Question about RCA OPAL M4001 MP3 Player
Boot error Hi. My RCA Opal mp3 player keeps saying boot error! Please format unit. Do you know of any way to fix it? Thanks Becky
  • stackb Jun 19, 2008
    I still cannot get my mp3 player to stop saying boot error! please format unit. I have tried dowloading the software to fix it but that hasn't worked either. Are there any other solutions to fix it?
    Thanks
    Becky
    Genius:
  • 3,422 Answers
Reformt the player:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
(source:fixya's MP3 doctor)
Please don't forget to rate the soltuion.
Goodluck..
Posted on Jun 19, 2008
    Master:
  • 638 Answers
Reformt the player:
    Guru:
  • 1,894 Answers
I seriously suggest u to upgrade the firmware for that product.
if that does not work u wil have to take to a service center and flash the memory and then upgrade the firmware again
i think only this can solve the problem.
reinstalling software wont help much.
because here boot.ini file is missing.
  • dewan nafees ahmed Jun 19, 2008
    here is how it goes.
    the symptoms must be like this.
    if u connect it to a computer u must be able to detect the hardwarre and u must be able to transfer songs also.
    but the device wont start individually.
    why because...
    while connected to computer the device synchronizes with the computer and does not boot.
    and thus it does not need a boot file.
    i shall tell you that this solution is going to be negative. and hence if u cant digest the bitter truth please dont read the solution. (i shall request u to ignore my last post)
    The original CD has no USB driver program so it doesn't help at all.
    There is a firmware upgrade program on RCA website for M4001. However,
    when you have a 'boot error' on your unit, the USB connection is not recognized by Windows also and the firmware upgrade program does not work
    either. So there is nothing you can do as a customer. The RCA customer
    service tells you to send it back to them, with all the accessories and a copy of the receipt and promise to swap/fix for u.
    source : fixya co experts.
  • 2,071 Answers
Sometimes this kind of unit needs to reheat or resolder the IC,that cause of the error because the solder that holds the IC is crack already.,after reheating clean with contact cleaner or laquer thinner is good for electronics like this.
Posted on Jun 18, 2008
  • 1,183 Answers
Need some additional inputs from your end to give you a correct solution .
1. Did try transfering songs on to it from a MAC computer or I-tunes software.
2. The problem happened when you unplugged and replugged it in your system
3. Is this device working on any other system other than yours
4. Have you tried formatting it.
You can answer all there questions YES and NO and i would let you know what would be the best course of action
Regards
Proton
  • Mandeep  Singh
    Mandeep Singh Jun 18, 2008
    Connect the device , to another computer check if its working there. If yes , the problem is with the operating system in your computer. If the device doesnot work on the other system, the flash memory in the device has gone bad. Genrally all flash memory devices come with 3 yr warranty.
    Proton
  • Mandeep  Singh
    Mandeep Singh Jun 19, 2008
    As I wrote, in my earlier post, if the unit is not working after the format too, kindly contact manufacturer to check if its in warranty and get the same replaced or repaired .There is nothing to open physically on the device and repair it at home.
    Thanks
    Proton
    Sergeant:
    Champion:
  • 347 Answers
Hello Stackb,
The solution for your problem, is as the hardware say, a reformat.
To do this you have to connectitthe MP3 to the computer. Then once it is detected, go to MY PC and right-click over your removable harddrive (mp3), and choose format.
Once you have formated it, you should click on this link to downloadyour MP3 firmware and then it should work again.
*note: your music and information will be lost
http://download.rcaaudiovideo.com/downloads/OPAL_4GB_8GB_FWUtility_v1.2.8.0.exe
Good luck, and if you need anyother help let me know
Dahaka
  • 1 more comment
  • Santiago Vallejo
    Santiago Vallejo Jun 18, 2008
    @proton77
    Does his MP3 uses ITUNES? How come, i tought that was only an option for Ipods....
  • Santiago Vallejo
    Stackbak,
    I strongly recomend you beforeoverheating your MP3and cleaning it with contact cleaner, to reformat it the way i told you to in the previous post, and then reinstall the new firmware.
    If you have anyother doubt, dont hesitate on telling me.
    Dahaka
  • Santiago Vallejo
    Santiago Vallejo Jun 19, 2008
    Hello Becky,
    Did you already try what i suggested you?
