 21, 2013 | Bosch Nexxt WTMC3321US Electric Dryer
My dryer light will not shut off even when door closed and it will not start up when in push start button it does a rapid beep
is the door switch broke?first what kind of dryer and send the model number,when the door closes it hits the door switch and shuts the light off,the dryer will not run if the switch is broke,it's like trying to start the dryer with the door open if the switch broke.
Apr 25, 2011 | Dryers
Dryer runs when door shuts. Only stops when door is open
There is a safety switch in the door that shuts dryer off when door is open. If there is more to your problem let me know. From what you have stated there is no problem.
Jun 06, 2010 | Frigidaire FEQ1442ES Electric Dryer
Whirlpool Cylypso Dryer not shutting off when
sounds like the door switch is sticking when door opens drum should stop and lite comes on, check to see if switch is sticking if not then you should probably replace it also chec bulb to see if it is not burned out.You never know one could probably effect the other
Dec 18, 2009 | Dryers
Dryer will not shut off dryer will not shut off
door lock or door micro switch
Nov 29, 2009 | Dryers
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
Roper RES7646KQ Electric Dryer Logo
210 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
