Question about Rival CF153-WM Deep Fryer
Replacement cord My cord has to be wiggled into a certain place to get it to stay 'on', so I'm assuming there is a short in it. My problem is where do I go to dfind a replacement for it?
    Problem Solver:
  • 18 Answers
It's probably dirty. Try saturating a cotton swab with rubbing alcohol, then swab the female end of the cord and immediatly push on and off the fryer pins a few times, then let dry and test. This should do the trick.
Posted on Sep 10, 2008
How to repair a short it a power cord on a front loading washing machine
have you checked the three places the power cord is bolted into the washing machine? if a nut is loose that could be causing the problem. If you have a shorted cable I would recommend buying a new cable they aren't that hazard!
Sep 28, 2015 | Kenmore Washing Machines
I had to replace a old cable it had a short.! Got a new one nothing happen.!it not charging period.!
Please tell us the make and model number so we can help. Normally a charger does not have a replaceable cable to the laptop - only the AC cord to the power plug can be replaced. I've purchased replacement adapters and the AC power cord doesn't work correctly in the adapter unless I push it in very hard or wiggle it to make a connection. Some replacement adapter also have a plug to the laptop that is not sized like the original and also needs to be wiggled to make a connection. Please provide the information if you still are having problems.
Oct 06, 2014 | Computers & Internet
No power getting to infinity interlude il100s
you have a nasty short cercuit in your woofer box due to constant mooving around or pulling the cords so get it fixed befor it costs you a lot more muney
Jan 12, 2014 | Infinity Audio Players & Recorders
Why my vacuum cleaner intermittently starts and stips while cleaning The dirt bag is not full.
The most likely cause would be a short circuit in the cord. Let the machine sit running in one place without moving it, and wiggle the cord to see if this is the problem. If it is, the cord will need replacement.
Mar 04, 2011 | Hoover Vacuums
Left side of headphone is partially working; I have to bend at a certain agle so I can get audio coming out. However right side is working perfectly
This is caused by a short circuit in the cord. If you can establish the location of the short by wiggling the cord back and forth in various places you might be able to cut the wire and splice a new length yourself. If you are comfortable with opening the case of the side that the cord connects to and it is obvious how to remove the casing, you should see the terminals inside for connection of the individual wires. You can replace the cord with a new one by soldering the 3 individual wires in place.
Note: Be sure to code the placement of the 3 wire terminals when you remove the old wires. This way you will not have the positive wire connected to the negative terminal, etc.
Oct 31, 2010 | Audio Players & Recorders
Laptop will not charge. After wiggling the cord
That's a short in the power input section of the motherboard- I've found, much to my dismay, that the power input/charging circuit on these laptops is not a separate circuit board as it is on some other models, but is a small area of the motherboard itself. You'll either need to have someone repair the motherboard or replace it entirely.
www.dfwsupergeek.com
Feb 16, 2010 | Gateway MT6705 Notebook
LG DLE2514W Power does not stay on. Power cuts
If you move the cord @ the outlet and the dryer shuts off replace outlet if the prongs on the cord are not damaged.
If you wiggle at the dryer side and it shuts off un plug the dryer remove acess cover and inspect end of cord. Ck. and make sure terminal nuts are tight. and not burnt due to a loose connection.
Jan 12, 2010 | LG DLE2514 Electric Dryer
Power Cord Slot Repair for a Gateway ML6230
First Of All.... STOP WIGGLING IT!!!!!!!!
WHat Your Doing is Shorting Out The DC JAck And Causing Further Damage Every Time You Wiggle It For A Connection....
Which Could End Up Ruining Your Motherboard....
Your Problem Is The DC Jack You Need To Have Yours Replaced... THis Involves Complete Disassembly Of the Laptop Down To The Motherboard, Then The Old-Bad DC Jack Needs To Be Desoldered and removed and a new one Soldered Into Place....
http://www.ifixlaptops.com
Nov 18, 2008 | Gateway ML6230 Notebook
Problem starting
This can happen if you have an intermittent short in your cord. Try plugging it in and then wiggling the cord around where it goes into the body of the vacuum with the switch set to "on." (If you're not sure whether it's on or off, just click it back and forth occasionally.)
If the motor kicks on there's a short, which usually requires a cord replacement. If that's the case, it's a relatively simple fix for most dyson models.
If not, you could have a short in your switch or somewhere else in the electrical system of the machine.
-R
Aug 10, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Rival CF153-WM Deep Fryer Logo
42 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ed Mac
Ric Shull
Ric Shull
Level 1 Expert
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
