Question about HP LaserJet 1020 Printer
Error Message: Operation could not be completed (error 0x000006ba). The local print spooler service is not running. Please restart the spooler or restart the machine. How do I restart the spooler? What happened to make it stop working?
admin734
  • 268 Answers
SOURCE: Print Spooler has stopped.RPC server unavailable
I can definitly help you out....it may take a few steps to narrow down this issue..so don't get frustrated! :-)
First lets start off by trying this:
Go to System Properties>Advanced
Select Performance>Settings
Select Data Execution Prevention
Select Turn on DEP for all programs and services except those I select
Click Add
Paste this in to the file name box of the window that opens:
C:\WINDOWS\system32\spoolsv.exe
Select Open
Select OK when you receive the warning
Select Apply
After doing that , follow my steps again for enabling the print spooler , let me know how that works
Posted on Oct 06, 2008
Basti
  • 1447 Answers
SOURCE: SPOOLER SERVICE IS NOT RUNNING
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
Pls Rate as Fixya if this helps, Thanks!!
Posted on Jun 26, 2008
Happy2Help
  • 59 Answers
SOURCE: Printer Spooler error 1068
Hi jbaratta,
This sounds like a software problem (in other words, your printer is not the issue). Here's what I suggest:
1) Save whatever you were attempting to print, and restart the computer. Try printing it again.
2) If it doesn't work, try uninstalling the software for your printer, and then re-install it. In the event you don't have the software handy, you can download the driver from this website:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
If it still doesn't work, please let me know, and I'll be happy to offer some more ideas. Hope this helps!
Kind regards,
H2H
Posted on Dec 16, 2008
kamal1984
  • 1383 Answers
SOURCE: HP Laserjet 1020 Spooler not starting
First uninstal old drivers then install again.
Then go to start menu then type in run "services.msc" then press enter
then you can seee right pane check there you find Print Spooler just double click on it then set
stratup type as automatic then click on depndancy tab then set restart the service .
then apply and ok.
Posted on Jul 15, 2009
SOURCE: HP Deskjet F300 Series Offline
my print is offline, how can I fix?
Posted on Feb 06, 2010
Printer spooler service not running
The spooler is not on your printer it is in the Windows folder on your computer and is used to hold documents whilst preparing to print.
Normally this service is set to start automatically and there are a number of reasons why it may of stopped but try this:
Right click on "Computer" in your Menu and then left click on "Manage".
In the page that appears click "Services and applications" and Click "Services"
Navigate down to "Print Spooler" and double click on that line.
A box should appear showing properties of the Spooler.
It should show
"Startup Type = Automatic"
"Service Status = Running"
If neither of these are true then change the Startup type to Automatic
and click on the "Start Button"
The service will then either start or tell you why it cannot start.
Nov 21, 2013 | LG Computers & Internet
Hi, my HP Laserjet 1020 is not printing. It gave me the error, 0x000006ba the printer spooler is not running. Please help!!!!
click on start and then select run
in the run window type in services.msc and hit ok
in the services local window look for print spooler
double click on it and start the process and also select automatic instead of manual or disabled... hit apply and ok and then try again
Mar 22, 2011 | Office Equipment & Supplies
Operation could not br completed. The print spooler service is not running
Hi There,
If your print spooler service is not running, then follow the below steps to get it working :
Step 1 :
* Start > run > services.msc > ok
* Select the service name called print spooler from the list.
* Check the status on the print spooler service, if it is stopped, then right click and select start or restart.
* Then the spooler service will start working....
Step 2 : ( NOTE :USE THIS STEP ONLY WHEN YOUR STEP 1 DOESN'T WORK )
In this case, we assume that the print spooler service is gone bad and we would have to recreate the spooler service.
* Start > run > cmd > ok
* Type: sc delete spoolsv (this will delete the corrupted spooler for us to create a new print spooler)
* Reboot the system and after rebooting the computer back.
* Type: sc create spoolsv (this will create a new print spooler service)
* Reboot the system and this time the print spooler service is a new and fresh spooler and it should work normal and perfectly.
Enjoy printing !!
Oct 22, 2010 | Office Equipment & Supplies
My print spooler service is not running
Try This :
Click on Start >> Run >> CMD >> OK
Type in SC CONFIG SPOOLER DEPEND= RPCSS
Press Enter
Then try to restart the compter
Then try to restart the print spooler this should resolve your issue
otherwise get me the exact error message you are getting
Regards
Sandeep
Oct 06, 2009 | HP Computers & Internet
"fatal print spooler error" error message
Completely uninstall the printer driver and install again. If this does not work, there is a corruption in the windows registry or in the print spooler cache files.
For a temporary workaround, disable print spooling. But, if you do, you will need to remember to never close an application you print from until printing is actually finished.
Jun 28, 2009 | Konica Minolta magicolor 5430 DL Laser...
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Operation could not be completed. The print spooler service is not running.
To fix the error message, in Windows XP, click on start, control panel, then administrative services. From here double click services and scroll down to print spooler and double click on the icon. Change startup type to automatic and click start below that and you are rolling. If the problem occurs repeatedly contact the manufacturer of your printer for best fixes.
Sep 12, 2008 | Office Equipment & Supplies
Operation could not be completed (error 0x00000005)access is denied
This worked for me. Go to control panel, look for printer in the hardware and sound section. click on it. Right clikc on it, and run as administrator. Cancel all documents, and that should be good.
May 01, 2008 | HP Officejet J5780 All-In-One InkJet...
PRiNt SP00lER
1. Go to Start > Run and type in services.msc then press Enter. 2. In the window that opens find "Print Spooler" on the right 3. Right-click "Print Spooler" and select "Properties". 4. Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service". 5. Make sure the 2 text boxes underneath say "1" in them. 6. Click Ok until you are back at the Services window, close it and you're good to go. 7. Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
Jan 08, 2008 | Dell A960 All-In-One InkJet Printer
PRiNt SP00lER
Try this FixYa for Error 1068.
Let me know how it goes.
Jan 08, 2008 | Dell A920 InkJet Printer
HP LaserJet 1020 Printer Logo
1,500 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
