Where can i find parts for my scanport 19" montor there is no picture nor power i opened it up and found bad card
    Scholar:
  • 152 Answers
Personally, I wouldn't mess around with a monitor. You can get seriously hurt by taking it apart. But .... since you have already opened it and found the bad card, try eBay. I have found a lot of parts there for reasonable prices.
Posted on Jun 18, 2008
Monitor flashes black and white rapidly like a strobe light.
The easiest way to check this problem out is take your monitor over to someone who has a computer or if you have an extra computer at home hook the monitor up to see if it stops doing this. Then you will know if it is not the monitor. Then you can focus on the video card going bad or is bad. Change the card with a new one, problem is solved. Check the cables connections make sure they are not loose as well. Restart you computer also discharge it by pushing in the power button in while the computer is unplugged from the wall. John
Jan 13, 2011 | Scanport N9 19" LCD Monitor
I lost the data cable to my scanport 19 inch monitor GL 1920S My email is pettwayr@yahoo.com. I want to order a new data cable by using my credit card.
what is your credit card? i can help you regarding to buying specific cables and pheriperals you want.. i can be your consultant.
thanks and god bless! just email me.
Nov 06, 2010 | Scanport GL-1920S 19" Flat Panel LCD...
I need a power cord for a Scanport 1920S 19 in. Flat Panel LCD Monitor
It uses a "standard" power-cord.
Look in any "Thrift Store" or "Dollar Store",
or buy at any small "mom-and-pop" computer-store -- they probably have a box-full of them.
Don't pay more than $2.
Oct 11, 2010 | Scanport GL-1920S 19" Flat Panel LCD...
I have a scanport 19" monitor and it will stay on for a little while and then go off and I have to repeatedly keep pushing the on and off button to be able to see what I am doing. If you leave it off for...
Look for bad caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 20, 2010 | Scanport N9 19" LCD Monitor
Scanport N9 Monitor Model #M19FBK flashes one time and goes dark.
Not likely it got damaged in the move.
Make sure the plugs are firmly seated. That is, the power cord and the video plug at both ends.
Apr 18, 2010 | Scanport N9 19" LCD Monitor
My monitors power light blinks red
I assume you have already try this monitor with other PC, just to be sure before opening up the case.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
http://www.badcaps.net
Apr 02, 2010 | X2Gen MG19MY 19" LCD Monitor
Screen is on but picture dose not show... cables connected
Solution, replace monitor with a new one.
I have found, at my shop, that getting parts for these things can be pricey and by the time I charge labor as well, could just buy a new one.
Probably a bad internal power supply or the inverter that powers the bulb(s) went out, which is sometimes built in with the power supply itself. If, and I stress IF, the parts are available, be prepared to pay more than its worth.
Pick up a new one, shop around on different brands. Some manufacturers offer 3 year warranties. ;)
Oct 23, 2007 | Scanport 17" LCD Monitor
Repair Help
Hi the FIRST thing I would do is, check the Lamp(s) and see if they are OK.. Next replace ALL the Electrolytic Capacitors in the Power Supply section.. with same or Better temperature ratings. Esspecially any by any Heatsinks or the like. If this don't sort ya problem, it may not B worth continuing?
Aug 06, 2007 | Scanport H7 17" LCD Monitor
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
