Question about GPS
Compass and temperature indicators stopped working
  • charles663 Nov 13, 2010
    2000 Toyota 4 Runner
    rear view mirror / compass, temperature, and automatic dimming
    works intermittently / Was not working this morning / I hit a bump in road and compass and temperature displayed properly.
    I checked the plug on back of mirror. It was secure. I think I have a loose connection with power supply / or loose ground. I don't know where the power supply connection is located or ground. Thanks Charles
    Top Expert:
  • GPS Master
  • 75,822 Answers
Hello
First off I will need the make and the model of the GPS, approx how old is the unit? have you attempted any repair to correct this issue of no compass or temperature read out.
Posted on Nov 12, 2010
  • yadayada
    yadayada Nov 13, 2010
    I have had allot of these mirrors in for warranty and non warranty repairs for exactly this problem, the only fix for this is to replace the mirror, they are not sent in for repair, no parts are made available to repair them at any factory electonics service center, Toyota considers them to be a throw away part, sorry but this is the fact of the matter.
  • yadayada
    This is not a connection problem, it is a defective mirror, have never seen anything else and have checked dozens of times.
How do I find the fuse on an impala 2002 for the.outside temperature and compass
There are two fuses one in the right I/P junction block an one in the left I/P junction block ! The right is marked DK / RKE 10amp fuse. The left is marked A/C / CRUSE 10amp fuse ! I don't think these are the problem ! These fuses supply power to the microprocessor in the driver information center . According to my service information the microprocessor supply's power to the ambient air temperature sensor an to the compass.
This mode displays an 8 point compass heading on the left hand side of the DIC. The compass will display the current vehicle direction relative to one of 8 compass headings using N, NE, E, SE, S, SW, W, and NW for the readout. The ambient temperature displays on the right hand side of the DIC. If the ambient temperature is below 3?°C (37?°F), the temperature reading will toggle between displaying the outside temperature and the word ICE for two minutes. If the temperature is less than minus 40?°F for more than 2 seconds, OC will display. If the temperature is above 140?°F for more than 2 seconds, SC will be displayed. If OC or SC is displayed DTC's will be set. For compass calibration and compass magnetic variation adjustment refer to Electronic Compass Calibration .
Feb 28, 2015 | 2002 Chevrolet Impala
Direction indicator (compass)
check the wire is connected to fuse panle
Aug 30, 2014 | 2002 Nissan Altima
My rear view mirror with temp and compass sometimes will not work. It will show all the digital shows up at once and not the temp, but sometimes it works ok. What can I do?
Does the compass work when the temperature goes out? If the compass still works then chances are that the ambient temp sensor is defective. Also, could be wiring to the sensor. If the compass goes out with the temperature then chances are the mirror itself is defective. Cheapest most common problem is the ambient temp sensor. It's behind the grill by the condenser at the front of the vehicle.
Aug 20, 2014 | 2003 Chevrolet Silverado 1500
How do i reset the compass on a 2006 dodge grand caravan
Hi Roger, I'm glad to help. Below is the procedure for resetting the compass on your vehicle.
COMPASS VARIATION ADJUSTMENT Compass variance, also known as magnetic declination, is the difference in angle between magnetic north and true geographic north. In some geographic locations, the difference between magnetic and geographic north is great enough to cause the compass to give false readings. If this problem occurs, the compass variance setting may need to be changed.
To set the compass variance:
1. Using the Variance Settings map, find your geographic location and note the zone number Figure 1.
22681.jpg Figure 1 - Variance Settings 2. Turn the ignition switch to the On position. If the compass/thermometer data is not currently being displayed, momentarily depress and release the C/T push button to reach the compass/thermometer display. 3. On Electronic Vehicle Information Center (EVIC) and Compass Mini-Trip Computer (CMTC) equipped vehicles depress the Reset push button and hold the button down until "VAR = XX" appears in the display. This takes about five seconds. On Compass Temperature Module (CT) equipped vehicles depress the C/T push button and US/M push button down until "VAR = XX" appears in the display. This takes about five seconds. 4. Release the push button(s). "VAR =XX " will remain in the display. "XX" equals the current variance zone setting. 5. On Electronic Vehicle Information Center (EVIC) and Compass Mini-Trip Computer (CMTC) equipped vehicles momentarily depress and release the STEP button to step through the zone numbers, until the zone number for your geographic location appears in the display. On Compass Temperature Module (CT) equipped vehicles depress the US/M push button to step through the zone numbers, until the zone number for your geographic location appears in the display. 6. On Electronic Vehicle Information Center (EVIC) and Compass Mini-Trip Computer (CMTC) equipped vehicles momentarily depress and release the RESET push button to enter the displayed zone number into the EVIC/CMTC module memory. On Compass Temperature Module (CT) equipped vehicles depress the C/T push button to enter the displayed zone number into the electronic module memory. 7. Confirm that the correct directions are now indicated by the compass.
May 17, 2014 | 2006 Dodge Caravan
Compass/Outside Temperature overhead doesn't work?
Not a solution, but mine doesn't work either.
Dec 03, 2011 | 1998 Mercury Mountaineer
Our outside temperature display on our dash now says zone 9, not the outside temperature, on our 2002 Ford Explorer. How do we fix it to display the temperature again?
The zone nine is for the compass you need to calibrate the compass. and then you temp will work again. check the owners manual if you do not have one call the service department at a ford dealer they should be able to help you.
Feb 17, 2011 | Ford Explorer Cars & Trucks
Display - outside temperature and compass
The overhead console is quite prone to internal failure. Dim, intermittent, or dead displays are a common symptom of an internal failure. We offer a reasonable repair service with a lifetime guarantee. Check it out: www.autoclockrepair.com
Jan 23, 2010 | 2002 Ford Expedition
Can't get the outside temp. showing in the inside backview mirror
Check the connector that plugs into the back of the mirror and make sure it is pushed in all the way. If that is not it, look carefully at the wires going into the connector. I had one that broke off. I had to pull the pin out of the connector and re crimp it onto the wire.
May 02, 2009 | 1998 Chevrolet Suburban
Temperature/compass display no longer works, any suggestions?
Number one..,
Id check the fuses then if still you have no luck id check that the unit is getting power by using a circuit tester or voltmeter ect...
Let us no how you get on...
Jules...
Mar 22, 2009 | 1999 Ford Explorer
GPS Logo
21 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
