Question about American Pro WS-9412 Car Subwoofer
SEALED BOX DIMENSIONS FOR WS-9015 2 15" AMERICAN PRO SUBS
TRIING TO BUILD A SEALED BOX FOR MY SUBS, I CANT FIND ANYTHING ON AMERICAN PRO. I HAVE 2 15" AMERICAN PRO WS-9015 SUBS. I NEED SEALED AND PORTED BOX DIMENSIONS. THANK YOU.
  • Anonymous Jan 06, 2009
    same problem as above
I have 3 power acoustik subs and im trying to build a ported box tund to about 30 hz what should b the dimensions of the box???
that requires a formula,go to utube. you need to know what subs you have some require ported boxes and others require sealed boxes.
Oct 04, 2014 | Car Audio & Video
How much air space is needed for lanxar max st 15d
it depends on the type of enclose you are building and number of drivers .. you can build them and share air space or build it to were neither sub shares any air space.. if you buy a prefab enclosure for your 15s what ever q logic or q power or any other manufacture choses to build a universal port or vent or sealed box will be just fine.
which type of enclosure are you looking for ..
port
vented
seal
isobaric
1.6 cuft to 2.5 cuft per subwoofer check out the sub boxes from qpower and there specs for 15"BASS15 3HOLE 40 1/8 x 21 x 21 x 17 2.5cuBASS15 4HOLE T 42 x 18 x 18 x 16 1/4 1.6cuqpowers specs from there website
radiorepair@windowtintingin239.com
Oct 29, 2013 | Car Audio & Video
How to build a box for my 2 Lanzar Max 12d subs to get real deep low bass
If you have a spec sheet as far as volume and any trunk dimensions I can design exactly what you are seeking.
Jul 21, 2012 | Lanzar MAX12D Car Subwoofer
Ihave 2 sony xs-gtx120Lw 12' going in a 04 honda civic. I want to build a box but do not have the specs for them subs in a ported box
here are the specs
  • Depth (Approx.) : 5 3/4"
  • Diameter (Approx.) : 12"
  • Dimensions (Approx) Depth : 5 3/4"
  • Mounting Dimensions (Approx.) : 13" OD, 5 3/4" mounting depth and 11" mounting diameter.
  • Weight (Approx.) : 11 lbs. 11 oz.
  • Power Handling Capacity : 1000 Watts Max
  • Rated Input : 300 Watts
  • Magnet : Ferrite
  • Material : Polypropylene cone
  • Frequency Response : 30 - 1000 Hz
  • Impedance : 4 Ohms
  • Sensitivity (db) : 86 +/-2dB (1W, 1m)
  • Jun 03, 2011 | Car Audio & Video
    Does anyone know the actual airspace requirements for sealed and ported enclosures on these speakers? Please no idiots building cube boxes need to respond!
    For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 11 inches x 11 inches x 11 inches. Hope this helps
    Feb 17, 2011 | Autotek MX-1222 Car Subwoofer
    Trying to put ported reccomended subs in sealed box.
    Well, 1.6 cubic foot for a 15 is not nearly enough. A ported box for 1 15 should be in atleast 3 cubes by itself. I suggest building a new box yourself or getting someone else to do it for you. If factory specs on those subs is no larger than 3 cubes per sub then I'd get the box built to 3 cubes per sub after all displacement and tune it in the upper 30's range. Putting big subs like that in a small sealed enclosure can and will damage a sub. and if you try to port an enclosure that is too small to begin with that will also hurt the woofer. Do it right or learn the hard way.
    May 26, 2010 | Kole audio KMX-15 Car Subwoofer
    I need to know the deminsions to build a box for my rfl mtx 15
    If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 16 inches x 16 inches x 16 inches
    May 20, 2010 | MTX RFL152 Car Subwoofer
    What is the best size speaker box for this subwoofer
    Any type BOX will do...This ensures all the thump to be pushed forward to give all the sound from the speaker forward....enjoy. Alow enough room to get you hand in to wire easy and you should be good.
    Dec 27, 2009 | Sony XS-L122P5 Car Subwoofer
    Want to find out the best type of enclosure for 2 lanzar max pro 124d subwoofers
    you best type of enclosure will be a sealed enclosure or you can build it with a partition in the middle seperating the 2 subs and port each side.
    heres a link that will give you the specs for your sub
    http://www.lanzar.com/manuals/MAXP104D-124D-154D.pdf
    Sep 07, 2009 | Lanzar (Pair) MAXP104D Max Pro Series...
    I need to build a box for 2 AudioBahn AW1505Q subs need the specs on how big the box needs to be
    try a electronics store like jaycar? they have the specs for sealed and ported speaker boxes depending on size and watts
    Jul 28, 2009 | Car Audio & Video
    Car Audio & Video Logo
    200 people viewed this question
    Top American Pro Car Audio & Video Experts
    xxxxxx xxx
    Are you an American Pro Car Audio and Video Expert? Answer questions, earn points and help others
