Question about Ovens
Kenmore 85230 MICROWAVE TOP MOUNT I NEED OVEN LIGHT REPLACEMENT SOCKRT....TRIED THREE WORKING BULS NOTHING IS WORKING
  • 213 Answers
SOURCE: MIcrowave stopped working
there is a 15 or 20 amp fuse behind the control panel. turn power off at breaker, remove control pand the fuse will either be round and the size of a quarter, screwed in or will be about an inch long and cliped into place
Posted on Nov 19, 2007
MNTECH
  • 1543 Answers
SOURCE: GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
Posted on Sep 19, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore gas oven won't heat up
If your ignitor is coming on that means the oven control is supplying the power to the ignitor and gas valve. So the gas valve is ok because it is allowing for a complete circuit so what the heck is wrong? The ignitor MUST draw 3.5 amps in order to open the gas safety and allow the gas to come out. The ignitor must be very bright, if it is dim then it is bad. (MORE)
Posted on Feb 09, 2009
  • 117 Answers
SOURCE: kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Posted on Feb 25, 2009
  • 414 Answers
SOURCE: I purchased a microwave/convect oven combo last
Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
Posted on Sep 05, 2010
Glass top on my Kenmore oven shattered- is t repairabe
Probably cheaper to replace whole oven try insurance if u have its an accident so insurance may pay if u have.
Oct 16, 2014 | Kenmore Ovens
I need to replace a wall mounted microwave oven. It needs to mount only to the back plate - there is no access to mounting holes in the top. I have replaced this oven once before, but now I cannot find a...
I just replaced one of those myself. New one had totally different back plate which had to be replaced. Both new and old ones were bolted to cabinet above.
Oct 29, 2013 | GE JEB1095 Electric Single Oven
I need to replace the light bulb in my whirlpool self-cleaning oven but I can not remove the glass cover. How do I remove it?
hello,
Here is a solution to go about the glass bellow
Removing your microwave door allows you to quickly clean out any accumulated food or grease. This also makes it easy to get to all the crumbs and debris around the door hinges. While you have the door off its hinges, examine the plastic panel and glass window for signs of damage. Make sure you install a replacement door that is designed for your brand of microwave to ensure that it will fit correctly.
  • Remove the power cord from the electrical outlet and move your microwave onto a workbench or sturdy table. For cabinet-mounted microwaves, pry off the decorative grills or front panels and remove the mounting screws. You should then be able to slide the microwave out of its mounting bracket.
  • 2 Open the microwave door and remove the glass tray. Use a flathead screwdriver or putty knife to pry off the plastic cover on the inside of the door. Work around the edge of the glass until the cover slips free.
  • 3 Remove the door by pulling the mounting pins out of the hinges at the top and bottom. You may need an assistant to steady the door so you can have both hands free to work with the pins.
  • hope this solution help?
    Thanks for visiting fixya.
    Oct 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Nothing on the oven works, however the burners work on top, but when we turn the oven on nothing happens I even grabbed hold of the heating element in the stove and felt no heat or burn myself or anything
    Check the thermal fuses / sensors mounted on the top exterior of the heating chamber and also the heating element. Both accessible from the rear of the oven. The element is most likely to have gone. It will be a 2 or 3 turn coil type with the fan mounted to the middle of it or a flat element with no fan. You will need to check the number of turns of the coiled element and also the mounting holes to ensure you get the right type. Turn off the mains power at the breaker or distribution point. You can get to the element behind the rear plate of the oven cavity by removing the side shelf slides, and rear panel by undoing the securing screws on the plate (2 or 4 depending on the exact model you have). Often a good idea to take a photo of the element mounting and take the model and serial no of the oven so that you can take this to the domestic appliance shop or email it to an online supplier to make sure that the element they supply is correct for your exact oven.
    Nov 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Thermador smw272y won't heat at all
    The switches on the first circcuit card mounted horizontally in the space above the microwave enclosure and behind the control pannel have burned to the point that they no longer engage properly to close the power to the oven heating elements. I do not know anyone who has removed the plastic covers and cleaned them to the point of working again properly and do not recommend trying that approach. The only sure solution is to replace the circuit card that has the three switches.
    Sep 01, 2009 | Thermador SMW272 Electric Double Oven
    After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
    This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
    Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
    Jun 03, 2009 | Ovens
    Kenmore Oven Mod# 665.75012104
    hi. thanks for the question .i would replace the bake igniter. that will solve your problem. happy graduation .thanks the appliance doc
    May 07, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
    Kenmore Oven
    The igniter may need to be replaced again. The only way to know is to test it to see if it has enough amperage to light the gas. If it glows, but no lighting of the gas, get it tested.
    Mar 21, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
    Kenmore 47779 double oven; lower oven doesn't work after self clean
    Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
    Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
    Ovens Logo
    76 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
