Question about GN Netcom GN 2000 STEREO USB HEADSET Headset
I have Windows XP on a new laptop. When I connect my GN 2000 USB headset, Windows displays the New Hardware Found dialog box, but is unable to find the necessary drivers needed to use the device. It's supposed to be a plug and play device.
    Guru:
  • 2,178 Answers
Verify your computer is connected to the Internet. Plug the device in again and allow Windows to search online for the drivers automatically.
Posted on Nov 12, 2010
In my computer gn com is not working
Is the headset showing as your default for sound?
Jan 16, 2013 | GN Netcom GN 2000 STEREO USB HEADSET...
I have the same problem with the installation of GN8120 and windows 7. just do not work. With XP was no problems.
go to gnnwtcom websites and go to support download the driver update software and run it in windows xp machine with headset connected. whatever error msg you see just ignore then connect it in your windows 7 should work perfectly....
Jun 09, 2011 | GN Netcom GN 8120 USB Headset
Hi, I have a GN8120 USB and want to use it with Windows 7. With Windows Xp it was installed automatically. With Windows 7 I got an error during installation. Do you have a solution for that? Thanks Best...
To enable Windows 7 support for the GN8120 USB headset, you need to make sure it's it has Firmware Version 11.0 or newer. The version 11.0 firmware updater can be found at http://www.jabra.com/sites/Jabra/GNimages/Software updates/GN8120_Update_790.zip or http://headsetplus.com/PDF/GN8120_Update_790.zip. Other headset updates and more info can be found at http://headsetplus.com/faqdesk44/faqdesk_info.html. Note that the firmware update must be performed under Windows XP, not Windows 7.
May 20, 2011 | GN Netcom GN 8120 USB Headset
Hi i am using windows 7 and GN Netcom GN 8110-USB drivers are not getting installed
According to a Jabra Rep, there is a hardware update available that needs to be run on an XP machine, prior to installing the headset on Windows 7.
You can get the link by calling the Jabra Technical Support Team at (866) 697-8757.
Mar 23, 2011 | GN Netcom GN 8110-USB (706487000020) Audio...
I have Vista as OS, when I plug in the GN 8110 USB. There is an installation process started, but in the set-up there is no audio device to be seen.
so far i have not found a single driver or program package for this device. the reason for this is the device was specifically designed for windows xp and running it in compatibility mode might fix it temporarily, but might cause issues elsewhere. if you choose to do so, you can :
  • Assuming you have the Installation program on the desktop(if it is on the CD then you will need to copy the contents of the CD to a folder on the desktop. create a new folder and drag and drop the files ito it.), right click on the program setup and select properties. in the properties tab there is a compatibility tab.
  • On the compatibility tab select the check-box for run this program in compatibility mode for Windows XP (Service Pack 3). then make sure the check boxes for disable windows themes and run this program as an administrator are checked.
  • click apply and then click ok. run the program now
this should work, but if not.........
the alternative is to buy the updated version. i have found several on the internet for really inexpensive prices to include this one: http://cgi.ebay.com/JABRA-GN-NETCOM-6299-829-105-BIZ-620-DUO-USB-HEADSET-/180542469641?pt=LH_DefaultDomain_0&hash=item2a092b7609#ht_1531wt_905
this is the update for your model. i would suggest this one because windows vista/windows 7 supports it.
If you have any problems let me know and please leave positive feedback for me.
Jethro
Feb 01, 2011 | GN Netcom GN 8110-USB (706487000020) Audio...
Printer is not scan but some problem she has. Error in scannor Turn off scannor and follow instructions ni manual. Scannor drive will closed. Code : 61,213,0 I want to new setup Canon PIXMA MP160...
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
Reinstall the Drivers
Note:
  • The MP drivers can be installed using Easy Install or Custom Install.
    Easy Install automatically installs the software which is in the CD-ROM.
    This method is recommended for first-time users.
    Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
  • Login as a user with Administrator privileges to install on WindowsXP/2000.
  • Close any antivirus software that may be running prior to installing the drivers.
  1. Turn off the printer and disconnect the cable connecting the computer and the printer.
  2. Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
    1. If setup does not start automatically, click 'Start' and then 'Run'.
    2. At the Run window, type x:\msetup4.exe (where x is your computer's CD drive) in Open box and then click 'OK'.
  3. At the main installation window, click 'Easy Install' or 'Custom Install'.
    When selecting Easy Install:
    (A) Click 'Easy Install'.
    (B) Click 'Install' in the following window.
    * Display varies according to the printer model.
    When selecting Custom Install:
    (A) Click 'Custom Install'.
    (B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
  4. When the License Agreement window is displayed, read the content carefully and click 'Yes'.
  5. The installation will start.
    Messages may be displayed during the installation of the application software.
    Follow the instructions on the window and continue the installation.
  6. When the Printer Connection window appears, connect the printer to the computer and power on the printer.
    Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
    1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
    2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
    3) Restart the computer.
    4) Install the printer driver again.
  7. For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
    Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
    In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
  8. After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
  9. If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
  10. At the Print Head Alignment window, click 'Execute'.
    Note:
    * The Execute button may not appear for all models. In that case, skip to step 13.
