When I push my forward or back button on my 750 carousel projector I just get a hum noise, carousel does not move. I just replaced bulb, can see slides if I put in individually. Any suggestions?
    President:
  • 412 Answers
The "hum" you hear is the cycle solenoid. Its normal movement is somehow being restricted, thus preventing your projector from cycling. Given the large number of possible solutions (or causes), I would consult with an Authorized Repair Dealer to minimize time and parts expense!
Posted on Nov 12, 2010
Lift gate tray
No. The slide tray should rotate when the forward or reverse buttons are pushed. Slides are not required for correct actuation of the tray. Before attempting any adjustment, try a few different trays (it may be a tray issue!). A 140-slide tray will be much tougher to get correct movement from than with a 80-slide tray on an older slide projector.... The 140 tray pushes the interface specification between a tray & a projector to the max.
Oct 13, 2013 | Kodak Carousel 4400 Slide Projector
My kodak carousel auto focus 760 carousel does not move but the projector makes a noise when I press the buttons how can I get it to move
Your Carousel 760 Slide Projector is about 45 years old. One of the problems I have seen as Carousel Slide Projectors age is that the plastic parts in the projector get brittle and break. Given your description of the observed condition is that probably either the gear on the focus motor shaft or the gear it interfaces with (or both) that is broken. Given the age of the machine, parts will be tough to locate. Try: www.micro-tools.com
for the best chance to locate those parts. Good Luck !! Jim
Sep 07, 2013 | Kodak Carousel 4600 Slide Projector
How do I get my carousel to move on my kodak 760 it makes a noise when I push the buttons but it wont move how can I fix it
Hi - I buy and sell these projectors all the time, but don't know this one - is it similar to the Ektalite?
The select bar on the projector is not working.
The Carousel 600 Projector is at least 45 years old!! Great to hear it still turns on!!
Because the 600 has no forward or reverse buttons, forward is accomplished by "tickling" (very lightly push) the Select bar. If you can cycle it forward and no Select, then you need to adjust the cycle solenoid to find the balance between forward and select. If you have NO forward, then chances are either the cycle solenoid is WAY out of adjustment, or the LINK between the CYCLE SOLENOID PLUNGER and the CYCLE LEVER is broken. You should still be able to order the LINK from: www.micro-tools.com
Good Luck !! Jim
May 19, 2013 | Kodak Carousel 600 Slide Projector
Kodak 850h
Your projector most likely has a broken Link, which connects the cycle solenoid plunger to the cycle lever. The buzzing you hear is the cycle plunger in the cycle solenoid. This is a quite difficult repair for a trained tech. Parts are available at: www.micro-tools.com I suggest you contact an authortzed repair dealer to make the repairs.
Oct 19, 2011 | Kodak Carousel 4400 Slide Projector
Slides will not advamce when you push lever. It is 50 yrs old.
The KODAK Carousel 4600 was manufactured from 1981 to 2004. If the tray won't advance with the push button on the projector, but will reverse, then it is a contact problem under the handle. If it doesn't cycle in forward OR reverse, but the "SELECT" feature does work, then there is a problem with the cycle (orange) wiring or the slide-change mechanism requires an adjustment. If forward, reverse and select ALL don't work, chances are the low-voltage side of the power motor is no longer providing the required voltage. An authorized repair dealer can help you sort this out.
Oct 14, 2010 | Kodak Carousel 4600 Slide Projector
I bought a used kodak 650 carousel slide projector and i can't get the slide tray to load. Is it because it came with a 140 slide tray instead of an 80 slide tray?
The KODAK Carousel 650 was manufactured approximately between 1964 and 1971.
Try removing the tray and pressing the cycle button(s) on the side of the projector. Watch the levers in the cut-out on the top of the projector. The lever closest to the rear of the projector should move back & forth (as you actuate the cycle buttons). The lever toward the front of the projector should extend and push forward (front of the projector) when you push the "forward" button, & extend and push toward the rear in reverse. If you are not seeing these levers move as described, then the chances of your projector needing a repair are likely. The good news: parts are still available. The bad news: You will have to find a factory-trained repair dealer to make the repairs for you.
Aug 10, 2010 | Office Equipment & Supplies
Carousel does not turn. Cord remote does not move it. Forward and back pushbuttons on case do nnot move it or make a sound
Because you don't specify a model, I will assume it is an older generation, manufactured in the 60's or 70's. These series had a part called the "link", which was made of plastic. This "link" connects the cycle solenoid to the slide change mechanism. With age, the "link" becomes brittle & cracks, rendering slide change non-functional, regardless if you use the side buttons on the projector or the remote control. This is a difficult repair, but the parts are still available. I recommend you contact a factory-trained repair dealer to fix your projector.
May 20, 2010 | Office Equipment & Supplies
Kodak Carousel 760H wont advance or reverse
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
56 people viewed this question
k24674
jasbo
jasbo
