Question about Insignia 37" LCD Flat-Panel HDTV
Dark colours appearing white
The black or very dark colours on our TV picture appear white. Not sure what the issue is but people's eyes will be all white in the centre and anything black will be white etc.
I have the same issue
Posted on Jun 28, 2008
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
Installed a new set top box last night and all the channels are black and white - no colour at all - confused!!
vron63
Check your cables between the receiver and your TV to make sure the colors match. If you are using a component cable (green, blue, red, white, red), not matching colors at both ends will give you what appears to be a black and white picture. I hope this helps.
Ray Calo
DISH Network
Mar 09, 2011 | Televison & Video
My Sony Bravia has no colour, and the black and white is so dark you can't see the picture. It is less than 1 year old model # KDL-46S5100
If the picture has no color or appear as black and white only, please reset the picture setting. To reset picture setting please follow the items below:
  1. Press MENU button on your remote.
  2. Press arrowtb.png to select setting.jpgSettings, then press ok.png.
  3. Press arrowtb.png to select picturemenu.jpgPicture Menu, then press ok.png.
  4. Press arrowtb.png to select Reset, then press ok.png to reset all the Picture Settings except Picture Mode and Display Mode to the factory settings.
If this does not not work, then change the picture board in your TV.
Please rate my solution.
Good luck.
Jun 27, 2010 | Televison & Video
Muddy prints
I have the R2400 and the photo prints look muddy. I have tried the same picture on another printer and the colors are vibrant. Why the muddy pictures on such a nice printer?
Mar 23, 2010 | Epson Stylus Photo R2400 InkJet Printer
Black holes where eyes should be
It sounds like your colour sensor is having issue deciding what colours should be what. To test this, take a picture of something else white, first try something large like a cloud or a white pillow from close up, see if it comes up black. Then try something like an egg against a different colour background, something skin toned would work best, or use yellow. If those come up white, you've got me stumped, but it is likely they will appear to be black.
Dec 08, 2009 | HP Photosmart R727 Digital Camera
Television picture fault
sounds like an issue with the tube but you probably wont be able to fix it on your own, i would take it by an tv repair shop, they will determine if its repairable
Aug 06, 2008 | Sony Televison & Video
Purchased a sony DSC-T70 and having a problem with the picture colour. it appears red. red eye is off. what could the issue be.
White balance set to AUTO? Special effects disabled (solar, sepia. etc)? Both of these are availanle in camera MENU.
If these ar ok then camera needs service by qualified camera shop.
May 19, 2008 | Cameras
Try # 2... Green Fog
The green gun in your picture tube is set a little too high. If you are experienced in removing the back cover of TV's,etc., you may try to find the drive and/or bias controls either on the circuit board that plugs on to the neck of the picture tube or mounted on the main circuit board of your TV. These controls are usually labeled. If you can find them, locate the green bias or drive control and back it down a little while watching the picture through a mirror. A slight adjustment may correct your problem.tJIS IS CALLED GRAY SCALE ADJUSTMENT. BE CAREFUL THERE ARE SOME HIGH VOLTAGE CIRCUITS NEARBY. WORK WITH ONE HAND AND USE AN INSULATED TOOL TO MAKE ADJUSTMENTS I hope this may help you.AGAIN BE CAREFUL!! Stargazer
Feb 26, 2007 | Toshiba 32HFX71 32" TV
Insignia 37" LCD Flat-Panel HDTV Logo
87 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