    * The Print Head Alignment can also be done after the installation of the printer driver.
  11. When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
  12. At the Do not start another operation until current one has finished dialog box, click 'OK'.
  13. When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
  14. At the Installation Results dialog box, check the content then click 'Next'.
  15. At the Installation completed successfully dialog box, click 'Exit'.
    Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
Dec 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I get this error message.. an error occurred communicating with the scanning device. Please ensure that the scanning device is connected properly and try again. Nothing seems to work,, this message...
#Click Start , select Settings , and then click Control Panel .
#Double-click System . The System Properties dialog box displays.
#Click the Hardware tab.
#Click Device Manager . The Device Manager dialog box displays.
#Click the plus sign (+ ) next to Universal Serial Bus Controllers .
#Click the USB Composite Device entry, and then click Remove .
#Disconnect the USB cable from the All-in-One, wait for few seconds, and then reconnect the cable. The New Hardware found dialog box displays.
#Click Next through all of the screens that display while the Wizard installs the USB composite device, and then click Finish .
Regards
Riztech
Oct 24, 2010 | HP Officejet 7310 All-In-One Printer
Canon PIXMA MP190 'not responding'
There are possible causes of this not responding status message you get. you will try out these option i have listed here and see which one resolves the problem. after each one, try to print from a file and from the web.
1. Configure driver to correct printer port
On the 'Ports' tab of 'Printer Properties' window, select the correct port for the printer driver.
From the Windows desktop, open the printer's properties window.
Click the Ports tab.
Below 'Print to the following port(s)' section, select the port to which your printer is connected.
Click 'Apply' to accept the changes.
Click General tab and then click 'Print Test Page' to confirm the changes corrected the issue.
2. Checking USB Connections
You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
Disconnect one end of the cable and then reseat it ensuring the cable is firmly seated into the USB port. If the USB cable is plugged into a hub instead of directly into the computer, try connecting the USB cable directly into the computer.
Repeat step one to reseat the cable on the other end.
3. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
when you are through, restart the system.
4. Uninstall and Reinstall the Driver
If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them.
Caution: Uninstalling means deleting software, such as MP drivers, from the computer. Once the software has been deleted the unit cannot be used through the computer until the software has been reinstalled.
Note: Login as a user with Administrator privileges to uninstall . Turn off any programs running in the background, such as antivirus programs and firewalls before begining.
Select 'Program' (for Windows 2000), or 'All Programs' (for Windows XP / Vista) from the Start menu.
5. Reinstall the Drivers
Note:
This method is recommended if you are a first-time user.
Login as a user with Administrator privileges to install on WindowsXP/Vista/2000.
If the setup program does not start automatically, click 'Start' and go to 'My Computer', then double-click the CD-ROM icon.
If you use Windows Vista, select 'Computer' from the Start menu, then double-click the icon of the CD-ROM.
Note:
The installation of the MP drivers and application has completed. Proceed to the Canon user registration.
If you want to register now, click 'Register'. If not, click 'Next'.
Registration can be done after the MP drivers installation.
Then, Inkjet Extended Survey Program will be launched. If you agree, click 'Agree'. If you do not agree, click 'Do not agree'.
May 22, 2009 | Canon PIXMA MX310 All-In-One Printer
I could not install the driver for pd1100 webcam on my windows XP machine. It say it is not licences with microsoft. What can I do? How can I install it?
Hiya Sivamathy,
1. Do not connect the webcam to your computer before installing the drivers. If you accidentally begin installation with the webcam connected, the Found New Hardware Wizard dialog box appears. Click the Cancel button.
2. Insert the disk. If you are definitely having problems with the drivers on that disk, then download this updated driver pack. It is a zip file you must unpack to a folder.
http://blog.benjarriola.com/Vibra.zip
3. Click the names of the drivers and applications you want to install on your computer.
4. Follow the instructions on the screen to complete the installation. You may be asked, after an application is installed, if you want to restart you computer. Do not restart your computer until all the drivers and applications are installed.
5. Connect the webcam's USB cable to an available USB port on your computer and wait for Windows to detect the device.
6. When the Found New Hardware Wizard dialog box appears, select Install the software automatically (Recommended), and then click the Next button.
7. When a Microsoft warning dialog box appears, ignore the message and click the Continue Anyway button.
8.Installation will complete.
9. Check the image in the Video preview pane of the Vibra Webcam Camera Configuration dialog box. If it flickers or displays a series of dark bands, click the Cancel Flicker button.
10. Click the Finish botton, and reboot if necessary.
When you boot up, you can check the Device Manager (Control Panel>System>DeviceManager). Click the plus(+) sign next to the Imaging Device icon. The entry "Vibra Webcam" should appear.
Done!
Hope this helps :)
Chris (ziraffa)
Dec 21, 2008 | Creative Labs Vibra Webcam
Radio Communications Logo
539 people viewed this question
Top GN Netcom Radio Communications Experts
Tom Chichester
MrFixitSTTL
techmncpa
Level 1 Expert
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
