Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp LC - 42DH77E TV power light is flashing and it wont turn on
  • 53 Answers
SOURCE: No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Posted on Mar 16, 2008
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
SOURCE: the power light and OPC light flash but TV won't
try making sure tht tha scart or HDMI cable is securly fitted (depending on which one u using) and this suld solve loss of picture or sound
Posted on Jun 09, 2009
  • 117 Answers
SOURCE: My Sharp Aquos LC-52D64U shut off by itself, and
sounds like power supply/ohm supplies for repair in uk
Posted on Nov 23, 2009
  • 7 Answers
SOURCE: sharp aquos lc-37d43u tv
I've read online that upgrading to the latest firmware sometimes resolves this issue. That's kind of shooting in the dark though - I personally would not feel completely confident that a FW flash would actually resolve the issue (as it could still be lurking beneath somewhere, waiting to surface again). If you have no warranty, then the FW flash is not a bad option. It's relatively easy and virtually impossible to screw up!
Another option is to order a replacement (new or used) main power board, and swap it into the TV (or pay someone to do it). It seems the power circuit board is a common culprit for this issue. If you're a do-it-yourselfer, then open up your TV and see if you can tell which component is failing, then hit eBay for a replacement:
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=sharp+power+board&_sacat=See-All-Categories
However, if you're still under warranty, then I imagine you've figured out by now that your best bet is to contact Sharp to fix this issue. Mine was luckily under the extended (15-month) factory warranty when this started happening to me. I was 13+ months out from date of purchase. Sharp support confirmed a tech needed to come out for an all-day appointment to troubleshoot the TV (I have the monstrous 65" Aquos). Thank goodness for the extra 3 month warranty I got when signing up for the Aquos Advantage club! Otherwise, my $3400 investment might have cost me at least $700-$800 to stay online - only ONE year out from purchase! If I would have known about the frequency and common nature of this problem, I would not have hesitated on buying the additional 3-year protection during my first year as an owner. Now I know to research product defects a bit more before opting out of a warranty for a multi-thousand dollar purchase!
In any case, I'll post the root cause of my issue (same symptom - OPC and power lights flash three times, then pause, and repeat indefinitely until TV is unplugged), once the Sharp tech leaves my place this coming week. Keep in mind that my root cause may not be the same as yours, even though the error codes are the same. :)
Good luck with your issue!
Posted on Dec 27, 2009
Sharp tv wont turn
If you have power to the standby light but no life beyond that you could be looking at a main tuner pcb: Link attached:
Search results for LC 50LE751K
Jun 06, 2014 | Televison & Video
SHARP LC-32B24U POWER LIGHT FLASHES AND UNIT WONT TURN ON
This is on a protection mode.
This is a case to be handled by a qualified service technician.
Aug 05, 2012 | Sharp LC-32SB24U 32 in. LCD TV
Sharp Aquos LC-42DH77E 42" LCD TV TV appears to
The PNL-POW (LCD panel Power) and the PS-ON will be 0V until the main board send out the signal to turn them on, it is working.
Do you get backlights?
Did you check the fuses on the Inverter board? You power supply is working.
This service manual may match your chassis:
http://elektrotanya.com/?q=showresult&megnev=Sharp&megnev2=LC-42DH77E&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 01, 2011 | Sharp Televison & Video
LC-42DH77E Sharp No picture Green led comes on then red LED comes on after a short while RED LED flashes twice then reoccurs .
maybe its on power supply try to check at power supply section check nearby parts of regulator ic if you can, test those passive and active parts using vom if those parts are ok then the regulator ic is defective
Apr 30, 2011 | Sharp LC40E77U LCD TV
LCD panel is perfect with no dead pixels, however: When you switch it on, screen comes up briefly, then goes off, with flashing red light. LCD TV Sharp LC-42DH77E model any help very much...
Sounds like a power supply problem - take off the back check voltages coming from power supply if they are good check your inverter board to make sure they are good.
Thanks,
michael
Mar 25, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
Jan 06, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
My sharp tv wont stay on, it flashes green
Hi i have seen this before sharp hdtv's are known for having the internal power supply go faulty
Feb 01, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My sharp aquos lc-c3242u turned itself off and now wont turn back on. i plugged it into a different power receptacle and the green light flashes but wont turn on. is there a way to reset the tv, or is...
If power light continuously flashing it means backlight problem. Two possible causes. One, backlight invertor is faulty. Two, but realy rare, one of the CCFL lamps went bad.
Dec 02, 2009 | Sharp Televison & Video
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
746 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
