Question about HP Audio Players & Recorders
I have HP Speakers (Rock 2.0) with two +1 config. They are not working properly. I have the power led glowing its usual blue when i switch on the tweeter unit, but the power is not coming on on the sub woofer. But there is no music / sound emnating from the speakers. I plugged it into my laptop and the tweeters worked. Is there a problem with the soundcard ?
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
Benimur
  • 6966 Answers
SOURCE: karaoke speaker,no woofer or midrange working, only tweeter
Hi, it's probably that the 8" woofer and the midrange of the "amped" enclosure is open. One way to test is to remove just one wire from the inside of the enclosure to the woofer or midrange in question and with the use of a continuity tester (or a VOM), check for the resistance of the coil of each the 2 speakers. Both should read anywhere from 4-8 ohms, if there's no reading (VOM needle will not move) then the coil(s) are open. In the absence of a tester, a single AAA or AA battery would do (pls. some would argue that this is not a sound practice, however this should be enough for you to be able to determine the condition of the coil(s)). With the use of the battery and a single short length of electrical wire, apply power from the battery to the terminals of the speaker, if the cone moves, then chances are it is good, if they don't then you would have to replace it. Am not sure if available in your area, but there are some trained people who can rewind the coil should a replacement speaker be not readily available. Hope this be of help. Please let us know how things turn up. Regards.
Posted on Apr 15, 2007
TJBENGR
  • 121 Answers
SOURCE: Tweeters & Midrange Speakers
If you have a Ohm Meter, check the resistance to the speakers. If it is very high, the speakers are burned, (or the crossover is (just capacitors, and resisters...cheap)). If it is close to 4 ohms check the wiring and connectors..to and at the speakers, most likly the receiver/amp is not blown.
Posted on Apr 20, 2008
robotek
  • 1512 Answers
SOURCE: woofer not working on new bx8a speaker
Hi ermo
Your new speakers are BiAmped, and if a woofer is not working then it is probably a fault in the amp or connection for that woofer, or the the woofer itself has a problem. If they are brand new, I suggest you take it back to purchase point to get sorted out. There is nothing that you can do that will NOT void your warranty. If you do not have a warranty, then get back to me here and we can work through the problem. Cheers
regards
Graeme
Posted on May 25, 2008
  • 4234 Answers
SOURCE: Lost woofer in one cabinet.
I'm not familiar with your specific model, but some of these have fuses for the woofers. Check for a blown safety fuse. Also, verify that the connections to the crossover board are in good shape. These crossovers are not that complex and don't usually fail. Keep us posted on what you find.
Dan
Posted on May 29, 2008
On my hp 6710b running windows 7, im trying to get wirless to work and it tells me it is not on and that I have to turn on switch on front or side , or use function keys . I have looked everywhere and I...
Here you go. . .(#18 is the button location)
439c6ce.gif 1. Volume mute button with LED indicator
2. Volume scroll zone with up/down LED indicators
3. Integrated microphone
4. RJ-11/modem port
5. Optical drive
6. Media Card Reader
7. 2 USB 2.0 ports
8. HP Fingerprint Sensor
9. Integrated stereo speakers
10. Touchpad with scroll zone
11. Touchpad buttons
12. Hard drive activity / HP 3D DriveGuard LED
13. Battery charging LED
14. Power/standby LED
15. Wireless on/off LED
16. Power button with LED
17. HP Info / HP QuickLook button with LED indicator
18. Wireless on/off button with LED indicator
19. HP Presentation button with LED indicator
20. WLAN antennas (with WLAN option)
21. WWAN antennas (with WWAN option)
Aug 26, 2010 | HP Smart Buy Notebook
HP E800 PAVILLION WILL NOT POWER ON
If there is not LED glowing in from of the servers, check the power cable is seated in properly. If that is also fine, the problem is with the power module itself. Get it replaced.
If there is LED dispaly and no BIOS screen coming up, Switch off the server and make sure the memory modules are seated properly in DIMM slots.and also the processor and HDD.
If still it didnt come up, better contact the vendor.
Please come back and vote for me if this turns to be helpful for you or also if you need more clarifications. Thnx
Mar 27, 2010 | HP NetServer E800
Not able to switch on the mothere board. Green led on the board glows but the system is not powering on.
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Feb 02, 2010 | Intel Computers & Internet
Samsung samtron monitor does not work
Please check whether the power cable is properly inserted...
The power button of this model fails with time.You need 2 press it tightly and hold it till the LED is on....
try this...
Hope this helped...
Dec 21, 2009 | SAMTRON 55V 15" CRT Monitor
How to connect HDD LED & POWER LED & RESET LED & 2 others who is blue and whid & my SPEAKERS, can you help me here?
don't you have the book for the motherbd? Most motherboards tell you right on them wat connection goes where. look for them they should be in close vicinity of each other Usually.... HDD-Harddrive connection./.RST - Reset /pwr-- to switch ....etc....
Oct 16, 2009 | Asrock ConRoe945G-DVI Motherboard
My HP laptop is not booting all of a sudden. Today morning i performed a forceful shutdown of my laptop after which it has stopped booting. On pressing the power on button, all the blue LED glows but the...
Try tapping on F11 after you turn the laptop on, and see if it will go into the recovery mode. If it does, you are in luck, and can choose how you want to do the recovery.
If it does not, you can order a set of recovery disks from HP for about $15us which includes shipping costs. Or, you can load any retail version operating system, and download/install device drivers from http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1839164&taskId=135&prodTypeId=321957&prodSeriesId=1839143&lang=en&cc=us&submit=Go%20»
Good luck, and please rate my response.
Thank you
Mar 15, 2009 | HP Compaq nx6310 Notebook
CREATIVE SPEAKERS NOT WORKING!!!
creative speakers not working.even though power button on the led not glowing. today morning properly worked but suddenly not working light not glowing. send me solution to my mail crishnareddy@gmail.com tan q
Jan 10, 2009 | Creative Labs Audio Players & Recorders
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
Creature JBL
check for the switches is in on,then check the wires are connected properly
May 11, 2008 | HP JBL Platinum Computer Speakers
53 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
