Question about Watts Onan Portable Generator - 4000 , Model# 5500
It will not charge the starter battery. - Watts Onan Portable Generator - 4000 , Model# 5500
    Genius:
  • 1,015 Answers
Do you have a volt meter so that you can check battery output when unit is running. The charge rate on most small engines is about 3 amp so it will not charge very fast. If you have a battery charger I would disconnect negative cable from battery, check voltage on battery then hook up charger for a couple hours. Recheck voltage.Then leave battery neg. cable off overnight and check voltage again the next day.You may have a bad battery that wont hold charge. If it holds charge overnight then I would hook neg. cable back up and leave set for a day or two and recheck voltage. If voltage has dropped then you have something draining battery. Before I did anything to drastic I would clean all connections to battery and starter switch. If your system is really not charging you will have to replace starting diode. Good luck.
Posted on Nov 12, 2010
Riding mower won't start & makes clicking sound when I turn key over
MAKE SURE BATTERY IS CHARGED IF IS THEN JUMP LAWN MOWER AT STARTER IF STARTS BAD BATTERY ARE STARTER RELAY COST 60.00 I STILL THINK YOUR BATTERY IS BAD OR DEAD NOT ENOUGH CHARGE IN IT
Sep 01, 2014 | Garden
Why my 2005 saab 9-3 Turbo won't start?
Check that you're getting charging current to battery. Voltage at battery terminals should read about 14.5 volts (well above 12 volts in any case). If not, a bad alternator may be failing to provide your battery with a full charge. If charging is good, and battery holds its charge, other possibilities are bad wiring connections to starter solenoid and/or starter motor, or bad ignition switch assembly.
Jul 29, 2014 | NRS S129 - Starter Solenoid Switch, D984
Car wont start has charged battery lights and radio come on new starter. drainging battery even though the battery is fully charged its reading its not tempature gauge reading hot but its not runn
If the problem began when (or soon after) installing the new starter, start checking there. Ensure that all cables to the starter are tight. As a second possibility, if the new starter was actually a rebuilt replacement, the solenoid could be faulty. (I went through three rebuilt starters on my son's truck until we got one that worked properly.)
Mar 06, 2014 | 2004 Ford Mustang GT
How to tell if it's the battery starter or alternator
Do the proper testing of the
battery,starter and charging system
Mar 27, 2013 | 2004 Ford Taurus
Car won't start without being charged and when it sits overnight it wont start. makes a clicking noise when trying to start it
Battery is to weak & not holding charge. If the battery does not have enough power the starter will make a fast clicking sound or you will just hear one click.
Feb 06, 2012 | 2000 Chrysler Cirrus
My cars Battery is 95%fuly charged charged but starter wont turn over where is the fault .starter or altenator
Not the alternator. If the battery has a sufficient charge, the start should turn regardless of the condition of the alternator. Try using a battery charger to be sure battery if at 100%.
Are your battery terminals clean, no corrosion and attached tight?
If starter still will not turn, problem could be wiring or bad starter solenoid.
Feb 06, 2011 | 1995 Nissan Maxima
My 1993 cadillac eldorado is cranking slow and i just change the alternator
If the battery is fully charged but the starter is slow, the starter may have an internal short or may just be worn out. Make sure your battery is fully charged and the battery terminals are clean and tight though before buying a new starter.
Sep 08, 2010 | 1993 Cadillac Eldorado
Battery is charged but the starter bareley turns
If the battery is fully charge, yes, the starter assembly is worn out, replace starter assembly.
Jul 19, 2010 | 1993 Oldsmobile Cutlass Supreme
My deauville doesnt start even after a 2 mile run
It's one of these things: The battery. Especially if you're still using the original one, which is now almost 10 years old. The charging system. Or the starter relay.
Even if your battery isn't 10 years old, if it has sat for more than a month or so without being charged, then it is toast. A fully charged 12 volt battery should show about 13.5 volts on a volt meter.
If the battery is good, then you will need to find out if the charging system is working. To do this, you will need an ampere meter capable of reading up to 10 amps. Start the engine and THEN hook the amp meter in series between the battery (either side) and the cable going to the battery. With the engine revved up to around 4,000 RPM, the charging system should be putting out at least 5~6 amps.
If it isn't the charging system or the battery, check for a bad starter relay (the thing that makes that buzzing sound when you hit the starter button). Perform this test by bridging across the two large cable connections on the top of the relay with a large screwdriver. If the starter spins when you do this, then you've got a faulty starter relay. If the starter doesn't spin, then you've got a bad starter motor or a bad electrical connection going to it.
Dec 29, 2009 | 2000 Honda Deauville NTV 650
Possible Alternator
have battery and charging system checked. you may have a bad starter.hope this helps.
Oct 14, 2009 | 1997 Buick LeSabre
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
314 people viewed this question
Top Watts Electrical Supplies Experts
Steve
Jim London
Jim London
Ottoniel
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
