Question about Vacuums
My swan steam generator iron s15040n is showing a push button when it is turned on. im pushing the button but it continues to say push and keeps beeping. the iron wont turn on at all. please help!!!!! thanks
  • 75 Answers
SOURCE: It won't keep a charge and it doesn't do anything
what kind of vacuum is it.
Posted on Jun 29, 2009
VacuumRepair
  • 438 Answers
SOURCE: Power Problem
Hi There,
Unfortunately this is being caused by static electricity building up in the electronic controls in the handle of the hose. I've seen this problem on numerious occasions, and in fact I have the twin brother of the Blue Moon, or the Silver Moon which used the same hose, and has the same problems in my own home.
The good news is that Miele has redesigned the hoses to fix this, and I have never seen a single problem on the newer style hoses. I guess the bad news is that the hose is not cheap.
I would recommend to you to go ahead and purchase the new hose. The average life expectancy of your Miele is 20-25 years, so you still have a lot of life left in your vacuum.
Here's a link to the SES125 Hose that fits your Miele Blue Moon on our website:
http://www.govacuum.com/miele-165.html
To change the hoses out, simply push the two tabs on the end of the hose that plugs into the vacuum, and pull the hose backwards until it disconnects. You'll see on the end of the new hose electrical connectors. Simply line these up with the opposity receptacles on the canister and push the hose down until you hear a snapping noise.
I really hope that this information was helpful to you. If you have any follow up questions, or would like a clarification, please use the comment box on this page.
If this was able to help you fix your machine, please be so kind and rate my repair or leave me feedback. This is really appreciated.
Thanks again,
Chris Jones
GoVacuum.com
Posted on Jun 15, 2010
  • 6 Answers
SOURCE: Dead shark in the water
Call them at 1-800-798-7398
Have the model number, the country it was made in and the date it was made. All found on sticker on bottom of unit. They are foreigners that answer the phone, so be prepared to spell everything. It takes 3 weeks to get the parts but I found them to be inexpensive.
Posted on Jan 30, 2009
SOURCE: push start button vaccumm won't turn on
I had a problem with my switch not working. The cheesy microswitch has a little nub on the back that breaks off. They kind of work like a ball point pen. I noticed that if I held my thumb against the back of the microswitch, it would click on and off.
Disassembly:
First, unplug the machine and disassemble the switch housing. There is a screw in the front. It takes a no. 10 Torx driver to remove it.
On the back there appears to be two little tabs that need to be pulled out. Don't mess with them! They are there to fool you. Instead, with a flat tip screwdriver, reach down past the tabs and pry inward (the handle of the screwdriver moves outward, the tip prys inward).
On the front is a little tab that needs to be gently pryed down. The unit should slide out.
With your thumb against the back of the switch, press the button. If it seems to be staying down on one stroke and popping up on the next, continue reading. Otherwise, you may need a new switch.
Now for the fix/jury rig:
With the plastic housing set aside. Put all the wiring and switch in it's place on the vacuum. The switch has grooves that allow it to slide onto the vacuum. Everything should go in neatly.
What you need is a thin piece of wood or plastic, about 3/4" long and 1/2" wide (a popsicle stick would probably work). Slide it between the bottom of the switch and the molded plastic on the vacuum. Make sure it is snug. Try the switch. It should be working now.
Now carefully slide the housing back on. I like to depress the switch first. Make sure the housing snaps back on. It takes a bit of force, but it should slide fairly easily right up to near the vacuum's face. If not you may want to make sure you're not interferring with any wires etc.
Good luck,
bentod
Posted on May 02, 2009
geterrollin
  • 277 Answers
SOURCE: I have a bosch generator
I would empty the water out and attempt to flush it out and steam some C.L.R through it
Posted on Jan 21, 2011
Swan steam iron
I have exactly the Same problem please someone help!!!
Jan 11, 2014 | Vacuums
How do i descale a SWAN iron model no S15030N. CAN I PUT DESCALER INTO WATER STORAGE TANK
The best and cheapest way to descale irons,steamers, etc. is to use white vinegar, mixed 1 cup to a quart of water. Pour in the iron and allow to steam. The vinegar will dissolve the calcium, which is the blocking scale. Do this a few times toensure that the holes are clear and operating correctly. For the last rinse, put a little lemon into plain water and allow to steam. This gets rid of any vinegar smell.
Jun 09, 2011 | Vacuums
I have a swan steam generator model s14021 and its all working but when you press button to get steam water pours out!
Dont know the model ,but steam is water and if water pours out than the steam heat portion isnt getting hot . Probably a heating element out
Feb 17, 2011 | Vacuums
I just bought a Tfal Ultimate Autoclean iron FV 9450. I am reading through the manual and trying to figure out all the parts and functions. I cannot figure out how to remove the anti calc valve. I...
Anti-calc valve wings (grip) located at #3 of the 1-15 labeled description diagram that is part of the instruction manual. The wings are on either side of the dry/steam control #4. Lift up on the wings (grips) and the dry/steam control will accompany it. The anti-calc valve is under this control. It's easy once you realize where the silly thing is actually located.
Jan 15, 2011 | Vacuums
I am looking for a cap for my tefal pressing profile steam generator iron model 2880 can you help
Did anyone help you with this? Did you find - I also need one!
Sep 27, 2010 | Vacuums
Safety cap on the Euro-Pro dexuxe steam cleaner style SC507H
if it is anything like mine...you push the cap down, give it a full turn & release. keep doing this (maybe 5 or more times, and eventually it will start unscrewing easily without needing to push down
Oct 24, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Vacuums Logo
114 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
