Question about Keurig Ultra B50 1-Cup Coffee Maker
My new Keurig coffemaker has started putting the brew, through the cup holder, very slowly and sometimes will stop before the large cup is filled. I've been cleaning the the "needle" spout every few times. It will be OK for a few cups then clog again. Any suggestionhs? I would like to order a new partfor it. Do you know how I can contact Keurig?
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Mar 01, 2011
Why does my Keurig smoke when brewing coffee, and the water doesn't go through until I take out the cup?
You probably have a clogged nozzle/needle. Take a straightened paperclip and run it thru the hollow needles that puncture the top and bottom of the k-cup. Make sure they are clear then try to brew a cup. Never reuse a k-cup. That's what usually clogs the needles.
Sep 19, 2014 | Keurig Coffee Makers & Espresso Machines
Keurig Vue V700 not filling cup
You are experiencing a clog of the upper tube. Not outside but inside the tube. Use a paperclip, open an end force it up the tube to clear the deposits and your in business. Remember to do a Full cleaning now and again with vinegar solution. Keep Filter changes at least every 4 to 6 weeks.
Jan 18, 2014 | Keurig Vue V700 Brewing System - 110774
Keurig troubleshooting
This problem is addressed on the Keurig website:
http://www.keurigtroubleshooting.com/Keurig-Coffee-Brewer-Problems.html
Scroll down to Partial Cup Brewing
Jan 05, 2014 | Coffee Makers & Espresso Machines
Mini keurig stops brewing and blows tops off k-cups
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Jan 01, 2013 | Keurig Mini B31 Plus Black Coffee Maker
Coffemaker not brewing, trying to de-scale but wont brew
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 16, 2011 | Keurig B60 Coffee Maker
My Keurig B60 is inconsistant in filling the cup. When I push the large cup to start brewing, it sometimes gives me 1/4 cup, 3/4 cup or a full cup.
heatman101
Mar 24, 2011 | Keurig B60 Coffee Maker
The coffemaker won't brew and showed a descale message. What does that mean?
Scale---or mineral deposits---form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water
1.Unplug the coffee machine and remove the cup.
2.Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
3.Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
4.Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
5.Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
6.Unplug the machine and dump the water into the sink.
7.Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue
Dec 10, 2010 | Keurig B70 Coffee Maker
Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Apr 06, 2009 | Keurig B50 Coffee Maker
Keurig B60 coffeemaker stopped pumping water because I didn't notice there was almost no water left in the chamber and started it--I added water right away but it won't pump any more water out of the...
This morning my Keurig sounds like it begins to pull water then stops. I tried to cut it off then back on. Still didn't work.Removed water from reservoir and K-cup and added pure vinegar. Ran machine several times without filter or Kcup by pressing cup selector several times. You must open K-cup holder and close each time. I had to do this about a dozen times before the water began to draw again. Flushed system by filling water reservoir with fresh water, and brewed just plain water until vinegar was gone.Works like brand new.
Nov 11, 2008 | Keurig B60 Coffee Maker
Keurig Ultra B50 1-Cup Coffee Maker Logo
206 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
