Question about HP Media Center m1080n (PC099A#ABA) PC Desktop
When turning on my hp media center m1080n the power button sort of stick and then turns itself back off. i have to keep trying to turn it on before it will stay on, any idea what problem could be.....i am thinking it is the power button itself....
  • 221 Answers
SOURCE: HP Media Center PC m7250n will not power up
hold the start button in and check the back of the case to see if the power supply fan turns while the power button is depressed. If it turns while the button is pushed, but then stops when you let off the button, then the power supply is probably bad and needs replacing.
Posted on Jun 01, 2008
chrlygrn
  • 149 Answers
SOURCE: HP Media Center m1080n PC... Problem
If you have the original restore disk, you could try and fix it. But if you have an actual copy, you can go to install it but when it propts you click repair. It should go into a dos mode, and then type fixboot, (this is for if the computer comes to the boot logo and then crashes and shows boot logo again, or if it comes to the blue screen of death) and hit enter. also if prompted, you could try last known good configuration.
These are some methods of fixing your computer without erasing all data!
Cheers and Please Rate!!
Posted on Jul 17, 2008
prayag_78
  • 43 Answers
SOURCE: hp media center power
hi friends, unpluug the power chord from the wall jack after that press and hold the power button in the front for about 15 seconds, connect the chord back in and try it. if it does the same then look at the rear side of the cpu box (where the power chord goes in and look for a small fan inside the power supply box, it has to be spinning). if not then the power supply (smps) has goen bad. now if the fan is sipnning try disconnecting all the extra periferals eg printer and stuff, still nogo then try opening the cpu box (reffer owners manual). take the RAM out and try to power up the system, if it starts beeping like beep ...beep... peeeep... then turn it off put the ram sticks back in and it should work fine...
NB:-for the owners manual check this out: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&product=470506&lc=en&jumpid=reg_R1002_USEN
Posted on Jul 22, 2008
rockitman187
  • 2559 Answers
SOURCE: hp media center pc won't turn on after electriticy
Unplug the power cord and hold the power button in until the light on the front comes on and fades out,The plug the power cord back in and start as normal.
Posted on Mar 13, 2009
SOURCE: HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
Posted on Mar 15, 2009
M1160n wont boot windows xp nor two internal fans
Step 1:
Lets try this...
Unplug the cpu
Step 2:
remove the battery from on the mainboard
Step 3:
press and hold the power button for 30 seconds
Step 4:
release it
Step 5:
put the battery back in, plug in and turn on , it should work fine..
Step 6:
If that fails replace the power supply..
Dec 28, 2012 | HP Media Center m1080n (PC099A#ABA) PC...
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
HP m1080n will not boot F8 and F10 do not work will not boot from XP disk
Reseat CMOS battery, try booting up from XP CD with only 1 memory stick after that
Dec 15, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
HP won't start - pushing the button and nothing happens...
first thing first, may you have a multitester on you, chick the power cord on replace the power cord , chick the power supply and open it and chick the fuse it might be cut, replace the fuse. and if does not work then replace the power suplly with the same specification.
Nov 05, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
DVD/CD door stuck on Bose 3 2 1
On the 321 systems turn off the power and unplug the power cord from the bass module. Wait 5 minutes and plug it back in. Then, simply hit the "stop/eject" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
Thanks to Matthew O;Neil for the the tip,...Italo
On a Lifestyle system with a tray that won't open, try this: Turn off the power to the system and unplug the power cord to the back of the media center itself. Wait 5 minutes and plug it back in. Then, simply hit the "open/close" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
If this does not work, then call Bose when you are home with the system at 800-367-4008.
Nov 05, 2008 | Bose (321GS) System
Nov 02, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Hp media center power
Jul 11, 2008 | HP Media Center m7060n PC Desktop
Jun 01, 2008 | HP Media Center m7250n (ED842AA) PC...
HP Media Center m1080n (PC099A#ABA) PC Desktop Logo
47 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
