Question about KitchenAid 24 in. KUDI02CRBS stainless Steel Built-in Dishwasher
In between wash cycles, water seems to back up into the dishwasher. I had a plumber take a look at the drain and disposal in the kitchen sink to see if there was an issue there. He suggested to have appliance repair tech to come look and indicated that he believed that the issue may be the "cylianoid" valve. Does the this valve prevent water from backing up into the dishwasher after it has drained?
rickzilla
  • 706 Answers
SOURCE: Kenmore Ultra Wash III Dishwasher will not drain properly
From the sound of things, your dishwasher drains faster than your sink drain ( via the garbage disposal) can drain it off.. You may have a problem with the way your sink drain/trap is vented and there is too much back pressure to drain down quickly.. When you run water from your sink, does it take a long time to drain down or if you fill your sink up and drain it, does it drain slowly ? That may be your problem.. Hope that helps.
Posted on Aug 26, 2008
leroyal
  • 2120 Answers
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
Posted on Jan 06, 2009
  • 3 Answers
SOURCE: Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Posted on Apr 23, 2009
  • 672 Answers
SOURCE: KitchenAid dishwasher allows water to drain while washing
Your dishwasher is siphoning the water out. The drain hose should turn upward, nearly to the bottom side of the counter top, before it attaches to the drain or disposal. If it has an independant drain it still needs the rise and also needs an air break to stop the siphoning.
Posted on Jul 18, 2009
  • 784 Answers
SOURCE: dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Posted on Sep 13, 2009
DISHWASHER FILLING UP WIYH WATER WHEN NOT IN USE
Check to see if dishwasher drain is attached to garbage disposer. Running the disposer when the dishwasher drains and it will help keep it clean but if the disposer drain line plugs then the water can drain back into the dishwasher. If it does not connect there then you have a slow kitchen drain and this can be fixed by having a plumber snake it. Often it is plugged with grease that can be cleared with boiling hot water poured down the drain. If this is not the problem then check to see if the dishwasher drain is raised as high as it can go under the sink cabinet. Fasten it up with a strap if needed. This will create a trap to keep the water from flowing back into the dishwasher. Do this regardless of your problem. Lastly If the dishwasher does not drain and it is connected to the disposer then the problem is that the knock out plug was not removed when the disposer was installed. Remove the hose at the disposer and knock it out with a screwdriver. This plug is there so you can install disposer without tying a dishwasher in. Otherwise it would leak there. A slow drain may back up and run into the dishwasher before you see any water appear in the sink. If you raise the dishwasher line to the underside of the counter top you should see water in the sink before it begins to drain into the dishwasher. A slow drain may only show up when you are doing a lot of dishes.
Oct 21, 2014 | Dishwashers
Flooding in both drawers of dishwasher
I suppose "flooding in both drawers of ..." implies water is not draining out. Is that right?
It is a very little information to give you any clear solutions.
Did the water get into the drawers without starting any wash program? Most likely it is the backflow from kitchen sink back through the dishwasher drain hose. Does your kitchen sink plumbing have an air gap sowehere. If so, is it clear?
If the water is the back flow then it is likely to be smelly and you do not want to run it through the dishwasher. I would suggest take the drain hose out from under the sink downpipe and drop into an empty bucket. Then take all the fixtures out from the drawers and empty out water using a small container.
Put the washer arms back and run each drawer on a short rinse cycle collecting the drain water in the bucket. If cycle runs clear, then get plumber to check the kitchen downpipe.
Reconnect drain hose.
Hope this helps.
Dec 28, 2010 | Fisher DD603FCSS Dishwasher
Water not draining after wash. Checked the troubleshooting guide and none apply to problem. It seems like the pump isn't running.
Have you purchased a new food waste disposer for the kitchen sink area? If so, make certain if you are draining the dishwasher directly into the food waste disposer, that you have removed the plug from the food disposer. Or you may be correct that the water pump is inoperable due to an obstruction or basic malfunction. Contact an appliance service company.
Apr 14, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
My dishwasher backed up into my kitchen sink , it was about 30 minutes into a 2 hour wash cycle--i drained the diswasher, but 1 inch stayed in it till this morning, the sink drained on its on
It sounds like an issue with the sink drain rather than the dishwasher. Many dishwashers are connected to a double sink, one bay of which contains a garbage disposal. If yours is connected in that configuration, run the disposal to clear any food debris that may still be present while running the HOT water into the disposal.
If you have no disposal or if the dishwasher is connected to the other non-disposal bay, check the sink drain again for proper drainage.
The easiest way to do this is to put a plug in the drain (both sides, one at a time), then fill the sink about half way with luke warm water. Then reach in and pull the plug from each side, watching to see how each side drains, but especially the side with the dishwasher connected. If it's slow draining, focus your efforts on clearing the drain on that particlular side of the sink. Try a plunger first before resorting to other methods to clear the sink. If you plunge the dishwasher side, get underneath the sink and pinch off the discharge line from the dishwasher if possible. A pair of vise grips works well, but don't overtighten them.
Some dishwashers have a soft disposal that can eject enough ground up particles into a sink to cause plugging up over time, especially if the dishwasher empties into the disposal side.
Jan 20, 2010 | Whirlpool 24 in. GU980SCG Built-in...
2 weeks ago, I had a plumber come and put in a new garbage diposer and since then somewhat old/dirty water seems to be sitting at the bottom after all cycles are done. I calle dhim back and he says that...
There is a breakaway stub in the garbage disposal's dishwasher hose port, it needs to be removed before connecting the dishwasher drain hose when installing the disposal.
Disconnect the dishwasher drain hose at the disposal, get a screwdriver and, insert in the disposal's dishwasher drain port and tap on it with hammer until it breaks off. Then remove that stub from the sink side.
Oct 14, 2009 | GE 24 in. Profile PDW7800 Built-in...
AFTER THE WASH AND RINSE CYCLE IT DOES NOT SEEM TO
Bad pump or a kink in the drainline between the appliance and the garbage disposal. And since we're speaking of garbage disposals check to see if scum hasn't built up at the drain orfice on the dishwasher.
Good Luck
Dave
Aug 19, 2009 | Dishwashers
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
New Garbage disposal, washing machine and dishwasher won't work.
Does not sound like these problems are directly related to the disposer. Grinding sound is most likely the impeller on the washer's pump. The washer gets to the first pump out and is unable to pump due to bad impeller or an obstruction. Bad impeller means replace pump motor. (not very hard) Check water supply to dishwasher. Valve turned off or line kinked? Filter screen at solonoid valve plugged?
Aug 15, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Dish machine
you need a plumber sounds like your sink piping has a blockage
Mar 08, 2008 | Dishwashers
KitchenAid 24 in. KUDI02CRBS stainless Steel Built-in Dishwasher Logo
32 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