    If you did and that didnt help, let me know
    Dahaka
    Sergeant:
  • 243 Answers
Did you try formatting it? Don't do it yet I am only asking.
Keep me updated,
Lee
  • Nathan Ayers
    Nathan Ayers Jun 18, 2008
    Use the auto updater to get the latest firmware
    Firmware:
    Opal M4004, M4008, M4018, MC4004, MC4008 and MC4018 Firmware
    If
    you are experiencing difficulties with your Opal device and believe
    your firmware may be corrupted, use this file to restore the original
    (OEM) firmware.
    Firmware v1.2.8.0 Enhancements:
    • Enhanced voice recording performance
    • Enhanced battery charging capabilities
    Firmware v1.2.4 Enhancements:
    • Improved charging compatibility with Windows™ 2000
    • Improved user experience when shutting down
    • Improved the functionality of the “Menu” button
    • Added device screensaver (visible when connected via USB)
    Video Converter:
    RCA Video Converter v1.6.2.0
    The RCA Video Converter software helps you convert your favorite videos into a supported format for use with your new RCA Gem Line player. With its intuitive interface, all you need to do is select and go. This software presently works ONLY with the RCA M4004, MC4004 and M4008, MC4008, M4018, and MC4018 series of players
    http://www.voxxsupport.com/images/downlo...
    This is the link to the auto updater
  • Nathan Ayers
    You need to format the device and install the firmware. If after installing the firmware you are still having the same problem. Then the device is defective.
    I hope you
    will take the time to appropriately use Fixya's rating system since the
    question and rating system go hand in hand.
    THANK YOU,
    NATE
  • 1,879 Answers
Hello : you need to visit their site for updates, here's the link
  • monk3ybidzness
    monk3ybidzness Jun 18, 2008
    After installing the firmware package in the PC, you'll get an install
    screen for the new firmware with a format option for the OPAL. Select that option, If the "Start" button is grayed-out press the reset button at the
    back of the OPAL for about 15 seconds, then hold down the "Play"
    button and wait. Eventually the software will recognize the OPAL and
    will start to format it.
    If you get a dialogue to restart the PC, press NO! You have to
    read the instructions that come with the installation. Eventually It will format the drive and install the new firmware.
M4008 Opal mp3 player error message
i dont now either if u find out will you let me now thanks jodiestar1@live .ca
Jun 03, 2009 | RCA M4008 MP3 Player
RCA Opal Says Boot Error Format Unit.
Then you need to format the memory, If the computer doesn't recognize the device then it is defective.
Jul 25, 2017 | RCA opal MP3 Player
Mp3 player says boot error please format
i just downlouded a few songs went to see iff it worked . Now it says boot error please format unit
Feb 12, 2009 | RCA M4008 MP3 Player
My rca mp3 player started saying boot error please format unit what do i do
I had the same probleme, go into your COMPUTER files, then into you mp3 file mine is calle M51series, right clic, format.
Oct 17, 2008 | RCA OPAL M4001 MP3 Player
Rca mp3 opal
your boot file is corrupt so it wont boot u will need to use a computer to format it. plug the mp3 player into ur computer go to my computer right click the mp3 player and select format. Format will wipe everything off ur mp3 player
Jul 15, 2008 | RCA OPAL M4001 MP3 Player
RCA OPAL M4008 MP3
Mine has the same problem too, it says boot error, I format the unit, nothing happens. Dang!
May 29, 2008 | RCA OPAL M4001 MP3 Player
Boot Error please format unit
my rca mp3 player started saying boot error please format unit how do i fix this so i can hear my music again
Mar 19, 2008 | RCA OPAL M4001 MP3 Player
Won't turn on saying boot error format
what if the reset button didn't work, because mine still says "boot error please format unit"
Feb 10, 2008 | RCA OPAL M4001 MP3 Player
Boot error! please format unit
It might be cause by a corrupt firmware. You need to have a utility that restore the mp3 player to its original setting. i had exactly the same problem with my ipod shuffle 1st generation 2 years ago. Good thing Apple has that utility for me to download and until no it is still working. Try to visit and upgrade the firmware using this link for you mp3 player http://support.rcaaudiovideo.com/downloads.aspx?product=192
Please Rate Appropriately Thanks!
Jan 14, 2008 | RCA OPAL M4001 MP3 Player
RCA OPAL M4001 MP3 Player Logo
172 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
