Question about InFocus Proxima DP1000X Multimedia Projector
Dim display. Lamp change did not help - InFocus Proxima DP1000X Multimedia Projector
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Most likely the light tunnel has collasped and will have to be replaced by a tech. Save you old lamp because it is probably still good. The light tunnel being collasped is obstructing the light but also not focusing the light into the engine as designed.
Posted on Nov 15, 2010
Satellite M105 S322 Display very Dim. The PC works fine with external monitor but the LCD display is dim and cannot see anything on the screen
You have lost your backlight which is a thin long bulb built into the bottom of the screen itself. You have the option of getting the backlight by itself and rebuilding the screen or buying a new screen assembly and changing that out. Below is the service guide to change the screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M105/take-apart-notebook-1.htm
Below is a general guide for display problems....
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Oct 27, 2009 | Computers & Internet
The screen of my laptop turns to black
You could have a faulty CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 06, 2009 | Toshiba Satellite Pro S300-EZ1511 Notebook
My sony vaio vgn-n365e screen is Dim
The fault could be a faulty CCFL lamp or inverter.
Check out
www.lcdparts.net
Jul 24, 2009 | Sony VAIO PCG-K23 Notebook
Acer Aspire 5735 LCD changes bight-dim-bright, etc.
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jun 24, 2009 | Acer Aspire 5735 Notebook
Dim display on Toshiba Satellite 4090XDVD notebook
The backlight CCFL lamp provides the lighting for the LCD screen. If you have already adjusted the brightness to the max. setting and it is still dim, it means the CCFL lamp is is nearly worn out. To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp. Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 18, 2009 | Toshiba Satellite 4090XDVD Notebook
Dim display ... no backlight
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
May 30, 2009 | Toshiba Qosmio G25 (G25-AV513) PC Notebook
The left side of my Dell inspiron screen is darker than the right. Changing the brightness only changes the brightness proportionately. any suggestions
You could have a defective screen - a defective inverter or a CCFL lamp.
  • Picture flickering with dim display.
Apr 29, 2009 | Dell Inspiron 1525 Laptop
THE SCREEN OF MY LAPTOP (ASUS)TURNS PINK.Can anybody help me to solve this.
Defective CCFL backlight may has the following symptom:
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 14, 2009 | Acer Aspire 5630 Notebook
Hp laptop 9720us screen wont brighten or dim. last week my screen went blank brought it to a shop they changed the inverter and also some cable connection . works fine just not quite as bright as before ....
You got the wrong inverter fitted - i'm sure your unit requires a sinle lamp inverter and they have cheated - putting in a generic lamp inverter and branching togeather the wires to accomodate the single plug thus reducing the available volatage for the lamps - this is why it's dim - correct part is 431391-001 Display panel power inverter - For use with single lamp display panel
Mar 10, 2009 | HP Pavilion DV9720US Notebook
My laptop, hp compaq nx6110 has a screen problem. Its dim
OS?
Check the "Power Options" in your "Control Panel" (classic view). For whatever option you have picked, click "Change plan settings". There you can either "Restore default settings", or manually "Change advanced settings". If you choose "advanced settings", look for "Display" / "Display brightness".
Feb 26, 2009 | HP Compaq nx6110 PC Laptop
InFocus Proxima DP1000X Multimedia Projector Logo
102 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
