Question about Brother Sewing Machines
Brother's Charger 661. How to thread it.Thread cintinues to break from sewing spool.
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: Brother 1034D
You either have a burr on one of the loopers, or you have threaded the loopers in the wrong order. I do not have this particular serger, but with mine, if I the lower looper thread is looped above the upper one(down where they all meet), it will break. Cut your lower looper thread and re thread it making sure its above the lower looper one.
Posted on Jun 12, 2008
SOURCE: My brother sewing machine jams threads under the
hi there, why is it that i can't sew at all..both thread are not working instead eating each other thread under....but i have a good brother ls 2125. ty...
Posted on Mar 19, 2009
  • 9 Answers
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
  • 7 Answers
SOURCE: my brother 2125I sewing machine
You may be sewing too fast, using cheap thread or your tension is off. All of which can cause your bobbin thread to break.
Posted on Aug 16, 2009
Why does my thread keep breaking on my brother ce4000? The machine is 100% threaded correctly new needle properly wound bobbin, I just don't know what could be wrong with it.
Could be a multitude of things. Use only good quality thread--no old or bargain bin threads. Try a different brand of thread--some machines prefer certain brands over others. The needle and thread should be compatible--ie needle eye shouldn't be too small for thread weight. Burr catching the thread and breaking it. Upper tension too tight.
Remove the upper thread, RAISE the presser foot and rethread from the beginning. Verify the thread is not looped incorrectly in the thread path, like around a thread guide or around the spool pin. Is the thread snagging on the thread spool itself? Do you see the thread tightening as you sew and eventually it breaks? This indicates it is catching somewhere between the needle and spool. Is it shredding at the needle eye? This indicates the needle eye is not suitable for the thread being used.
Watch where the thread is breaking. This will sometimes give you a clue where the problem exists.
Sewing Machine Problem 1 Thread Breakage
Why Does My Thread Keep Breaking While Sew
All About Needles
Jan 26, 2017 | Brother CE4000 Computerized Sewing Machine
Brother 661 charger keeps breaking the thread on the needle when it goes down in the machine
Install a new needle. Remove the thread from the upper threader. RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the tension to the midway point.
Jan 19, 2017 | Brother Sewing Machines
How do I stop my tread from popping on my Brother (17 stich) sewing machine?
Breaking thread? Presumably the top thread? AVOID old or bargain bin threads. The upper tension is too tight or the thread is not properly seated in the tension disk, the needle is defective or the needle, needle eye/scarf is not the best choice for the fabric/thread being used, there may be a snag in the bobbin area that is catching the thread. Make sure the thread is not catching on the spool's thread notch.
Why is my thread breaking
Dec 07, 2016 | Brother Sewing Machines
My Brother PE 770 will work for about a minute then the upper thread will get so tight that it will break. How do I fix this?
Check that the thread has not wrapped around the thread spool pin or one of the thread guides. Something is holding the thread from unwinding from the thread spool. Old style thread spools also have the small slit to hold the thread tail which will tend to catch the thread (turn the spool over). Sounds like the symptoms I've experienced with this problem.
Aug 23, 2016 | Brother Sewing Machines
Brother exedra E-40 why it alway get tangle and brake the threat?
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 05, 2014 | Brother Industries, Ltd Brother Sewing...
Brother pc 8500 upper thread breaks
Check the spindle the thread is mounted on and see if it\'s wrapped around it. Sometimes thread will catch and wrap around the spool spindle and break.
Check thread guides to be sure there are no nicks that might be catching the thread or damaging it.
Replace the needle.. a burr in the eye can cause upper thread to break. Needles should be replaced often, modern fibres can be hard on them, they get dull and that\'s no help for anything either.
Make sure the thread spool is mounted on the spindle with the thread coming off as directed in the manual. Some machines only work when the thread feeds in the right direction from the spool.
It can also be a tension issue.. tight upper tension or tight bobbin tension. Bobbin tension may be adjustable manually, but it\'s pretty rare for it be a problem. Upper tension, I don\'t know. I\'ve yet to get into computer machines so am not familiar with how they set upper tension.
But the mechanism that produces the tension can wear out or break and need replacement.
Jun 25, 2014 | Brother PC-8500 Pacesetter Embroidery &...
My LS2125i will sew a straight stitch but when I turn it to a zigzag stitch it takes a couple of stitches, then all of a sudden the top thread on the spool holder goes... whirl and winds the thread around...
sounds like your thread is getting caught in the thread spool's thread keeper notch. Make sure you use the spool holder disk with the closest size to the spool of thread to help prevent that. This is pretty common with old fashioned spools like coats and clark spools.
My brother suggests that i make sure the spool unwinds in a certain direction. You might check your manual to be certain the thread is unwinding the correct way.
Good luck.
Dec 18, 2010 | Brother LS-2125 Mechanical Sewing Machine
Brother 8500D sewing/emb machine - upper thread stops feeding
If the thread is hanging up at the spool - this could be the way it was manufactured, a nick in the spool end or the thread is unwinding too fast, puddling and wrapping around the spool pin.
Keep the bobbin case and surrounding area clean and free of thread tangles and snips. Thread tangles in this area can cause the machine to stop.
When the presser foot is down on any sewing machine, the tension closes and you cannot manually pull the thread through.
Sulky and C & C black tends to fray more than other brands of thread.
If the problem continues, the machine will need to be serviced by a professional.
Feb 24, 2010 | Brother Sewing Machines
Breaking threads... you so about an inch and it
It sound like it is not threaded properly or the tension is too tight, You should be able to pull on the thread manually without breaking it
look for your manual here
http://www.brother-usa.com/manuals/default.aspx?ProductGroupID=3
Jan 22, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
336 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
