Question about Arrow T50P ARROW STAPLE GUN
WHERE do I open it to refill it?? - Arrow T50P ARROW STAPLE GUN
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Posted on Nov 12, 2010
To add staples to this Craftsman stapler do the following: 1. Where you see the words "Squeeze to open" on the stapler, place your thumb and index finger on the 2 plastic tabs (identified with 3 vertical plastic lines on each side of stapler) 2. Squeeze tabs inward/together and the refill stapler cartridge will slide out under spring tension but will not fully come out/away from the stapler itself. 3. At the bottom of the stapler, there is a channel where you will insert the refill staples. This channel is visible because the staplers reloader cartridge is slid out of the way. Insert the staples into the staplers reload channel with the sharp points of the staples are facing away from the stapler itself. 4. Under tension, push the reloader cartridge back into the stapler until you hear the 2 tabs "click" back into the stapler housing. 5. If the stapler reloader cartridge does not fully slide back into locked position, remove some of the staple bundle and reload the stapler cartridge.
Note: Staples are sold in various sizes and are not always compatible with every industrial stapler sold. Verify the staples are compatible with your stapler before purchasing. Good Luck!!
Posted on Nov 14, 2012
Drain and refill of New Yorker forced hot water furnace
drain raidaitor remove or open drain valve on heater unit then when refilling leave open til no air is in the line then refill
Nov 12, 2013 | Cars & Trucks
How do you refill roundup pump and go
The Pump N Go can be refilled with either the Roundup Super Concentrate or Roundup Ready To Use Plus Refill Bottle.
To refill the Pump N Go with the Roundup Super Concentrate (purple cap), add 6.5 fl oz of the Super Concentrate to container and slowly fill with water.
To refill with the Ready To Use Plus Refill bottle, just slowly fill the Pump N Go with the refill container.
We do not recommend using Roundup Concentrate Plus (red cap) to refill the Pump N Go because it has different active ingredients and different information regarding use around edibles.
To open to Pump N Go container, please follow the directions below:
Stabilize container by holding between your feet
While holding the pump handle push down slightly and turn left (the pump will be out of the locked position)
The first time it is opened it will be difficult to open because for shipping safety the top is but on very tightly at the factory.
If you have any further questions, please contact us at 877-465-5160.
Hilary @Roundup
Aug 29, 2011 | Roundup "" Weed & Grass Killer
The colored ink cartridge was refilled once and it worked well, now I'm refilling it the second time and it seems to not be responding anymore, assistance please, if there is any.
It is not recommended to use the refilled ink cartridges...But anyhow you can use the refilled cartridge once or twice if it is refilled properly...
When refilling the cartridge, the cartridge will be opened for refilling the INK...In this phase the Circuit in the cartridge may be damaged due to improper handling...
In this situation the cartridge has to be changed, No other go...!
Feb 24, 2011 | Lexmark Z640 InkJet Printer
Does ink refile is possible in canon ip 2770 printer?
Yes, Canon ink cartridges can be refilled. Most Canon cartridges can be refilled up to 12 times. Canon cartridges consist of a sponge and an open ink reservoir, so they can be refilled using a syringe.
Nov 14, 2010 | Office Equipment & Supplies
Cannot open it to refill it how do i refill the
On my unit, I have to go under the sink and unscrew the plastic bottle, fill it and then screw it back on to the pump from underneath. You might want to try that.
Sep 15, 2010 | Blanco Alta Soap Dispenser Satin Nickel...
Refilling the roundup pump and go container
You will find the answer here : http://www.scotts.com/smg/learn/infoHowToArticle.jsp?detailId=13400022 Mine locks with a part clockwise turn but to refill I open by turning counterclockwise. It's very tight.
Jun 17, 2010 | Roundup "" Weed & Grass Killer
Procedure to change manual transmission fluid, 1995 honda accord.
There are two plugs on trany , one drain , one refiil.
Lift car and level it , open refill plug , set aside.
Open Drain plug and drain the oil.
Reinstall drain plug.
Use sifon pump to pump oil in to refill hole.
Fill it up untill oil start coming out of refill hole.
Reinstall refill plug.
You are done.
Plugs are for 22 or 24 mm wrench.One at the bottom the other one at level of drive axle of the transmission.They are same size.
Jun 16, 2010 | 1995 Honda Accord
Toto toilet: refill valve opens and closes rapidly
I believe you have a high water pressure going to the
tank. Minimize the water volume going to your tank. This is done by fully closing the inlet valve under the tank. Then open about 1/4 to 1/3 of the inlet valve. To do this, count the number of turns to get it full close from full open position. For 1/4, divide the number of turns by 4 and divide it by 3, for 1/3 open. Hope this will solve your problem.
Nov 26, 2009 | Water Heaters
Refill Process of Samsung Toner
Dear sir,
  1. open your printer cartridge drum cleaning blade unite wast toner clean.
  2. open two side from your cartridge left side and right side
  3. open plastic cork
  4. filling toner
  5. assembling again
  6. start print
Aug 19, 2009 | Office Equipment & Supplies
Cartridge
This is independent of every printing ink type and there usually is good instructions with the refills you get for the ink cartridge.
Have you purchased a refill cartridge?
Assuming not - there are 2 options; one is to buy a replacement ink tank same as the one which has run out, the other is to buy refill inks which you "inject" into your existing cartridge.
Personally, I use refill inks, as the running cost is about 1/5th of buying new and I have a copious supply of print cartridges. Some people really don't like using refills, because it's easy to get stuck with a refill kit and the ink cartridge dies or heads become clogged, forcing you to buy a new cartridge anyway. Your gamble, ahh, I mean choice....
I doubt it's computer/CPU related, but, just in case, you could try going to Start>Control Panels>Administrative tools. Double-click on 'Services', a window opens that show all the optional services for your Windows, some running, some not. Scroll down to "Print Spooler" and across from that you'll see "Started", 'Right-click' on this and change it to "Stop". This stops any printing instances that are stuck, jammed, frozen, just will not go away. Now 'Right-click on "Stopped" and change it back to "Start", close your open windows and try printing again.
If you go to Start>Control Panel>Printers and 'Right-click' on the printer in question, go down to "Properties" and when that opens click on "Print a test page" button. If you machine fails to print, a dialog box/window will open to help you troubleshoot it - must admit the questions asked are very basic and it has never helped me but may open some ideas for you.
Please let us know how it went.
**.The best way to acknowledge contribution is to rate it's relevance.**
Jan 26, 2009 | HP Deskjet 3845 InkJet Printer
Arrow T50P ARROW STAPLE GUN Logo
2,202 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
